[4 septembre 2013] Update Kernel 3.10.9 et Firefox 23.0.1
sylvainsjc
Operating system: ROSA Linux
Сообщение sylvainsjc »
Salut à tous,
Update ce matin du kernel de Rosa Fresh. On passe de 3.8.12 à 3.10.9
Mise à jour également pour Firefox de 23.0 à 23.0.1
sylvainsjc
Re: [4 septembre 2013] Update Kernel 3.10.9 et Firefox 23.0.1
Mise à jour terminée, redémarrage sans problèmes :good:
[root@Rosa2012Fresh ~]# inxi -F
System:    Host: Rosa2012Fresh Kernel: 3.10.9-nrj-desktop-1rosa x86_64 (64 bit)
           Desktop: KDE 4.10.5 Distro: RosaDesktop.Fresh 2012.1 belka
Machine:   Mobo: ASRock model: N68C-S UCC Bios: American Megatrends version: P1.60 date: 09/19/2011
CPU:       Triple core AMD Athlon II X3 460 (-MCP-) cache: 1536 KB flags: (lm nx sse sse2 sse3 sse4a svm)
           Clock Speeds: 1: 800.00 MHz 2: 800.00 MHz 3: 800.00 MHz
Graphics:  Card: NVIDIA G94 [GeForce 9600 GT] X.org: 1.13.4 drivers: nvidia,v4l tty size: 164x51 Advanced Data: N/A for root
Audio:     Card: NVIDIA MCP61 High Definition Audio driver: snd_hda_intel Sound: ALSA ver: k3.10.9-nrj-desktop-1rosa
Network:   Card: NVIDIA MCP61 Ethernet driver: forcedeth
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: bc:5f:f4:07:a7:84
Drives:    HDD Total Size: 1064.2GB (31.4% used) 1: id: /dev/sda model: KINGSTON_SV100S2 size: 64.0GB
           2: id: /dev/sdb model: WDC_WD10EALX size: 1000.2GB
Partition: ID: / size: 20G used: 15G (82%) fs: ext4 ID: swap-1 size: 9.30GB used: 0.00GB (0%) fs: swap
RAID:      No RAID devices detected - /proc/mdstat and md_mod kernel raid module present
Sensors:   System Temperatures: cpu: 34.0C mobo: 31.0C gpu: 39C
           Fan Speeds (in rpm): cpu: 3183 fan-1: 0 fan-3: 0 fan-4: 0 fan-5: 0
Info:      Processes: 172 Uptime: 3 min Memory: 992.2/7987.4MB Client: Shell (bash) inxi: 1.9.12
Par contre il manque le paquet fr pour Firefox 23.0.1 pour le moment :pardon:
Bernard_rd
Operating system: RosaDesktopFresh 2016.1 Fresh for x86_64, seven et XP dans virtualbox
System exploitation sur SSD 128 Go, Home sur partition DD 1To
Сообщение Bernard_rd »
Je confirme !
Le paquet fr pour firefox 23.0.1 à jour également
Je suis vraiment content de cette distribution, je retrouve la stabilité de la mandriva 10.2
System:    Host: bernard_64 Kernel: 3.10.9-nrj-desktop-1rosa x86_64 (64 bit)
           Desktop KDE 4.10.5 Distro: RosaDesktop.Fresh 2012.1 belka
Machine:   Mobo: Gigabyte model: GA-970A-DS3 Bios: Award version: F3 date: 07/09/2012
CPU:       Hexa core AMD FX-6100 Six-Core (-MCP-) cache: 12288 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm)
           Clock Speeds: 1: 1400.00 MHz 2: 1400.00 MHz 3: 1400.00 MHz 4: 1400.00 MHz 5: 1400.00 MHz 6: 1400.00 MHz
Graphics:  Card: Advanced Micro Devices [AMD] nee ATI Caicos [Radeon HD 6450]
           X.Org: 1.13.4 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1280x1024@60.0hz
           GLX Renderer: Gallium 0.4 on AMD CAICOS GLX Version: 3.0 Mesa 9.0.1
Audio:     Card-1: Advanced Micro Devices [AMD] nee ATI Caicos HDMI Audio [Radeon HD 6400 Series] driver: snd_hda_intel
           Card-2: Advanced Micro Devices [AMD] nee ATI SBx00 Azalia (Intel HDA) driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture ver: k3.10.9-nrj-desktop-1rosa
Network:   Card: Realtek RTL8111/8168B PCI Express Gigabit Ethernet controller driver: r8169
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 90:2b:34:9b:3f:76
Drives:    HDD Total Size: 1128.2GB (45.8% used) 1: /dev/sda M4 128.0GB
           2: /dev/sdb WDC_WD1002FAEX 1000.2GB
Partition: ID: / size: 78G used: 12G (16%) fs: rootfs ID: / size: 78G used: 12G (16%) fs: ext4
           ID: /home size: 243G used: 117G (49%) fs: ext4 ID: swap-1 size: 27.01GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 22.2C mobo: N/A gpu: 50.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 216 Uptime: 2 min Memory: 959.3/32161.3MB Client: Shell inxi: 1.7.24
Kernel: 4.9.155-nrj-desktop-1rosa-x86_64 x86_64 bits KDE 4.14.37 RosaDesktopFresh 2016.1
Hexa core AMD FX-6100 AMD/ATI [Radeon HD 6450/7450/8450]
/dev/sda M4 size: 128.0GB /dev/sdb WDC_WD1002FAEX size: 1000.2GB Memory: 16003.3MB
sylvainsjc
Merci et bienvenue à toi Bernard ;)
D27
Сообщение D27 »
Salut,
Etonné de ne pas voir arriver cette MàJ, je jette un oeil dans mes dépôts, et... tiens(?!...) "main-updates" est décoché (?)... Première fois que ça arrive chez moi (32)...
