Can't update systemd package stack.
benbullard79
Operating system: ROSA Fresh R5
OpenMandriva Lx 2014.1
openSuSE 13.2
Сообщение benbullard79 »
In brand new install of Fresh x86_64 R2. :cry:
 Package                        Version      Release       Dist  DEpoch Arch
(medium "main updates (distrib2)")
 lib64gcrypt11                  1.5.3        1             rosa  2012.1 x86_64
 lib64systemd-daemon0           204          22            rosa  2012.1 x86_64
 lib64systemd-id1280            204          22            rosa  2012.1 x86_64
 lib64systemd-journal0          204          22            rosa  2012.1 x86_64
 lib64systemd-login0            204          22            rosa  2012.1 x86_64
 systemd                        204          22            rosa  2012.1 x86_64
 systemd-sysvinit               204          22            rosa  2012.1 x86_64
 udev                           204          22            rosa  2012.1 x86_64
5.2MB of additional disk space will be used.
2.2MB of packages will be retrieved.
Proceed with the installation of the 8 packages? (Y/n) Y
installing systemd-sysvinit-204-22-rosa2012.1.x86_64.rpm udev-204-22-rosa2012.1.x86_64.rpm lib64systemd-journal0-204-22-rosa2012.1.x86_64.rpm lib64gcrypt11-1.5.3-1-rosa2012.1.x86_64.rpm lib64systemd-daemon0-204-22-rosa2012.1.x86_64.rpm lib64systemd-login0-204-22-rosa2012.1.x86_64.rpm systemd-204-22-rosa2012.1.x86_64.rpm lib64systemd-id1280-204-22-rosa2012.1.x86_64.rpm from /var/cache/urpmi/rpms
starting installing packages
created transaction for installing on / (remove=0, install=0, upgrade=8)
warning: LOOP:
warning: removing systemd-204-22.x86_64 "Requires: udev = 204-22" from tsort relations.
warning: removing udev-204-22.x86_64 "Requires: systemd = 204-22" from tsort relations.
warning: LOOP:
warning: removing systemd-194-20.x86_64 "Requires: systemd = 194-20" from tsort relations.
warning: removing udev-194-20.x86_64 "Requires: udev = 194-20" from tsort relations.
Preparing...                     ############################################################################
Installation failed:
        file /usr/share/bash-completion/completions/udevadm from install of systemd-204-22.x86_64 conflicts with file from package bash-completion-1.99-1.noarch
Installation failed:    file /usr/share/bash-completion/completions/udevadm from install of systemd-204-22.x86_64 conflicts with file from package bash-completion-1.99-1.noarch
Thanks,
Ben Bullard
