Bug systemd 208, not work urpmi
fkuller
Operating system: Rosa Fresh 2016.1 R9
Сообщение fkuller »
After upgrading to systemd 208, urpmi and rpm stopped working.
Re: Bug systemd 208, not work urpmi
fkuller писал(а):After upgrading to systemd 208, urpmi and rpm stopped working.
Do you have laptop is EFI + GPT hdd?
akdengi
Сообщение akdengi »
in latest update you recived not only systemd, but urpmi and rpm too. What did you mean by 'not working' ?
fkuller
Сообщение fkuller »
My laptop is EFI + GPT hdd, after updating systemd, udev, urpmi, rpm ... Can not use urpmi, just hangs on is verifying signature.
fkuller писал(а):My laptop is EFI + GPT hdd, after updating systemd, udev, urpmi, rpm ... Can not use urpmi, just hangs on is verifying signature.
I think it is the same problem that in Bug http://bugs.rosalinux.ru/show_bug.cgi?id=3634
I've never install packets and not deleted. Hanging all. Also on EFI+GPT hdd.
akdengi
Сообщение akdengi »
Please provide /lib/systemd/system/boot-efi.mount
fkuller
Сообщение fkuller »
My file boot-efi.mount
# Automatially generated by systemd-efi-boot-generator\n\n"
[Unit]
Description=EFI System Partition
[Mount]
Where=/boot/efi
What=/dev/disk/by-uuid/
Options=umask=0077
fkuller писал(а):My file boot-efi.mount
[Unit]
[Mount]
Where=/boot/efi
Options=umask=0077
What=/dev/disk/by-uuid/<no UUID efi partition>
Yes, same error as in the bug. :( Wait for fix...
akdengi
Сообщение akdengi »
Please provide output
for you system
Than i say what you need fix on boot-efi.mount
fkuller
Сообщение fkuller »
/dev/sda1: UUID="EBF8-30B4" TYPE="vfat" PARTUUID="4f028f54-a249-48b8-94d4-8b8a1c05cfc4"
/dev/sda2: UUID="aebcdc84-209c-4b1e-bebf-de3f4e5103af" TYPE="ext4" PARTUUID="42c9b7a2-0dec-4611-b94c-8affe17d0ecc"
/dev/sda3: UUID="c3342b7a-fa3e-41be-b51a-f59c147af0ab" TYPE="swap"
/dev/sda4: UUID="1399c73c-1442-4d79-b4f2-1460f6f97865" TYPE="ext4"
akdengi
Сообщение akdengi »
Change
to
What=/dev/disk/by-uuid/EBF8-30B4
And reboot.
Also please provide output of
gdisk -l /dev/sda | grep EF00
fkuller
Сообщение fkuller »
Thank you for your help, I do not speak Russian and little English, thanks to a Brazilian.
akdengi
Сообщение akdengi »
fkuller писал(а):Thank you for your help, I do not speak Russian and little English, thanks to a Brazilian.
This is error in efi mount generator - we investigate it for now and will try fix this as soon as posible. But you now knew how resolve this error.
