а он видимо требует еще каких-то зависимостей((
вот что получается при запуске из консоли:
$ nevernote
/usr/share/nevernote/nevernote.sh: строка 118: java: команда не найденаКод: Выделить всё
$ nevernote
Exception in thread "main" java.lang.ExceptionInInitializerError
at com.trolltech.qt.QtJambiObject.<clinit>(QtJambiObject.java:60)
Caused by: java.lang.RuntimeException: Loading library failed, progress so far:
Unpacking .jar file: 'qtjambi-linux32-gcc-4.5.2_01.jar'
Checking Archive 'qtjambi-linux32-gcc-4.5.2_01.jar'
- skipping because of wrong system: trying to load: 'linux32', expected: 'linux64'
Loading library: 'libQtCore.so.4'...
- using 'java.library.path'
- ok, path was: /usr/lib64/libQtCore.so.4
Loading library: 'libqtjambi.so'...
at com.trolltech.qt.internal.NativeLibraryManager.loadNativeLibrary(NativeLibraryManager.java:431)
at com.trolltech.qt.internal.NativeLibraryManager.loadLibrary(NativeLibraryManager.java:325)
at com.trolltech.qt.Utilities.loadJambiLibrary(Utilities.java:144)
at com.trolltech.qt.QtJambi_LibraryInitializer.<clinit>(QtJambi_LibraryInitializer.java:57)
... 1 more
Caused by: java.lang.RuntimeException: Library 'libqtjambi.so' was not found in 'java.library.path'=/usr/lib/jvm/java-1.6.0-openjdk-1.6.0.0.x86_64/jre/lib/amd64/server:/usr/lib/jvm/java-1.6.0-openjdk-1.6.0.0.x86_64/jre/lib/amd64:/usr/lib/jvm/java-1.6.0-openjdk-1.6.0.0.x86_64/jre/../lib/amd64:/usr/java/packages/lib/amd64:/usr/lib64:/lib64:/lib:/usr/lib
at com.trolltech.qt.internal.NativeLibraryManager.loadLibrary_helper(NativeLibraryManager.java:486)
at com.trolltech.qt.internal.NativeLibraryManager.loadNativeLibrary(NativeLibraryManager.java:426)
... 4 more
Could not find the main class: cx.fbn.nevernote.NeverNote. Program will exit.
/home/pavel
