Update repos frequently disabled
sylvainsjc
Operating system: ROSA Linux
Сообщение sylvainsjc »
Hi,
I don't know why but I find regularly update repos unchecked and therefore no updates.
I check again update repos and some days later, again disabled.
Other french users have reported me the same behavior on their system.
Any idea ?
Re: Update repos frequently disabled
What a version system? (KDE, KDE R1, GNOME, ....)
This issue in GUI? (grpmdrake)
NicCo
Сообщение NicCo »
I confirm the issue, not only in my Fresh, but with the most of Fresh,
the thing happens especially with main/updates and contrib/updates,
but doesn't refuse affecting other xxx/updates, non-free & restricted
it seems not affecting the external repositories like, for example, MIB
I realized that when I want to install a program from MIB and it informs me about
few missing libs that should be from an official /update repo, so I need to enable...
I verified the issue on the previous Fresh and in Fresh R1:
I believe is not related to UI (Kde, Gnome, Lxde), I believe it may be caused
by a bad reading of media info datas when starts a try to update lists.cz
A supposition:
perhaps happens when bad md5sum is found, so the repo become unchecked?
I have noticed too many time, some not justified, md5sum errors on reading...
(Those are caused by curl (better using wget?), by network, or mirror errors?)
This error happens really too frequently, and if you are a newbie user, surely you may think that there are no more updates for ROSA Fresh...
Some suggestion to try (if we want to discover the culprit)?
- We can try experimenting replacing the predefined download manager to wget or to prozilla,
- We can install the repositories in a manual way with add the option to disable md5sum check
- others???
bye, NicCo
sylvainsjc
I'm running KDE R1
Below is what I see currently when I launch "urpmi --auto-update"
[root@Rosa2012Fresh ~]# urpmi --auto-update
le média « main (distrib1) » est à jour
    http://mirror.rosalab.ru/rosa2012.1/repository/x86_64/media/main/updates/media_info/synthesis.hdlist.cz
échec de la récupération de [http://mirror.rosalab.ru/rosa2012.1/repository/x86_64/media/main/updates/media_info/synthesis.hdlist.cz] (inégalité md5sum)
problème de lecture du fichier de synthèse du média « main updates (distrib2) »
le média « Main32 (distrib3) » est à jour
le média « contrib (distrib5) » est à jour
le média « contrib updates (distrib6) » est à jour
le média « non-free (distrib7) » est à jour
le média « non-free updates (distrib8) » est à jour
le média « Non-free32 (distrib9) » est à jour
le média « Non-free32 Updates (distrib10) » est à jour
le média « restricted (distrib11) » est à jour
le média « restricted updates (distrib12) » est à jour
le média « Restricted32 (distrib13) » est à jour
le média « Resctricted32 Updates (distrib14) » est à jour
Les paquetages sont à jour
if I start again, I no longer error
if I start again, I find again an error
le média « main updates (distrib2) » est à jour
    http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/main/updates/media_info/synthesis.hdlist.cz
échec de la récupération de [http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/main/updates/media_info/synthesis.hdlist.cz] (inégalité md5sum)
problème de lecture du fichier de synthèse du média « Main32 Updates (distrib4) »
    http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/non-free/updates/media_info/synthesis.hdlist.cz
échec de la récupération de [http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/non-free/updates/media_info/synthesis.hdlist.cz] (inégalité md5sum)
problème de lecture du fichier de synthèse du média « Non-free32 Updates (distrib10) »
Following this, I switched to wget a while ago but still the same issue
NicCo
Сообщение NicCo »
We found the culprit and the cause of the issue: MD5SUM (as I suspected since the start)
replacing the download manager from aria to wget seems not helping us really too much...
