Запрос на удаление кучи пакетов при попытке установить QupZilla
user
Operating system: ROSA.FRESH.KDE.R6.x86_64
Сообщение user »
Packages lib64xcb1-1.9.1-2-rosa2012.1.x86_64, lib64xcomposite1-0.4.3-5-rosa2012.1.x86_64, lib64sqlite3_0-3.8.2-1-rosa2012.1.x86_64, lib64icudata49-49.1.1-2-rosa2012.1.x86_64, lib64gstreamer-plugins-base0.10-0.10.36-2-rosa2012.1.x86_64, lib64png15-1.5.17-1-rosa2012.1.x86_64, lib64gstreamer0.10_0-0.10.36-4-rosa2012.1.x86_64, lib64xslt1-1.1.27-1-rosa2012.1.x86_64, lib64icui18n49-49.1.1-2-rosa2012.1.x86_64, lib64xcb-util-image0-0.3.9-1-rosa2012.1.x86_64, lib64gcc1-4.7.4_2014.01-1-rosa2012.1.x86_64, lib64sm6-1.2.1-1-rosa2012.1.x86_64, lib64z1-1.2.8-1-rosa2012.1.x86_64, lib64ice6-1.0.8-3-rosa2012.1.x86_64, lib64gthread2.0_0-2.36.3-4-rosa2012.1.x86_64, lib64xcb-render0-1.9.1-2-rosa2012.1.x86_64, lib64gmodule2.0_0-2.36.3-4-rosa2012.1.x86_64, lib64gstbase0.10_0-0.10.36-4-rosa2012.1.x86_64, lib64x11_6-1.6.1-1-rosa2012.1.x86_64, lib64xml2_2-2.9.1-1-rosa2012.1.x86_64, lib64xcb-sync0-1.9.1-2-rosa2012.1.x86_64, lib64xcb-xfixes0-1.9.1-2-rosa2012.1.x86_64, lib64gobject2.0_0-2.36.3-4-rosa2012.1.x86_64, lib64glib2.0_0-2.36.3-4-rosa2012.1.x86_64, lib64pulseaudio0-5.0-2-rosa2012.1.x86_64, lib64stdc++6-4.7.4_2014.01-1-rosa2012.1.x86_64, lib64xi6-1.7.2-3-rosa2012.1.x86_64, lib64xcb-shape0-1.9.1-2-rosa2012.1.x86_64, lib64icuuc49-49.1.1-2-rosa2012.1.x86_64, glibc-2.15-8-rosa2012.1.x86_64, lib64freetype6-2.4.12-1plf-plf2012.1.x86_64, lib64xext6-1.3.2-2-rosa2012.1.x86_64, lib64xrender1-0.9.8-1-rosa2012.1.x86_64, lib64dbus-1_3-1.6.8-3-rosa2012.1.x86_64, lib64fontconfig1-2.10.93-2plf-plf2012.1.x86_64, lib64xcb-randr0-1.9.1-2-rosa2012.1.x86_64, lib64gio2.0_0-2.36.3-4-rosa2012.1.x86_64, lib64openal1-1.15.1-3-rosa2012.1.x86_64, lib64xcb-shm0-1.9.1-2-rosa2012.1.x86_64, lib64gl1-9.2.4-4-rosa2012.1.x86_64, lib64openssl1.0.0-1.0.1h-1-rosa2012.1.x86_64, lib64x11-xcb1-1.6.1-1-rosa2012.1.x86_64, lib64jpeg8-1.3.0-6-rosa2012.1.x86_64, lib64xcb-glx0-1.9.1-2-rosa2012.1.x86_64, lib64xcb-util-keysyms1-0.3.9-1-rosa2012.1.x86_64, lib64udev1-208-30-rosa2012.1.x86_64 are already installed
The following package has to be removed for others to be upgraded:
rosa-media-player-plugin-1.6-2-rosa2012.1.x86_64
 (due to conflicts with qupzilla-1.6.6-1-rosa2012.1.x86_64) (y/N)
Так и должно быть?
Re: Запрос на удаление кучи пакетов при попытке установить QupZilla
user писал(а):The following package has to be removed for others to be upgraded:
Так и должно быть?
Ну, тут не кучу пакетов предлагается удалить, а только один rosa-media-player-plugin. Если он установлен, то QupZilla иногда зависает или что-то в этом роде.
