Не запускается Gpodder
user
Operating system: ROSA.FRESH.KDE.R6.x86_64
Сообщение user »
Вот что пишет:
** (process:11676): WARNING **: Trying to register gtype 'GMountMountFlags' as enum when in fact it is of type 'GFlags'
** (process:11676): WARNING **: Trying to register gtype 'GDriveStartFlags' as enum when in fact it is of type 'GFlags'
** (process:11676): WARNING **: Trying to register gtype 'GSocketMsgFlags' as enum when in fact it is of type 'GFlags'
1400617834.454498 [gpodder.sync] WARNING: Could not find eyeD3
1400617835.572869 [gpodder.log] ERROR: Uncaught exception: Traceback (most recent call last):
  File "/usr/bin/gpodder", line 175, in <module>
    main()
  File "/usr/bin/gpodder", line 170, in main
    main.main(options)
  File "/usr/lib/python2.7/site-packages/gpodder/gtkui/main.py", line 3535, in main
    gp = gPodder(bus_name, core.Core(UIConfig, model_class=Model))
  File "/usr/lib/python2.7/site-packages/gpodder/gtkui/main.py", line 120, in __init__
    BuilderWidget.__init__(self, None)
  File "/usr/lib/python2.7/site-packages/gpodder/gtkui/interface/common.py", line 38, in __init__
    GtkBuilderWidget.__init__(self, gpodder.ui_folders, gpodder.textdomain, **kwargs)
  File "/usr/lib/python2.7/site-packages/gpodder/gtkui/base.py", line 66, in __init__
    self.new()
  File "/usr/lib/python2.7/site-packages/gpodder/gtkui/main.py", line 210, in new
    self.channels = self.model.get_podcasts()
  File "/usr/lib/python2.7/site-packages/gpodder/model.py", line 1393, in get_podcasts
    self.children = self.db.load_podcasts(podcast_factory)
  File "/usr/lib/python2.7/site-packages/gpodder/dbsqlite.py", line 156, in load_podcasts
    cur = self.cursor()
  File "/usr/lib/python2.7/site-packages/gpodder/dbsqlite.py", line 100, in cursor
    return self.db.cursor()
  File "/usr/lib/python2.7/site-packages/gpodder/dbsqlite.py", line 94, in db
    schema.upgrade(self._db, self.database_file)
  File "/usr/lib/python2.7/site-packages/gpodder/schema.py", line 185, in upgrade
    assert version == CURRENT_VERSION
AssertionError
    main()
    main.main(options)
    self.new()
    cur = self.cursor()
AssertionError
Re: Не запускается Gpodder
Только что поставил и запустил в x64. У вас какая система?
user
Сообщение user »
ROSA.FRESH.KDE.R3.x86_64
Попробуйте переставить его и все, что с ним связано. Если не поможет, то в багзиллу, будем пробовать воспроизвести и разбираться.
