Playing dvds with vlc
fairoaks
Operating system: Rosa Fresh
Сообщение fairoaks »
Installed task codecs plus libdvdcss2, plus libdvdread, but vlc will not play a dvd .WTF?
fairoaks
Re: Playing dvds with vlc
Installed every codec I can find. Still will not play a dvd.
vlc in konsole;
libdvdread: Encrypted DVD support unavailable.
libdvdnav: DVD Title: BANK_JOB
libdvdnav: DVD Serial Number: 3A3D3DCA001CD17D
libdvdnav: DVD Title (Alternative):
libdvdnav: Unable to find map file '/home/d/.dvdnav/BANK_JOB.map'
libdvdnav: DVD disk reports itself with Region mask 0x00000000. Regions: 1 2 3 4 5 6 7 8
*** libdvdread: CHECK_VALUE failed in ifo_read.c:841 ***
*** for cell_playback.last_vobu_start_sector <= cell_playback.last_sector ***
[0x7f979c0009b8] main input error: ES_OUT_RESET_PCR called
Fontconfig warning: FcPattern object size does not accept value "0"
No accelerated IMDCT transform found
[0x7f9780001248] main vout display error: Failed to resize display
[0x7f979c0009b8] main input error: ES_OUT_SET_(GROUP_)PCR is called too late (pts_delay increased to 300 ms)
[0x7f979c0009b8] main input error: ES_OUT_SET_(GROUP_)PCR is called too late (pts_delay increased to 363 ms)
[0x7f979c0009b8] main input error: ES_OUT_SET_(GROUP_)PCR is called too late (pts_delay increased to 365 ms)
fairoaks
Ignore these two posts. Uninstalled Rosa Fresh. It has so many problems it`s not worth it.
Aesculapius
Сообщение Aesculapius »
fairoaks писал(а):Ignore these two posts. Uninstalled Rosa Fresh. It has so many problems it`s not worth it.
RestrictedFormats/PlayingDVDs?
Linux Playing encrypted DVD?
Hm. I install VLC and play my test DVD ("Lord of the rings" SE, 6*DVD-9) without any problems.
Aesculapius
keleg писал(а):Use ROMP
А как же свобода выбора? vlc поддерживается в РОСА.
Ну, просто на момент ответа я точно проверял ROMP и был за него уверен и еще не успел vlc.
Но и у vlc у меня проблем нет.