NicCo писал(а):A supposition:
First verify:
Second verify
NicCo писал(а):
[root@localhost ~]# urpmi.addmedia --update Contrib_32_updates http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/contrib/updates/
viene aggiunto il supporto "Contrib_32_updates"
    http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/contrib/updates/media_info/synthesis.hdlist.cz
acquisizione di [http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/contrib/updates/media_info/synthesis.hdlist.cz] fallita (md5sum non corretta)
problema nel leggere il file synthesis del supporto "Contrib_32_updates"
Now we have a problem in MD5SUM for /contrib/updates and voilà, I can verify that /contrib/updates has been disabled
So, I tried to use the scripts available on MIB, and also with these I continue having problems with /contrib/updates
Workaround:
1>copy the scripts available on MIB to a text editor, 2>add --no-md5sum to each command rows, 3>configure again all your repos
example for ROSA i586
urpmi.addmedia --no-md5sum Main_32_release http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/main/release/
urpmi.addmedia --no-md5sum --update Main_32_updates http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/main/updates/
urpmi.addmedia --no-md5sum Contrib_32_release http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/contrib/release/
urpmi.addmedia --no-md5sum --update Contrib_32_updates http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/contrib/updates/
urpmi.addmedia --no-md5sum NonFree_32_release http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/non-free/release/
urpmi.addmedia --no-md5sum --update NonFree_32_updates http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/non-free/updates/
urpmi.addmedia --no-md5sum Restricted_32_release http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/restricted/release/
urpmi.addmedia --no-md5sum --update Restricted_32_updates http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/restricted/updates/
urpmi.addmedia --no-md5sum --update MIB-basic_32 http://mib.pianetalinux.org/MIB/rosa2012.1/32/basic/
urpmi.addmedia --no-md5sum --raw --update MIB-experts_32 http://mib.pianetalinux.org/MIB/rosa2012.1/32/experts/
Now is working with /contrib/update enabled and available, and I verified several times that also with a MD5UM error none repos become disabled:
In my opinion:
- the first problem is into mirror MD5SUM creation, something in ABF should check its integrity
- the second is in urpmi predefined behaviour, it's wrong move disabling repo for MD5SUM error
probably using --no-md5sum is not the best and proper solution, but only a bad workarournd,
but, at the moment, I have none other better suggestions...
bye, NicCo
NicCo
Сообщение NicCo »
Since more than one week there is none way to update this ROSA R1 32bit installation:
I uninstalled and reinstalled repository using mirrorlist, but I had a long pause, no error,
then I tried to install using the manual strings from MIB, but after adding /main/release,
it stopped for a neverending time..., and the urpmi gone stalled
[root@localhost ~]# inxi -F
System:    Host: localhost.localdomain Kernel: 3.8.13-nrjQL-desktop-69rosa i686 (32 bit)
           Desktop N/A Distro: RosaDesktop.Fresh 2012.1 belka
Machine:   System: Acer product: TravelMate 4050 version: 290 serial: LXT700508445011649ED00
           Mobo: Acer model: TravelMate 4050 version: A0 serial: LXT700508445011649ED00
           Bios: Acer version: V1.40 date: 11/04/2004
CPU:       Single core Intel Pentium M (-UP-) cache: 2048 KB flags: (nx sse sse2) clocked at 600.00 MHz
Graphics:  Card: Intel 82852/855GM Integrated Graphics Device
           X.org: 1.14.1 drivers: intel (unloaded: fbdev,vesa) tty size: 112x36 Advanced Data: N/A for root
Audio:     Card: Intel 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller driver: snd_intel8x0
           Sound: Advanced Linux Sound Architecture ver: k3.8.13-nrjQL-desktop-69rosa
Network:   Card-1: Realtek RTL-8139/8139C/8139C+ driver: 8139too
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: 00:02:3f:0e:28:48
           Card-2: Intel PRO/Wireless 2200BG [Calexico2] Network Connection driver: ipw2200
           IF: eth1 state: down mac: 00:0e:35:96:78:e3
Drives:    HDD Total Size: 60.0GB (44.6% used) 1: /dev/sda ST960821A 60.0GB
Partition: ID: / size: 12G used: 6.0G (54%) fs: rootfs ID: / size: 12G used: 6.0G (54%) fs: ext4
           ID: /home size: 41G used: 19G (47%) fs: ext4 ID: swap-1 size: 2.42GB used: 0.00GB (0%) fs: swap
Sensors:   Error: You do not have the sensors app installed.
