System checks summary
File properties checks...
Files checked: 145
Suspect files: 0
Rootkit checks...
Rootkits checked : 312
Possible rootkits: 2
Rootkit names : GasKit Rootkit, Unknown rootkit
Applications checks...
Applications checked: 3
Suspect applications: 0
The system checks took: 6 minutes and 42 seconds
All results have been written to the log file (/var/log/rkhunter.log)
One or more warnings have been found while checking the system.
Please check the log file (/var/log/rkhunter.log)
[root@kaos kaos]#
Последний раз редактировалось Elia 18 сен 2014, 00:49, всего редактировалось 1 раз.
Desintale el sistema y lo volvi a instalar, esta vez me baje el chkrootkit y tambien me da otro rootkit, si por favor alguien sabe si son reales estos rootkit y como se puede limpiar el sistema, (aunque sea un tuto) o si son falsos positivos, he buscado por internet y no veo nada claro al respecto.
-- esta vez el rkhunter no parece actualizado, aqui les dejo solo lo que me da ahora el chkrootkit:
[kaos@kaos ~]$ sudo rkhunter --update
[sudo] password for kaos:
The default temporary directory will be used: /var/lib/rkhunter/tmp
The default database directory will be used: /var/lib/rkhunter/db
[ Rootkit Hunter version 1.4.0 ]
Checking rkhunter data files...
Checking file mirrors.dat [ No update ]
Checking file programs_bad.dat [ No update ]
Checking file backdoorports.dat [ No update ]
Checking file suspscan.dat [ No update ]
Checking file i18n/cn [ No update ]
Checking file i18n/de [ Updated ]
Checking file i18n/en [ Updated ]
Checking file i18n/tr [ Updated ]
Checking file i18n/tr.utf8 [ Updated ]
Checking file i18n/zh [ No update ]
Checking file i18n/zh.utf8 [ No update ]
[kaos@kaos ~]$ sudo chkrootkit
ROOTDIR is `/'
Checking `amd'... not found
Checking `basename'... not infected
Checking `biff'... not found
Checking `chfn'... not infected
Checking `chsh'... not infected
Checking `cron'... not infected
Checking `crontab'... not infected
Checking `date'... not infected
Checking `du'... not infected
Checking `dirname'... not infected
Checking `echo'... not infected
Checking `egrep'... not infected
Checking `env'... not infected
Checking `find'... not infected
Checking `fingerd'... not found
Checking `gpm'... not found
Checking `grep'... not infected
Checking `hdparm'... not infected
Checking `su'... not infected
Checking `ifconfig'... not infected
Checking `inetd'... not tested
Checking `inetdconf'... not found
Checking `identd'... not found
Checking `init'... not infected
Checking `killall'... not infected
Checking `ldsopreload'... not infected
Checking `login'... not infected
Checking `ls'... not infected
Checking `lsof'... not infected
Checking `mail'... not infected
Checking `mingetty'... not infected
Checking `netstat'... not infected
Checking `named'... not found
Checking `passwd'... not infected
Checking `pidof'... not infected
Checking `pop2'... not found
Checking `pop3'... not found
Checking `ps'... not infected
Checking `pstree'... not infected
Checking `rpcinfo'... not infected
Checking `rlogind'... not found
Checking `rshd'... not found
Checking `slogin'... not infected
Checking `sendmail'... not infected
Checking `sshd'... not infected
Checking `syslogd'... not tested
Checking `tar'... not infected
Checking `tcpd'... not infected
Checking `tcpdump'... not infected
Checking `top'... not infected
Checking `telnetd'... not found
Checking `timed'... not found
Checking `traceroute'... not infected
Checking `vdir'... not infected
Checking `w'... not infected
Checking `write'... not infected
Checking `aliens'... no suspect files
Searching for sniffer's logs, it may take a while... nothing found
Searching for HiDrootkit's default dir... nothing found
Searching for t0rn's default files and dirs... nothing found
Searching for t0rn's v8 defaults... nothing found
Searching for Lion Worm default files and dirs... nothing found
Searching for RSHA's default files and dir... nothing found
Searching for RH-Sharpe's default files... nothing found
Searching for Ambient's rootkit (ark) default files and dirs... nothing found
Searching for suspicious files and dirs, it may take a while...
/usr/lib/debug/.build-id
Searching for LPD Worm files and dirs... nothing found
Searching for Ramen Worm files and dirs... nothing found
Searching for Maniac files and dirs... nothing found
Searching for RK17 files and dirs... nothing found
Searching for Ducoci rootkit... nothing found
Searching for Adore Worm... nothing found
Searching for ShitC Worm... nothing found
Searching for Omega Worm... nothing found
Searching for Sadmind/IIS Worm... nothing found
Searching for MonKit... nothing found
Searching for Showtee... nothing found
Searching for OpticKit... nothing found
Searching for T.R.K... nothing found
Searching for Mithra... nothing found
Searching for LOC rootkit... nothing found
Searching for Romanian rootkit... nothing found
Searching for HKRK rootkit... nothing found
Searching for Suckit rootkit... Warning: /sbin/init INFECTED
Searching for Volc rootkit... nothing found
Searching for Gold2 rootkit... nothing found
Searching for TC2 Worm default files and dirs... nothing found
Searching for Anonoying rootkit default files and dirs... nothing found
Searching for ZK rootkit default files and dirs... nothing found
Searching for ShKit rootkit default files and dirs... nothing found
Searching for AjaKit rootkit default files and dirs... nothing found
Searching for zaRwT rootkit default files and dirs... nothing found
Searching for Madalin rootkit default files... nothing found
Searching for Fu rootkit default files... nothing found
Searching for ESRK rootkit default files... nothing found
Searching for rootedoor... nothing found
Searching for ENYELKM rootkit default files... nothing found
Searching for common ssh-scanners default files... nothing found
Searching for suspect PHP files... nothing found
Searching for anomalies in shell history files... nothing found
Checking `asp'... not infected
Checking `bindshell'... not infected
Checking `lkm'... chkproc: nothing detected
chkdirs: nothing detected
Checking `rexedcs'... not found
Checking `sniffer'... eth0: PF_PACKET(/sbin/dhclient)
Checking `w55808'... not infected
Checking `wted'... chkwtmp: nothing deleted
Checking `scalper'... not infected
Checking `slapper'... not infected
Checking `z2'... user kaos deleted or never logged from lastlog!
Checking `chkutmp'... The tty of the following user process(es) were not found
in /var/run/utmp !
! RUID PID TTY CMD
! root 11132 tty1 /etc/X11/X :1 -background none -verbose -auth /var/run/gdm/auth-for-gdm-1xSUrs/database -seat seat0 -nolisten tcp vt1
chkutmp: nothing deleted
Checking `OSX_RSPLUG'... not infected
[kaos@kaos ~]$
Elia писал(а):oḱ, but it is not only one *false positive* there are two more ... it is too much, something is going wrong with ROSA.
I think you're little paranoid. if you do not know what it this "something" you should believe the real info, given to you in the thread. Or just do the exact research and give the results here. Otherwise it's just meaningless words.
