How to install catalyst 13.6 beta on rosa
pandev92
Operating system: Rosa Linux and Windows 8
Сообщение pandev92 »
I want to install this drivers because 13.4 have a bug with opengl vsync and 13.8 is so slow and buggy.
Any help?
Thanks :D
pandev92
Re: How to install catalyst 13.6 beta on rosa
the repository have 13.8 driver now.., the problem with 13.8 is the slow xv output, slow performance on flash...etc.
akdengi
Сообщение akdengi »
I may say only "try use upstream and manually install". Before you need delete 13.8 driver. I don't want downgrade driver from my private repo, becouse i build only latest drivers for test.
wget -c www2.ati.com/drivers/beta/amd-driver-installer-catalyst-13-6-beta-x86.x86_64.zip
Вернуться в «Desktop»
