Rosa 12.1 kernel 3.8.12-nrj-desktop-2rosa
The latest release of Bricscad has some tricky dependecies related to pixbuf.
Any attempt to open a file causes a crash
(bricscad:7323): GdkPixbuf-WARNING **: Cannot open pixbuf loader module file '/usr/lib/gdk-pixbuf-2.0/2.10.0/loaders.cache': No such file or directory
This likely means that your installation is broken.
Try running the command
gdk-pixbuf-query-loaders > /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders.cache
to make things work again for the time being.
Segmentation fault (core dumped)
As suggested I ran the command
[brm@rosa v13]$ gdk-pixbuf-query-loaders > /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders.cache
bash: /usr/lib/gdk-pixbuf-2.0/2.10.0/loaders.cache: No such file or directory
The needed files are 64bit while pixbuf wants 32bit
[brm@rosa v13]$ locate loaders.cache
/usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders.cache
I tried to create a link to in /usr/lib - but his did not work
(bricscad:9962): Gtk-WARNING **: Error loading theme icon 'text-x-generic' for stock: Unable to load image-loading module: /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so: /usr/lib64/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so: wrong ELF class: ELFCLASS64
also tried to install gdk-pixbuf-2.0 32bit - but no luck so far - any ideas ?
Bricscad Pixbuf dependency problem
Re: Bricscad Pixbuf dependency problem
This issue has progressed. I was able to do a hack by copy and pasting some libraries from a Fedora vm. Not ideal - but the errors subsided. One of my problems stemmed for a failure to have the necessary 32bit repositories enabled.
Bricscad now starts ok but any attempt to load a dwg file will cause a crash. The developers are working on a fix for this version which is 13.2.1. My earlier version of Bricscad (13.1.19) was working ok.
Rosa Desktop Fresh 2012.1 with updates including KDE 4.11.2
Currently running (Licensed copy) of Bricscad 4.2.13 with 13.200.5-1-rosa2012.1
Everything is working well
Thanks for your contributing!mkbr1 писал(а):Everything is working well
