Steam в R4
Steam в R4
Нет ускорения графики
[serge@samsung ~]$ steam
Couldn't find dpkg, please update steamdeps for your distribution.
Running Steam on rosadesktopfresh 2014.1 32-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(1411443970)
libGL error: dlopen /usr/lib/dri/r600_dri.so failed (/home/serge/.local/share/Steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /usr/lib/dri/r600_dri.so))
libGL error: unable to load driver: r600_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: r600
libGL error: dlopen /usr/lib/dri/swrast_dri.so failed (/home/serge/.local/share/Steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /usr/lib/libLLVM-3.5.so))
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
Installing breakpad exception handler for appid(steamwebhelper)/version(20140922201705)
Installing breakpad exception handler for appid(steamwebhelper)/version(1411417025)
[1010/155338:ERROR:nss_util.cc(1018)] Failed to load NSS libraries.
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 70: non-double matrix element
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 78: saw unknown, expected number
Error: OpenGL GLX context is not using direct rendering, which may cause performance problems.
For more information visit https://support.steampowered.com/kb_article.php?ref=9938-EYZB-7457.
** (steam:25547): WARNING **: Unknown device type 14
** (steam:25547): WARNING **: Could not create object for /org/freedesktop/NetworkManager/Devices/0: unknown object type
Generating new string page texture 2: 48x256, total string texture memory is 49,15 KB
Generating new string page texture 3: 256x256, total string texture memory is 311,30 KB
Adding licenses for the following package(s): 0, 37, 64, 77, 108, 482, 1045, 2206, 2487, 8360, 12064, 12361, 13944, 17250, 17882, 18185, 27644, 47618, 48323, 48324, 48325, 49447, 52296, 52326, 52661
roaming config store loaded successfully - 1739 bytes.
migrating temporary roaming config store
ExecCommandLine: ""/home/serge/.local/share/Steam/ubuntu12_32/steam" "
System startup time: 8,58 seconds
[1010/155344:ERROR:renderer_main.cc(227)] Running without renderer sandbox
Generating new string page texture 70: 1024x256, total string texture memory is 1,36 MB
Generating new string page texture 71: 256x256, total string texture memory is 262,14 KB
Generating new string page texture 72: 128x256, total string texture memory is 1,49 MB
Generating new string page texture 73: 32x256, total string texture memory is 1,52 MB
Generating new string page texture 74: 24x256, total string texture memory is 1,55 MB
Generating new string page texture 75: 384x256, total string texture memory is 1,94 MB
Generating new string page texture 76: 64x256, total string texture memory is 2,01 MB
STEAM_RUNTIME has been set by the user to: /home/serge/.local/share/Steam/ubuntu12_32/steam-runtime
Generating new string page texture 81: 128x256, total string texture memory is 2,14 MB
Generating new string page texture 83: 256x256, total string texture memory is 2,40 MB
ExecCommandLine: "/home/serge/.steam/root/ubuntu12_32/steam steam://open/driverhelperready"
ExecSteamURL: "steam://open/driverhelperready"
Generating new string page texture 87: 128x256, total string texture memory is 2,53 MB
еще dpkg просит в зависимости
Re: Steam в R4
Стим-то тут при чём, это графику копать надо.
Re: Steam в R4
так это Стим ругается на его отсутствие, но эффекты рабочего стола работают, всвозможное 3D тоже. В R3 все работало.
Re: Steam в R4
ну а поставить dpkg ?
Re: Steam в R4
Тоже самое, вот такое окно вылезает
Он еще какие-то пакеты стал требовать, после установки dpkg
which: no gnome-terminal in (/usr/bin:/bin:/usr/local/bin:/usr/X11R6/bin/:/usr/games:/usr/lib/qt4/bin:/home/serge/bin)
QDBusConnection: session D-Bus connection created before QCoreApplication. Application may misbehave.
QGtkStyle cannot be used together with the GTK_Qt engine.
X Error: BadWindow (invalid Window parameter) 3
  Major opcode: 20 (X_GetProperty)
  Resource id:  0x380001a
Package curl needs to be installed
Package python-apt needs to be installed
Package xterm needs to be installed
Package xz-utils needs to be installed
Package zenity needs to be installed
Package libgl1-mesa-dri:i386 needs to be installed
Package libgl1-mesa-glx:i386 needs to be installed
Package libc6:i386 needs to be installed
[1010/184108:ERROR:nss_util.cc(1018)] Failed to load NSS libraries.
** (steam:32442): WARNING **: Unknown device type 14
** (steam:32442): WARNING **: Could not create object for /org/freedesktop/NetworkManager/Devices/0: unknown object type
System startup time: 5,14 seconds
[1010/184113:ERROR:renderer_main.cc(227)] Running without renderer sandbox
Generating new string page texture 84: 128x256, total string texture memory is 2,53 MB
Re: Steam в R4
Андрея щас нет он-лайн под рукой, чтобы спросить конкретно про пакет стима, но походу кривовато прошло обновление. Хорошо бы проверить установку стима в чистой виртуалке с образа, конечно. Конкретно тут только разрабы смогут помочь, но уже пятница вечер :( по-хорошему, если есть отдельный раздел для хомяка, проще установиться с нуля, проще будет разгребать всё это, если вообще ошибка возникнет.