Info:      Processes: 150 Uptime: 27 min Memory: 462.5/2006.3MB Client: Shell inxi: 1.7.24
This morning, before re formatting, I wanted experiment one last attempt:
I modified the string commands adding --no-md5sum --downloader wget
urpmi.removemedia -a
urpmi.addmedia --no-md5sum --downloader wget Main_32_release http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/main/release/
urpmi.addmedia --no-md5sum --downloader wget --update Main_32_updates http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/main/updates/
urpmi.addmedia --no-md5sum --downloader wget Contrib_32_release http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/contrib/release/
urpmi.addmedia --no-md5sum --downloader wget --update Contrib_32_updates http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/contrib/updates/
urpmi.addmedia --no-md5sum --downloader wget NonFree_32_release http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/non-free/release/
urpmi.addmedia --no-md5sum --downloader wget --update NonFree_32_updates http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/non-free/updates/
urpmi.addmedia --no-md5sum --downloader wget Restricted_32_release http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/restricted/release/
urpmi.addmedia --no-md5sum --downloader wget --update Restricted_32_updates http://mirror.rosalab.ru/rosa2012.1/repository/i586/media/restricted/updates/
urpmi.addmedia --no-md5sum --downloader wget --update MIB-basic_32 http://mib.pianetalinux.org/MIB/rosa2012.1/32/basic/
urpmi.addmedia --no-md5sum --downloader wget --raw --update MIB-experts_32 http://mib.pianetalinux.org/MIB/rosa2012.1/32/experts/
All the repositories finally are added, I verified that with drakrpm-edit-media:
right now, I'm updating this PC, now seems that operation is progressing well...
I'll update this msg when the full PC update will be complete.
Bye, NicCo
sylvainsjc
Thanks, I'll try the workaround this evening ;)
sylvainsjc
I use 64 bits ans I have notification this afternoon about KDE 4.10.5 update
I started update via the Software Update Manager but it stop in the middle and I can't finish the update. It always stop after 3 ou 4 packages.
In the console, I have this errors with "inégalité md5sum"
[root@Rosa2012Fresh rosa2012lts-current-x86_64]# urpmi --auto-update
le média « main » est à jour
problème de lecture du fichier de synthèse du média « main updates »
le média « Main32 » est à jour
problème de lecture du fichier de synthèse du média « Main32 Updates »
le média « contrib » est à jour
    http://mirror.rosalab.ru/rosa2012.1/repository/x86_64/media/contrib/updates/media_info/synthesis.hdlist.cz
média « contrib updates » mis à jour
le média « non-free » est à jour
le média « non-free updates » est à jour
le média « Non-free32 » est à jour
le média « Non-free32 Updates » est à jour
le média « restricted » est à jour
le média « restricted updates » est à jour
le média « Restricted32 » est à jour
le média « Restricted32 Updates » est à jour
I've tried several settings like this :
urpmi.addmedia --no-md5sum --downloader wget --distrib --mirrorlist '$MIRRORLIST'
urpmi --no-md5sum --auto-update
But it still the same behavior... Help...
NicCo
Сообщение NicCo »
My test has been done NOT using
I presume that using --distrib --mirrorlist '$MIRRORLIST' then --no-md5sum is ignored at all...
but the tested! FULL CONFIGS available in the MIB , now everything is updated correctly
(it has been tested in two different PCs that before were suffering the issue, 32 and 64bit...)
viking
Operating system: Rosa 2012 x64
KDE 4.8.3
nrj-netbook 3.4.11
Сообщение viking »
Few times i had timeout issues for some of the packages, but never the problems you describe.
