Не включается экран после ждущего режима на ноутбуке
saman
Сообщение saman »
Экран черный и ничего не помогает кроме выключения.
Спящий режим работает и яркость экрана через клавиши тоже работают.
Как починить ждущий режим?
$ uname -a
Linux home 3.10.46-nrj-desktop-1rosa #1 SMP PREEMPT Tue Jul 1 11:20:14 UTC 2014 x86_64 x86_64 x86_64 GNU/Linux
$ dmesg | grep acpi
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    6.855662] acpi PNP0A08:00: Requesting ACPI _OSC control (0x1d)
[    6.855974] acpi PNP0A08:00: ACPI _OSC control (0x1d) granted
[    9.863537] acpi root: \_SB_.PCI0 notify handler is installed
[    9.863642] Found 1 acpi root devices
[   17.145092] acpi device:03: registered as cooling_device0
[   24.082716] ACPI: acpi_idle registered with cpuidle
[   27.306615] acpi-cpufreq: overriding BIOS provided _PSD data
$ dmesg | grep ACPI
[    0.000000] BIOS-e820: [mem 0x000000009dc80000-0x000000009e147fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000009e83a000-0x000000009e841fff] ACPI NVS
[    0.000000] ACPI: RSDP 00000000000f0490 00024 (v02 KAMPEN)
[    0.000000] ACPI: XSDT 000000009dd04080 00084 (v01 KAMPEN  Model X 01072009 AMI  00010013)
[    0.000000] ACPI: FACP 000000009dd0b608 0010C (v05 KAMPEN  Model X 01072009 AMI  00010013)
[    0.000000] ACPI BIOS Bug: Warning: Optional FADT field Pm2ControlBlock has zero address or length: 0x0000000000000000/0x1 (20130328/tbfadt-603)
[    0.000000] ACPI: DSDT 000000009dd041a0 07461 (v02 HKB000 HKB00000 00000000 INTL 20051117)
[    0.000000] ACPI: FACS 000000009e13d080 00040
[    0.000000] ACPI: APIC 000000009dd0b718 0007E (v03 KAMPEN  Model X 01072009 AMI  00010013)
[    0.000000] ACPI: FPDT 000000009dd0b798 00044 (v01 KAMPEN  Model X 01072009 AMI  00010013)
[    0.000000] ACPI: MCFG 000000009dd0b7e0 0003C (v01 KAMPEN  Model X 01072009 MSFT 00010013)
[    0.000000] ACPI: SLIC 000000009dd0b820 00176 (v01 KAMPEN  Model X 01072009 AMI  00010013)
[    0.000000] ACPI: HPET 000000009dd0b998 00038 (v01 KAMPEN  Model X 01072009 AMI  00000005)
[    0.000000] ACPI: SSDT 000000009dd0b9d0 00B10 (v01 KAMPEN  Model X 00000001 AMD  00000001)
[    0.000000] ACPI: SSDT 000000009dd0c4e0 046D1 (v02 KAMPEN  Model X 00000002 MSFT 04000000)
[    0.000000] ACPI: CRAT 000000009dd10bb8 00380 (v01 KAMPEN  Model X 00000001 AMD  00000001)
[    0.000000] ACPI: SSDT 000000009dd10f38 013C6 (v01 KAMPEN  Model X 00000001 INTL 20051117)
[    0.000000] ACPI: SSDT 000000009dd12300 0008C (v01 KAMPEN  Model X 00000001 INTL 20051117)
[    0.000000] ACPI: SSDT 000000009dd12390 010E8 (v01 KAMPEN  Model X 00000001 INTL 20051117)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: IOAPIC (id[0x05] address[0xfec00000] gsi_base[0])
[    0.000000] ACPI: IOAPIC (id[0x06] address[0xfec01000] gsi_base[24])
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x10228210 base: 0xfed00000
[    0.006046] ACPI: Core revision 20130328
[    0.021631] ACPI: All ACPI Tables successfully acquired
[    0.211748] PM: Registering ACPI NVS region [mem 0x9dc80000-0x9e147fff] (5013504 bytes)
[    0.211922] PM: Registering ACPI NVS region [mem 0x9e83a000-0x9e841fff] (32768 bytes)
[    0.223459] ACPI: bus type PCI registered
[    0.276144] ACPI: Added _OSI(Module Device)
[    0.276153] ACPI: Added _OSI(Processor Device)
[    0.276160] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.276167] ACPI: Added _OSI(Processor Aggregator Device)
[    0.278726] ACPI: EC: Look up EC in DSDT
[    0.279222] ACPI Error: [CPST] Namespace lookup failure, AE_NOT_FOUND (20130328/psargs-359)
[    0.279242] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SBRG.EC0_._REG] (Node ffff88013a2415c8), AE_NOT_FOUND (20130328/psparse-537)
[    0.279441] ACPI Error: [CPST] Namespace lookup failure, AE_NOT_FOUND (20130328/psargs-359)
[    0.279458] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SBRG.EC0_._REG] (Node ffff88013a2415c8), AE_NOT_FOUND (20130328/psparse-537)
[    0.280733] ACPI: Executed 1 blocks of module-level executable AML code
[    0.292051] ACPI Error: [CPST] Namespace lookup failure, AE_NOT_FOUND (20130328/psargs-359)
[    0.292080] ACPI Error: Method parse/execution failed [\_SB_.PCI0.SBRG.EC0_._REG] (Node ffff88013a2415c8), AE_NOT_FOUND (20130328/psparse-537)
[    0.292124] ACPI: Interpreter enabled
[    0.292143] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S1_] (20130328/hwxface-568)
[    0.292161] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20130328/hwxface-568)
[    0.292200] ACPI: (supports S0 S3 S4 S5)
[    0.292208] ACPI: Using IOAPIC for interrupt routing
[    0.292377] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[    0.320819] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.321049] ACPI: No dock devices found.