Viktor125
Operating system: ROSA Desktop.Fresh 2012/Ubuntu 12.10
Re: Steam в R4
Сообщение Viktor125 »
Устанавливал с диска, та же беда не запускается, при запуске происходит обновление и больше ни каких действий
Re: Steam в R4
Значит, баг. Идите на багзиллу оба, можно на русском.
Re: Steam в R4
У меня так же было месяц назад.
Никак не могу вспомнить, как вылечил.
Вроде там были проблемы в конфигах steam.
Или в конфигах KDE.
Можно попробовать удалить файлы ~/.steampid и ~/.steampath, и папку ~/.steam
и переименовать папку ~/.local/share/Steam
Останутся ли проблемы?
alexey_r
Re: Steam в R4
Сообщение alexey_r »
Или в конфигах KDE.
Неплохо было бы вспомнить )))
beeth
Operating system: rosa 2012.1 fresh rp1
Re: Steam в R4
Сообщение beeth »
была такая же проблема, решил удалением /home/beeth/.local/share/Steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-linux-gnu/libstdc++.so.6
alexey_r
Re: Steam в R4
beeth писал(а):была такая же проблема, решил удалением /home/beeth/.local/share/Steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-linux-gnu/libstdc++.so.6
У меня не решилась. Почитал на других форумах, пока никак...
Пробовал даже так:
rm ~/.local/share/Steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-linux-gnu/libstdc++.so.6
rm ~/.local/share/Steam/ubuntu12_32/steam-runtime/i386/lib/i386-linux-gnu/libgcc_s.so.1
rm ~/.local/share/Steam/ubuntu12_32/steam-runtime/amd64/lib/x86_64-linux-gnu/libgcc_s.so.1
rm ~/.local/share/Steam/ubuntu12_32/steam-runtime/amd64/usr/lib/x86_64-linux-gnu/libstdc++.so.6
rm ~/.local/share/Steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-linux-gnu/libxcb.so.1
При запуске проверяет обновление, распаковывает рантайм и завершается.
beeth
Re: Steam в R4
Сообщение beeth »
Пробовал даже так:
это для открытых драйверов амд, с закрытыми драйверами амд тоже не запускается, забил сижу на открытых
alexey_r
Re: Steam в R4
Как производительность на открытых?
Пакет x11-deriver-video-ati?
Edit:
Разобрался!
Производительность примерно такая же, а ноут стал холодней ))
beeth
Re: Steam в R4
Сообщение beeth »
alexey_r писал(а):Как производительность на открытых?
Edit:
Разобрался!
А связка какая Интел+Амд или Амд+Амд? у меня Амд+Амд нормально все работает, только со ждущим режимом проблемы
alexey_r
Re: Steam в R4
Интел+амд. Ждущий режим работает нормально
Re: Steam в R4
У меня на закрытых тоже обновляется, и сразу закрывается. А на открытых вот такая вот бяка http://forum.rosalab.ru/download/file.p ... &mode=view
beeth
Re: Steam в R4
Сообщение beeth »
tverskoy писал(а):У меня на закрытых тоже обновляется, и сразу закрывается. А на открытых вот такая вот бяка http://forum.rosalab.ru/download/file.p ... &mode=view
попробуй так сделать на открытых
Re: Steam в R4
Удялил и не получилось
Ukol
Re: Steam в R4
Сообщение Ukol »
Такая же беда на проприетарном драйвере, а на свободном работает. У меня Intel+ AMD.
Yamah
Нетбук: Rosa Fresh R10
Re: Steam в R4
Сообщение Yamah »
У меня что-то стим при запуске стал регулярно запускать konsole и настойчиво просит установить несколько пакетов. Понятное дело, что названия пакетов и способ их установки стим берет из Убунту. Если konsole закрыть, то он нормально дальше работает.
Re: Steam в R4
"имя, сестра, имя!"
какие пакеты-то?
beeth
Re: Steam в R4
Сообщение beeth »
Yamah писал(а):У меня что-то стим при запуске стал регулярно запускать konsole и настойчиво просит установить несколько пакетов. Понятное дело, что названия пакетов и способ их установки стим берет из Убунту. Если konsole закрыть, то он нормально дальше работает.
у меня konsole запускает если установлен пакет dpkg, без него молча запускает;
удалось запустить на проприетарном драйвере amd при помощи команды LC_ALL=C steam
Yamah
Re: Steam в R4
Сообщение Yamah »
keleg писал(а):"имя, сестра, имя!"
какие пакеты-то?
Steam needs to install these additional packages:
        curl, python-apt, xterm, xz-utils, zenity, libgl1-mesa-dri:i386, libgl1-mesa-glx:i386, libc6:i386
[sudo] password for <USER>:
beeth писал(а): у меня konsole запускает если установлен пакет dpkg, без него молча запускает;
А-а-а-а! Вот где собака порылась!!!