Since i am using different repositories then you, I start to think that there might be a problem in mirroring process. :%)
I use those repositories:
urpmi.addmedia Main_64_release http://mirror.rosalinux.com/rosa/rosa2012.1/repository/x86_64/media/main/release/
urpmi.addmedia --update Main_64_updates http://mirror.rosalinux.com/rosa/rosa2012.1/repository/x86_64/media/main/updates/
urpmi.addmedia Contrib_64_release http://mirror.rosalinux.com/rosa/rosa2012.1/repository/x86_64/media/contrib/release/
urpmi.addmedia --update Contrib_64_updates http://mirror.rosalinux.com/rosa/rosa2012.1/repository/x86_64/media/contrib/updates/
urpmi.addmedia NonFree_64_release http://mirror.rosalinux.com/rosa/rosa2012.1/repository/x86_64/media/non-free/release/
urpmi.addmedia --update NonFree_64_updates http://mirror.rosalinux.com/rosa/rosa2012.1/repository/x86_64/media/non-free/updates/
urpmi.addmedia Restricted_64_release http://mirror.rosalinux.com/rosa/rosa2012.1/repository/x86_64/media/restricted/release/
urpmi.addmedia --update Restricted_64_updates http://mirror.rosalinux.com/rosa/rosa2012.1/repository/x86_64/media/restricted/updates/
urpmi.addmedia --raw --update MIB-basic_64 http://mirrors.coreix.net/MIB/rosa2012.1/64/basic/
urpmi.addmedia --raw --update MIB-experts_64 http://mirrors.coreix.net/MIB/rosa2012.1/64/experts/
urpmi.addmedia Main_32_release http://mirror.rosalinux.com/rosa/rosa2012.1/repository/i586/media/main/release/
urpmi.addmedia --update Main_32_updates http://mirror.rosalinux.com/rosa/rosa2012.1/repository/i586/media/main/updates/
urpmi.addmedia Contrib_32_release http://mirror.rosalinux.com/rosa/rosa2012.1/repository/i586/media/contrib/release/
urpmi.addmedia --update Contrib_32_updates http://mirror.rosalinux.com/rosa/rosa2012.1/repository/i586/media/contrib/updates/
urpmi.addmedia NonFree_32_release http://mirror.rosalinux.com/rosa/rosa2012.1/repository/i586/media/non-free/release/
urpmi.addmedia --update NonFree_32_updates http://mirror.rosalinux.com/rosa/rosa2012.1/repository/i586/media/non-free/updates/
urpmi.addmedia Restricted_32_release http://mirror.rosalinux.com/rosa/rosa2012.1/repository/i586/media/restricted/release/
urpmi.addmedia --update Restricted_32_updates http://mirror.rosalinux.com/rosa/rosa2012.1/repository/i586/media/restricted/updates/
urpmi.addmedia --raw --update MIB-basic_32 http://mirrors.coreix.net/MIB/rosa2012.1/32/basic/
sylvainsjc
It's really strange I had this problem on 2 different PC with ROSA (KDE, LXDE) and also in Virtualized ROSA desktop - using aria2 or wget gives the same issue
Below is the debug mode of update on the LXDE laptop, look at this part
    aria2c: (OK):download completed.
    $MIRRORLIST media/main/updates media_info/synthesis.hdlist.cz récupéré
    calcul de la somme de contrôle MD5 du fichier synthesis
[root@rosa ~]# urpmi --auto-update --debug
getting lock on urpmi
parsing: /etc/urpmi/mediacfg.d/rosa2012lts-current-i586
loading mirrors cache
using mirror http://mirror.rosalab.ru/rosa2012.1/repository/i586/
récupération de $MIRRORLIST media/main/release media_info/MD5SUM
'/usr/bin/aria2c' '--log' '/var/cache/urpmi/partial/.aria2.log' '--auto-file-renaming=false' '--ftp-pasv' '--follow-metalink=mem' '--summary-interval=0' '--metalink-enable-unique-protocol=true' '--metalink-preferred-protocol=http' '--max-tries=5' '--lowest-speed-limit=20K' '--timeout' '3' '--metalink-servers=3' '--uri-selector=adaptive' '--server-stat-if=/root/.aria2-adaptive-stats' '--server-stat-of=/root/.aria2-adaptive-stats' '--max-file-not-found=10' '--connect-timeout=6' '-Z' '-j1' '--allow-overwrite=true' '/var/cache/urpmi/.metalink'
aria2c:
aria2c: 2013-07-11 06:41:33.416045 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:33.416298 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:33.493668 NOTICE - ServerStat file /root/.aria2-adaptive-stats loaded successfully.