Bref, MàJ du kernel effectuée sans PB (=> pour Firefox, j'utilise depuis longtemps, celui du site Mozilla directement, et j'étais déjà en 23.0.1 depuis quelques jours).
Remarques ;
1- Fana d'avoir depuis l'allumage du PC, jusqu'à mon bureau, le même fond d'écran, je n'avais pas réussi à faire changer celui du tout premier démarrage (fond bleu Rosa avec les trainées bleues tournantes) malgré les changements d'images dans Plymouth et partout ailleurs. => Avec le changement de noyau, mon fond perso a directement été pris en compte, sans nouvelle intervention de ma part.
Supposition ; Il y a un fichier de config lié au boot noyau, qui doit conserver les paramètres initiaux (donc les fonds d'écran originaux), pour éviter d'aller les chercher à chaque démarrage PC, dans le dossier où ils se trouvent. => Avec le nouveau noyau, à l'initialisation, ce fichier doit se reconfigurer, et prend en compte les images du fichier (que j'avais changées)...
J'ai donc effectivement maintenant, un seul fond d'écran, depuis Grub jusqu'au bureau final (KDE).
Le tout est parfaitement fluide à l'exception d'un bref écran noir (1 sec. ou 2) entre la fin du chargement du noyau et l'écran de connexion.
Les icônes de démarrage de KDE apparaissent parfaitement sur mon image peso, avec un fondu aussi parfait qu'avec l'écran par défaut KDE.
2. Avec le changement de noyau, j'ai aussi le grub personnalisé que j'avais concocté (suppression des lignes "d'option avancées" des différentes distributions existant sur mon PC) qui a été changé, et ces lignes apparaissent donc à présent.
Je trouve étrange que sans MàJ du Grub, celui-ci soit changé... Probablement le même fichier de config (Dracut ou Plymouth ou initramfs ?) dont je parlais plus haut pour les fonds d'écran, qui récapitule les différents éléments, pour gagner du temps de boot (?)...
3. J'ai toujours le problème de ne pas pouvoir mettre mon PC à l'heure par NTP.
Le service NTPD est effectivement installé et coché, mais il n'y a pas moyen d'obtenir la connexion avec aucun des serveurs de temps.
=> Ce petit problème reste donc le seul ennui (mineur) que j'ai avec Fresh...
A+ et, bienvenu à Bernard
Bernard_rd
Merci et bonjour à tous.
Finalement et contrairement à mon post précédent j'ai bien quelques soucis après la mise a jour.
Ma machine refuse de s'arrêter, ce qu'elle faisait sans problème avant.
elle s'arrête à la ligne [ OK ] Stopped D-Bus System Message Bus
puis il ne se passe plus rien même si j'appuie sur une touche quelconque (j'ai attendu plus de cinq minutes).
Si je fais CTRL-HALT-Supp, la liste continue, se termine puis la machine reboot.
Je vois bien un [ FAIL ] écrit en rouge, mais ma machine va trop vite et je ne peux pas lire le texte.
J'ai recopié ci-après les quelques dernières lignes au moment de l'arrêt.
[ OK ] Started Show Plymouth Power Off Screen
[ OK ] Stopped Permit User Sessions
[ OK ] Stopped LSB: A poxerful remplacement for inetd
[ OK ] Stopped LSB: Start the rpcbind daemon
[ OK ] Stopped LSB: Samba servers (nmbd and smbd)
[ OK ] Stopped WPA Supplicant daemon
[ OK ] Stopped Shorewall IPv4 firewall
[ OK ] Stopped target Network
La solution provisoire que j'ai adopté pour arrêter la machine consiste à "mettre en veille en mémoire" ( la machine s'arrête bien), puis de couper le secteur.
Je ne sais pas quel log lire qui pourrait faire avancer le schmilblic.
sylvainsjc
Salut,
Peux tu essayer de démarrer sur l'ancien Kernel 3.8.12 que tu trouveras dans les options avancées du Grub puis nous dire si le problème est toujours présent ?
Bernard_rd
Après redémarrage sur le noyau 3-8-12, la machine s'arrête normalement.
deux choses ont changé après retour sur le noyau 3-10-9 maintenant l'arrêt ne se fait plus sur la ligne
l'ordre des lignes à changé et l'arrêt se fait sur la ligne [ OK ] Stopped target Network
Si je fais CTRL-ALT-Supp à ce stade la machine termine son cycle, s'éteint et ne reboote plus comme auparavant.
Il est évident que si je démarre toujours sur le noyau 3-8-12 je n'aurais plus le problème, mais j'aime bien comprendre.
Вернуться в «ROSA Desktop»
