fstab
# Entry for /dev/sda6 :
UUID=87145e5b-44ba-4bc4-98dc-e2edbf7ca2aa / ext3 defaults 1 1
# Entry for /dev/sda8 :
UUID=4f2f45d3-97a3-4af3-9f91-0af36c9aa47c /home ext3 defaults 1 2
# Entry for /dev/sda5 :
UUID=687C8F507C8F1848 /mnt/Data ntfs-3g defaults 0 0
# Entry for /dev/sda3 :
UUID=584E786A4E7842B4 /mnt/windows ntfs-3g defaults 0 0
none /proc proc defaults 0 0
# Entry for /dev/sda7 :
UUID=3afc1070-7a04-4cd6-b244-e08a8f3d1389 swap swap defaults 0 0Код: Выделить всё
# DO NOT EDIT THIS FILE
# It is automatically generated by grub2-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
load_env
fi
set default="${saved_entry}"
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="--id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos6'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos6 --hint-efi=hd0,msdos6 --hint-baremetal=ahci0,msdos6 --hint='hd0,msdos6' 87145e5b-44ba-4bc4-98dc-e2edbf7ca2aa
else
search --no-floppy --fs-uuid --set=root 87145e5b-44ba-4bc4-98dc-e2edbf7ca2aa
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=1680x1050,1360x768,1280x800,1024x768,1024x600,800x600,640x480
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=bg_BG
insmod gettext
fi
terminal_output gfxterm
insmod part_msdos
insmod ext2
else
fi
insmod gfxmenu
loadfont ($root)/boot/grub2/themes/rosa/dejavu_sans_bold_14.pf2
loadfont ($root)/boot/grub2/themes/rosa/dejavu_sans_mono_11.pf2
loadfont ($root)/boot/grub2/themes/rosa/terminal_font_11.pf2
insmod png
set theme=($root)/boot/grub2/themes/rosa/theme.txt
export theme
insmod part_msdos
insmod ext2
else
fi
insmod png
background_image -m stretch /boot/grub2/themes/rosa/terminal_background.png
set timeout=10
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'ROSA Desktop Fresh R2' --class rosa --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-87145e5b-44ba-4bc4-98dc-e2edbf7ca2aa' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading Linux 3.12.5-nrj-desktop-1rosa ...'
linux /boot/vmlinuz-3.12.5-nrj-desktop-1rosa root=UUID=87145e5b-44ba-4bc4-98dc-e2edbf7ca2aa ro splash=silent logo.nologo radeon.dpm=1 resume=/dev/sda7 init=/lib/systemd/systemd
echo 'Loading initial ramdisk ...'
initrd /boot/initrd-3.12.5-nrj-desktop-1rosa.img
submenu 'Advanced options for ROSA Desktop Fresh R2' $menuentry_id_option 'gnulinux-advanced-87145e5b-44ba-4bc4-98dc-e2edbf7ca2aa' {
menuentry 'ROSA Desktop Fresh R2, with Linux 3.12.5-nrj-desktop-1rosa' --class rosa --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.12.5-nrj-desktop-1rosa-advanced-87145e5b-44ba-4bc4-98dc-e2edbf7ca2aa' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
menuentry 'ROSA Desktop Fresh R2, with Linux 3.11.8-vanilla.nrj.laptop.1rosa' --class rosa --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.11.8-vanilla.nrj.laptop.1rosa-advanced-87145e5b-44ba-4bc4-98dc-e2edbf7ca2aa' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
echo 'Loading Linux 3.11.8-vanilla.nrj.laptop.1rosa ...'
linux /boot/vmlinuz-3.11.8-vanilla.nrj.laptop.1rosa root=UUID=87145e5b-44ba-4bc4-98dc-e2edbf7ca2aa ro splash=silent logo.nologo radeon.dpm=1 resume=/dev/sda7 init=/lib/systemd/systemd
initrd /boot/initrd-3.11.8-vanilla.nrj.laptop.1rosa.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
menuentry 'Windows Recovery Environment (loader) (on /dev/sda1)' --class windows --class os $menuentry_id_option 'osprober-chain-DCB2B2FBB2B2D8EA' {
savedefault
insmod part_msdos
insmod ntfs
set root='hd0,msdos1'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 --hint='hd0,msdos1' DCB2B2FBB2B2D8EA
else
search --no-floppy --fs-uuid --set=root DCB2B2FBB2B2D8EA
fi
drivemap -s (hd0) ${root}
chainloader +1
menuentry 'Windows 7 (loader) (on /dev/sda2)' --class windows --class os $menuentry_id_option 'osprober-chain-965C76615C763BD5' {
savedefault
insmod part_msdos
insmod ntfs
set root='hd0,msdos2'
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos2 --hint-efi=hd0,msdos2 --hint-baremetal=ahci0,msdos2 --hint='hd0,msdos2' 965C76615C763BD5
else
search --no-floppy --fs-uuid --set=root 965C76615C763BD5
fi
chainloader +1
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/42_efi ###
### END /etc/grub.d/42_efi ###
### BEGIN /etc/grub.d/43_resque ###
if [ -f /boot/resque.iso -o -f /boot/sgb.iso ]; then
submenu 'Repair tools' {
if [ -f /boot/resque.iso ]; then
menuentry "Boot rescue CD" {
loopback loop /boot/resque.iso
linux (loop)/isolinux/vmlinuz0 boot=live iso_filename=/boot/resque.iso root=live:/dev/sr0 rootfstype=auto ro rd.live.image rhgb splash=silent logo.nologo rd.luks=0 rd.md=0 rd.dm=0
initrd (loop)/isolinux/initrd0.img
fi
if [ -f /boot/sgb.iso ]; then
menuentry "Run Grub2 repair" {
loopback loop /boot/sgb.iso
linux16 /boot/memdisk iso
initrd16 /boot/sgb.iso
fi
fi
### END /etc/grub.d/43_resque ###
### BEGIN /etc/grub.d/90_persistent ###
### END /etc/grub.d/90_persistent ###