aria2c:
aria2c: 2013-07-11 06:41:33.697414 NOTICE - Lowering lowest-speed-limit since we have no clue about available speed (now:4096 was:20480)
aria2c:
aria2c: 2013-07-11 06:41:33.698156 NOTICE - Download complete: /var/cache/urpmi/partial/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:33.699554 NOTICE - ServerStat file /root/.aria2-adaptive-stats saved successfully.
aria2c:
aria2c: Download Results:
aria2c: gid|stat|avg speed  |path/URI
aria2c: ===+====+===========+===========================================================
aria2c:   1|  OK| 242.1KiB/s|/var/cache/urpmi/partial/MD5SUM
aria2c:
aria2c: Status Legend:
$MIRRORLIST media/main/release media_info/MD5SUM récupéré
comparaison de /var/cache/urpmi/partial/MD5SUM et de /var/lib/urpmi/MD5SUM.main
récupération de $MIRRORLIST media/main/updates media_info/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:33.738056 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:33.738307 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:33.818087 NOTICE - ServerStat file /root/.aria2-adaptive-stats loaded successfully.
aria2c:
aria2c: 2013-07-11 06:41:33.981054 NOTICE - Lowering lowest-speed-limit since we have no clue about available speed (now:4096 was:20480)
aria2c:
aria2c: 2013-07-11 06:41:33.981991 NOTICE - Download complete: /var/cache/urpmi/partial/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:33.983783 NOTICE - ServerStat file /root/.aria2-adaptive-stats saved successfully.
aria2c:
aria2c:
$MIRRORLIST media/main/updates media_info/MD5SUM récupéré
comparaison de /var/cache/urpmi/partial/MD5SUM et de /var/lib/urpmi/MD5SUM.main updates
récupération du fichier synthesis de « main updates »...
no versioned synthesis.hdlist.cz for medium main updates
récupération de $MIRRORLIST media/main/updates media_info/synthesis.hdlist.cz
aria2c:
    $MIRRORLIST: media/main/updates/media_info/synthesis.hdlist.cz
aria2c: 2013-07-11 06:41:34.023395 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:34.023789 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:34.109932 NOTICE - ServerStat file /root/.aria2-adaptive-stats loaded successfully.
aria2c:
aria2c: 2013-07-11 06:41:34.314256 NOTICE - Lowering lowest-speed-limit since we have no clue about available speed (now:4096 was:20480)
aria2c: [#1 SIZE:288.0KiB/715.8KiB(40%) CN:1 SPD:428.6KiBs]
aria2c:
aria2c: 2013-07-11 06:41:35.266009 NOTICE - Download complete: /var/cache/urpmi/partial/synthesis.hdlist.cz
aria2c:
aria2c: 2013-07-11 06:41:35.266588 NOTICE - ServerStat file /root/.aria2-adaptive-stats saved successfully.
aria2c:
aria2c:   1|  OK| 751.8KiB/s|/var/cache/urpmi/partial/synthesis.hdlist.cz
aria2c:
récupération de $MIRRORLIST media/contrib/release media_info/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:35.300852 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:35.301171 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:35.382958 NOTICE - ServerStat file /root/.aria2-adaptive-stats loaded successfully.
aria2c:
aria2c: 2013-07-11 06:41:35.583759 NOTICE - Lowering lowest-speed-limit since we have no clue about available speed (now:4096 was:20480)
aria2c:
aria2c: 2013-07-11 06:41:35.584385 NOTICE - Download complete: /var/cache/urpmi/partial/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:35.586141 NOTICE - ServerStat file /root/.aria2-adaptive-stats saved successfully.