[    0.321909] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[    0.321947] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[    0.322383] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[    0.322416] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[    6.845352] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    6.847653] pci 0000:00:10.0: System wakeup disabled by ACPI
[    6.848146] pci 0000:00:12.0: System wakeup disabled by ACPI
[    6.848402] pci 0000:00:12.2: System wakeup disabled by ACPI
[    6.848608] pci 0000:00:13.0: System wakeup disabled by ACPI
[    6.848857] pci 0000:00:13.2: System wakeup disabled by ACPI
[    6.849257] pci 0000:00:14.2: System wakeup disabled by ACPI
[    6.853098] pci 0000:02:00.2: System wakeup disabled by ACPI
[    9.856328] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 5 7 10 *11 14 15)
[    9.856486] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 *5 7 10 11 14 15)
[    9.856638] ACPI: PCI Interrupt Link [LNKC] (IRQs *4 5 7 10 11 14 15)
[    9.856789] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 5 7 *10 11 14 15)
[    9.856917] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 5 7 10 *11 14 15)
[    9.857035] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 5 7 *10 11 14 15)
[    9.857142] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 5 7 10 11 14 15) *0
[    9.857250] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 5 7 10 11 14 15) *0
[    9.863517] ACPI: Enabled 2 GPEs in block 00 to 1F
[    9.863738] ACPI: EC: GPE = 0x17, I/O: command/status = 0x66, data = 0x62
[    9.864213] ACPI: bus type ATA registered
[    9.864502] PCI: Using ACPI for IRQ routing
[    9.885163] pnp: PnP ACPI init
[    9.885205] ACPI: bus type PNP registered
[    9.885452] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[    9.885625] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    9.885756] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    9.885817] pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active)
[    9.885887] pnp 00:04: Plug and Play ACPI device, IDs PNP0b00 (active)
[    9.885933] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active)
[    9.886055] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    9.886109] pnp 00:07: Plug and Play ACPI device, IDs PNP0c04 (active)
[    9.886206] pnp 00:08: Plug and Play ACPI device, IDs PNP0303 (active)
[   12.386226] pnp 00:09: Plug and Play ACPI device, IDs STU0404 PNP0f13 (active)
[   12.887029] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[   12.891648] pnp 00:0b: Plug and Play ACPI device, IDs PNP0103 (active)
[   12.891665] pnp: PnP ACPI: found 12 devices
[   12.891676] ACPI: bus type PNP unregistered
[   17.144632] ACPI: Video Device [VGA] (multi-head: yes  rom: no  post: no)
[   17.144663] [Firmware Bug]: ACPI: No _BQC method, cannot determine initial brightness
[   17.159396] ACPI: bus type USB registered
[   24.111246] ACPI: Power Button [PWRB]
[   24.195211] ACPI: Sleep Button [SLPB]
[   24.195409] ACPI: Lid Switch [LID]
[   24.195496] ACPI: Power Button [PWRF]
[   24.343927] ACPI: Thermal Zone [TZ00] (55 C)
[   24.531422] ACPI: AC Adapter [AC0] (on-line)
[   24.632687] ACPI: Battery Slot [BAT0] (battery present)
$ cat /proc/acpi/wakeup
Device  S-state   Status   Sysfs node
RTKL      S0    *disabled  pci:0000:02:00.2
SBAZ      S4    *disabled  pci:0000:00:14.2
OHC1      S4    *enabled   pci:0000:00:12.0
EHC1      S4    *enabled   pci:0000:00:12.2
OHC2      S4    *enabled   pci:0000:00:13.0
EHC2      S4    *enabled   pci:0000:00:13.2
OHC3      S4    *disabled
EHC3      S4    *disabled
XHC0      S4    *enabled   pci:0000:00:10.0
