PieDock is a task bar and application launcher in shape of a pie menu. It feels a little bit like the famous OS X dock in a circle. Homepage:
http://markusfisch.de/
PieDock - installation and configuration for ROSA Fresh Mate 32 bit or 64 bit.
1
Install the terminal, the following packages:
64-bit systems users install a package called:lib64png0
2
Log off and log (option required)
3
Full automatic install or update:
The user's home directory, create a new folder, eg: Programs, then enter it and when you press the right mouse button, from the context menu select "Open in terminal".
Then, paste the following command ( necessarily as a regular user):
curl piedock.markusfisch.de/install.sh | sh
When the installation is successful, the message appears:
"Congratulations! PieDock was successfully installed!
You may use one of the following combinations to make the menu
appear:
Shift + scroll wheel up
Shift + scroll wheel down
To fine-tune the experience, check out the configuration file at
/home/daro7/.piedockrc
You may now erase this directory."
And in the "Programs" will be a directory called "piodock-1.6.6"
4
PieDock we need to add to autostart:
Control Center -> Startup Programs -> Add
subsequently, we must provide the location of a file named "piedock" which is located in a folder named "piedock-1.6.6".
Without this, the system is restarted ROSA, does not work - option:
5
Configuration menu PioDock
Menu Piddock, we can change through, edit the file named ".piedockrc"
Home directory -> View -> Show hidden files -> .piedockrc
Clipping a text file before editing.
# end
# end
menu
end
menu window-control
- icon close "piedockutils -c "
icon iconify "piedockutils -i "
icon fullscreen "piedockutils -f "
icon lower "piedockutils -o "
icon stick "piedockutils -s "
icon shade "piedockutils -d "
end
# preload icons
# usage: preload [(menus|all|none)]
# NOTE: you really shouldn't choose "all" when using /usr/share/* icon paths!
preload menus
Slice text file after editing.
# end
# end
menu
- icon libreoffice
icon rosa_media_player rosa-media-player
icon lisek firefox
icon gogle_chrome /usr/bin/google-chrome-stable
icon radio_na_pasku radiotray
icon pobieranie_z_youtube youtube-dl-gui
icon edytor_tekstu_pulma pluma
end
menu window-control
end
# preload icons
preload menus
Description
Before closing the text editor pulm, save the changes. After logging out and logging in, the changes will be visible in the menu PioDock.