aria2c:
aria2c:
$MIRRORLIST media/contrib/release media_info/MD5SUM récupéré
comparaison de /var/cache/urpmi/partial/MD5SUM et de /var/lib/urpmi/MD5SUM.contrib
récupération de $MIRRORLIST media/contrib/updates media_info/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:35.614260 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:35.614500 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:35.692196 NOTICE - ServerStat file /root/.aria2-adaptive-stats loaded successfully.
aria2c:
aria2c: 2013-07-11 06:41:35.861998 NOTICE - Lowering lowest-speed-limit since we have no clue about available speed (now:4096 was:20480)
aria2c:
aria2c: 2013-07-11 06:41:35.863063 NOTICE - Download complete: /var/cache/urpmi/partial/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:35.864208 NOTICE - ServerStat file /root/.aria2-adaptive-stats saved successfully.
aria2c:
aria2c:
$MIRRORLIST media/contrib/updates media_info/MD5SUM récupéré
comparaison de /var/cache/urpmi/partial/MD5SUM et de /var/lib/urpmi/MD5SUM.contrib updates
le média « contrib updates » est à jour
récupération de $MIRRORLIST media/non-free/release media_info/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:35.885133 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:35.885370 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:35.963848 NOTICE - ServerStat file /root/.aria2-adaptive-stats loaded successfully.
aria2c:
aria2c: 2013-07-11 06:41:36.167627 NOTICE - Lowering lowest-speed-limit since we have no clue about available speed (now:4096 was:20480)
aria2c:
aria2c: 2013-07-11 06:41:36.168240 NOTICE - Download complete: /var/cache/urpmi/partial/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:36.169687 NOTICE - ServerStat file /root/.aria2-adaptive-stats saved successfully.
aria2c:
aria2c:
$MIRRORLIST media/non-free/release media_info/MD5SUM récupéré
comparaison de /var/cache/urpmi/partial/MD5SUM et de /var/lib/urpmi/MD5SUM.non-free
récupération de $MIRRORLIST media/non-free/updates media_info/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:36.193608 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:36.193849 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:36.273335 NOTICE - ServerStat file /root/.aria2-adaptive-stats loaded successfully.
aria2c:
aria2c: 2013-07-11 06:41:36.476094 NOTICE - Lowering lowest-speed-limit since we have no clue about available speed (now:4096 was:20480)
aria2c:
aria2c: 2013-07-11 06:41:36.476772 NOTICE - Download complete: /var/cache/urpmi/partial/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:36.478487 NOTICE - ServerStat file /root/.aria2-adaptive-stats saved successfully.
aria2c:
aria2c:
$MIRRORLIST media/non-free/updates media_info/MD5SUM récupéré
comparaison de /var/cache/urpmi/partial/MD5SUM et de /var/lib/urpmi/MD5SUM.non-free updates
récupération de $MIRRORLIST media/restricted/release media_info/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:36.500534 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:36.500769 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:36.577666 NOTICE - ServerStat file /root/.aria2-adaptive-stats loaded successfully.
aria2c:
aria2c: 2013-07-11 06:41:36.757770 NOTICE - Lowering lowest-speed-limit since we have no clue about available speed (now:4096 was:20480)
aria2c:
aria2c: 2013-07-11 06:41:36.758386 NOTICE - Download complete: /var/cache/urpmi/partial/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:36.759871 NOTICE - ServerStat file /root/.aria2-adaptive-stats saved successfully.
aria2c:
aria2c:   1|  OK| 121.0KiB/s|/var/cache/urpmi/partial/MD5SUM
aria2c:
$MIRRORLIST media/restricted/release media_info/MD5SUM récupéré
comparaison de /var/cache/urpmi/partial/MD5SUM et de /var/lib/urpmi/MD5SUM.restricted
récupération de $MIRRORLIST media/restricted/updates media_info/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:36.783876 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:36.784112 WARN - --metalink-servers option is deprecated. Use --split option instead.
aria2c:
aria2c: 2013-07-11 06:41:36.863832 NOTICE - ServerStat file /root/.aria2-adaptive-stats loaded successfully.
