Very slow boot with error
Nitro3k
Operating system: ROSA Fresh R1
Сообщение Nitro3k »
Hi,
I have a problem with Rosa Fresh R1.
Every time I try to boot the loading screen shows up and hangs at 'dracut: Starting plymouth daemon' for about 20 minutes. After that it shows me a bunch of warnings and drops me into the debug shell. When I just type 'exit' the system boots normaly after.
Where could be a problem?
akdengi
Re: Very slow boot with error
Сообщение akdengi »
You need remove string 'splash=silent' from Grub boot string and then you will see where is error appear.
Nitro3k
Сообщение Nitro3k »
I didn't manage to fix the problem, so I just completely reinstalled the system.
Now it boots fine (for now) but I have a different problem:
When trying to run the second update, I get the following conflict warning:
Conflicting Packages писал(а):The following packages have to be removed for others to be upgraded:
alsa-utils-1.0.26-1-rosa2012.1.x86_64
(due to missing pciutils)
bootloader-utils-1.15-9-rosa2012.1.noarch
(due to unsatisfied drakxtools-backend >= 10-52)
drakconf-kde4-2012.1-3-rosa2012.1.x86_64
(due to missing drakxtools,
due to missing drakx-kbd-mouse-x11,
due to missing drakx-net,
due to missing rpmdrake)
drakguard-0.7.14-1-rosa2012.1.noarch
(due to unsatisfied drakxtools >= 10.22,
due to unsatisfied drakx-net >= 0.41)
drakx-finish-install-14.37-2-rosa2012.1.x86_64
(due to unsatisfied drakxtools == 14.37-2)
drakx-kbd-mouse-x11-0.99-3-rosa2012.1.x86_64
(due to unsatisfied drakxtools-curses >= 12.40)
drakx-net-1.1-4-rosa2012.1.noarch
(due to unsatisfied libdrakx-net == 1.1,
due to unsatisfied drakxtools >= 12.36,
due to unsatisfied drakx-net-text == 1.1)
drakx-net-text-1.1-4-rosa2012.1.noarch
(due to unsatisfied drakxtools-curses >= 12.36,
due to unsatisfied libdrakx-net == 1.1)
drakxtools-14.37-2-rosa2012.1.x86_64
(due to unsatisfied drakxtools-curses == 14.37-2)
drakxtools-backend-14.37-2-rosa2012.1.x86_64
(due to missing libldetect.so.0.12()(64bit),
due to missing perl(Xconfig::resolution_and_depth))
drakxtools-curses-14.37-2-rosa2012.1.x86_64
(due to unsatisfied drakxtools-backend == 14.37-2,
due to missing perl(Xconfig::various))
gtk+3.0-3.6.2-1-rosa2012.1.x86_64
(due to unsatisfied gtk+3.0-common == 3.6.2-1)
harddrake-14.37-2-rosa2012.1.x86_64
(due to unsatisfied drakxtools-curses == 14.37-2,
due to missing perl(Xconfig::various),
due to missing perl(Xconfig::card))
harddrake-ui-14.37-2-rosa2012.1.x86_64
(due to unsatisfied drakxtools == 14.37-2,
due to missing drakx-kbd-mouse-x11)
ipw3945-ucode-1.14.2-2-rosa2012.1.noarch
(due to unsatisfied drakxtools >= 10-34.2mdk)
ldetect-0.12.6-2-rosa2012.1.x86_64
(due to missing libldetect.so.0.12()(64bit))
lib64ldetect0.12-0.12.6-2-rosa2012.1.x86_64
(due to missing pciids)
libdrakx-net-1.1-4-rosa2012.1.noarch
(due to unsatisfied drakxtools-backend >= 12.36,
mdkonline-2.77.27-1-rosa2012.1.noarch
(due to unsatisfied rpmdrake >= 5.11.1,
due to missing perl(Rpmdrake::open_db))
memtest86+-4.20-2-rosa2012.1.x86_64
(due to missing drakxtools-backend)
networkmanager-openvpn-0.9.8.0-1-rosa2012.1.x86_64
(due to unsatisfied gtk+3 >= 3.0)
networkmanager-pptp-0.9.8.0-2-rosa2012.1.x86_64
networkmanager-vpnc-0.9.8.0-1-rosa2012.1.x86_64
(due to missing gtk+3)
pciutils-3.1.10-1-rosa2012.1.x86_64
rpmdrake-5.26.12-33-rosa2012.1.noarch
(due to unsatisfied drakxtools >= 12.64)
sound-scripts-0.62-5-rosa2012.1.noarch
(due to unsatisfied alsa-utils >= 1.0.25)
userdrake-1.13.2-8-rosa2012.1.x86_64
(due to missing drakxtools)
When pressing "Yes" I get
Cannot Select писал(а):The following packages cannot be installed because they depend on packages that are older than the installed ones:
- lib64python-devel-2.7.3-6
- python-distribute-0.6.45-11
I also cannot install any of the remaining packages, which are mostly firefox, thunderbird, gtk2/gtk3 and linux-firmware by picking them alone due to some dependency issues on each package...
I don't know how to approach that...
akdengi
Сообщение akdengi »
Please check media enable.
And for update process temporaty disable all 32-bit medai (they need only for steam and skype).
Nitro3k
Сообщение Nitro3k »
Hi akdengi,
Could you explain please how to do that? Sorry, I'm not too experienced with linux.
I have no steam or skype and need neither. What should I disable and how to do that?
