Проблема с USB на ядре 3.10.34-3rosa в Rosa Fresh R3 [РЕШЕНО]
Yamah
Нетбук: Rosa Fresh R10
Сообщение Yamah »
Доброго времени суток!
С прошедшим Днём Победы!
Запостил баг 4019 для Rosa Fresh R3.
Есть материнская карта Asus M2 Crosshair
lspci
00:00.0 RAM memory: NVIDIA Corporation C51 Host Bridge (rev a2)
00:00.1 RAM memory: NVIDIA Corporation C51 Memory Controller 0 (rev a2)
00:00.2 RAM memory: NVIDIA Corporation C51 Memory Controller 1 (rev a2)
00:00.3 RAM memory: NVIDIA Corporation C51 Memory Controller 5 (rev a2)
00:00.4 RAM memory: NVIDIA Corporation C51 Memory Controller 4 (rev a2)
00:00.5 RAM memory: NVIDIA Corporation C51 Host Bridge (rev a2)
00:00.6 RAM memory: NVIDIA Corporation C51 Memory Controller 3 (rev a2)
00:00.7 RAM memory: NVIDIA Corporation C51 Memory Controller 2 (rev a2)
00:04.0 PCI bridge: NVIDIA Corporation C51 PCI Express Bridge (rev a1)
00:08.0 RAM memory: NVIDIA Corporation MCP55 Memory Controller (rev a1)
00:09.0 ISA bridge: NVIDIA Corporation MCP55 LPC Bridge (rev a2)
00:09.1 SMBus: NVIDIA Corporation MCP55 SMBus (rev a2)
00:0a.0 USB controller: NVIDIA Corporation MCP55 USB Controller (rev a1)
00:0a.1 USB controller: NVIDIA Corporation MCP55 USB Controller (rev a2)
00:0c.0 IDE interface: NVIDIA Corporation MCP55 IDE (rev a1)
00:0d.0 IDE interface: NVIDIA Corporation MCP55 SATA Controller (rev a2)
00:0d.1 RAID bus controller: NVIDIA Corporation MCP55 SATA Controller (rev a2)
00:0d.2 RAID bus controller: NVIDIA Corporation MCP55 SATA Controller (rev a2)
00:0e.0 PCI bridge: NVIDIA Corporation MCP55 PCI bridge (rev a2)
00:0e.1 Audio device: NVIDIA Corporation MCP55 High Definition Audio (rev a2)
00:10.0 Bridge: NVIDIA Corporation MCP55 Ethernet (rev a2)
00:11.0 Bridge: NVIDIA Corporation MCP55 Ethernet (rev a2)
00:12.0 PCI bridge: NVIDIA Corporation MCP55 PCI Express bridge (rev a2)
00:16.0 PCI bridge: NVIDIA Corporation MCP55 PCI Express bridge (rev a2)
00:17.0 PCI bridge: NVIDIA Corporation MCP55 PCI Express bridge (rev a2)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Address Map
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] DRAM Controller
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
02:06.0 Multimedia controller: Philips Semiconductors SAA7131/SAA7133/SAA7135 Video Broadcast Decoder (rev d0)
02:0b.0 FireWire (IEEE 1394): Texas Instruments TSB43AB22A IEEE-1394a-2000 Controller (PHY/Link) [iOHCI-Lynx]
04:00.0 Mass storage controller: Silicon Image, Inc. SiI 3132 Serial ATA Raid II Controller (rev 01)
05:00.0 VGA compatible controller: NVIDIA Corporation GK104 [GeForce GTX 760] (rev a1)
05:00.1 Audio device: NVIDIA Corporation GK104 HDMI Audio Controller (rev a1)
На ядре kernel-nrj-desktop-3.10.34-3rosa-1-1-rosa2012.1.x86_64 не работают практически все USB-устройства (клавиатуры, мыши, флэшки, камера Canon, смартфоны шнур видят только как зарядку), МФУ Samsung CLX-2160 система видит.
dmesg ругается на устройство: "device descriptor read/64, error -110"
На ядре kernel-nrj-desktop-3.10.34-2rosa-1-1-rosa2012.1.x86_64 все работаете нормально.
Другого 64-хбитного железа под рукой пока нет.
32-хбитной версии Rosa Fresh R3 на этом же железе тоже нет.
Пока решение: откат на предыдущую версию ядра.
У материнки, конечно, уже есть (должны быть от возраста) проблемы с питанием - конденсаторы от возраста подсохли. Но перезагрузска с предыдущей версии ядра, вряд ли может игнорировать проблемы питания.
Re: Проблема с USB на ядре 3.10.34-3rosa в Rosa Fresh R3
Скорее всего виновато не ядро. Попробуйте просто переставить.
http://forum.rosalab.ru/viewtopic.php?f ... 92&p=27042
Yamah
Сообщение Yamah »
Переставил. Но пока нет возможности перезагрузиться: идет конвертирование большого количества видеофайлов.
Yamah
Сообщение Yamah »
keleg писал(а):Скорее всего виновато не ядро. Попробуйте просто переставить.
Действительно помогло!
Переставил ядро. Даже перезагружаться не пришлось (был уже на "глючном" ядре) - все заработало.