aria2c:
aria2c: 2013-07-11 06:41:37.068795 NOTICE - Lowering lowest-speed-limit since we have no clue about available speed (now:4096 was:20480)
aria2c:
aria2c: 2013-07-11 06:41:37.069946 NOTICE - Download complete: /var/cache/urpmi/partial/MD5SUM
aria2c:
aria2c: 2013-07-11 06:41:37.071474 NOTICE - ServerStat file /root/.aria2-adaptive-stats saved successfully.
aria2c:
aria2c:
$MIRRORLIST media/restricted/updates media_info/MD5SUM récupéré
comparaison de /var/cache/urpmi/partial/MD5SUM et de /var/lib/urpmi/MD5SUM.restricted updates
examen de la liste de synthèse [/var/lib/urpmi/synthesis.hdlist.main.cz]
examen de la liste de synthèse [/var/lib/urpmi/synthesis.hdlist.contrib.cz]
examen de la liste de synthèse [/var/lib/urpmi/synthesis.hdlist.contrib updates.cz]
examen de la liste de synthèse [/var/lib/urpmi/synthesis.hdlist.non-free.cz]
examen de la liste de synthèse [/var/lib/urpmi/synthesis.hdlist.non-free updates.cz]
examen de la liste de synthèse [/var/lib/urpmi/synthesis.hdlist.restricted.cz]
examen de la liste de synthèse [/var/lib/urpmi/synthesis.hdlist.restricted updates.cz]
effectuerait une installation plutôt qu'une mise à jour de kernel-source-3.6.10-1rosa-1-1-rosa2012.1.noarch
effectuerait une installation plutôt qu'une mise à jour de kernel-nrj-desktop-3.6.10-1rosa-1-1-rosa2012.1.i586
effectuerait une installation plutôt qu'une mise à jour de kernel-doc-3.6.10-1-rosa2012.1.noarch
effectuerait une installation plutôt qu'une mise à jour de kernel-nrj-desktop-devel-3.6.10-1rosa-1-1-rosa2012.1.i586
effectuerait une installation plutôt qu'une mise à jour de kernel-linus-doc-3.4.19-1-rosa2012.1.noarch
effectuerait une installation plutôt qu'une mise à jour de kernel-rt-devel-3.2.34-1.rt51.1-rosa2012.1.i586
effectuerait une installation plutôt qu'une mise à jour de kernel-linus-devel-3.4.19-1rosa-1-1-rosa2012.1.i586
effectuerait une installation plutôt qu'une mise à jour de kernel-rt-3.2.34-1.rt51.1-rosa2012.1.i586
effectuerait une installation plutôt qu'une mise à jour de kernel-linus-source-3.4.19-1rosa-1-1-rosa2012.1.i586
effectuerait une installation plutôt qu'une mise à jour de kernel-linus-3.4.19-1rosa-1-1-rosa2012.1.i586
effectuerait une installation plutôt qu'une mise à jour de kernel-rt-source-3.2.34-1.rt51.1-rosa2012.1.i586
effectuerait une installation plutôt qu'une mise à jour de kernel-rt-debuginfo-3.2.34-1.rt51.1-rosa2012.1.i586
getting exclusive lock on rpm
opening rpmdb (root=, write=)
auto-select: adding libfontconfig1-2.10.93-2plf-plf2012.1.i586 replacing libfontconfig1-2.10.93-1plf-plf2012.1.i586
auto-select: adding fontconfig-2.10.93-2plf-plf2012.1.i586 replacing fontconfig-2.10.93-1plf-plf2012.1.i586
selecting libfontconfig1-2.10.93-2plf-plf2012.1.i586
set_rejected: libfontconfig1-2.10.93-1plf-plf2012.1.i586
requiring libc.so.6,libc.so.6(GLIBC_2.0),libc.so.6(GLIBC_2.1),libc.so.6(GLIBC_2.1.3),libc.so.6(GLIBC_2.2),libc.so.6(GLIBC_2.3.3),libc.so.6(GLIBC_2.3.4),libc.so.6(GLIBC_2.4),libc.so.6(GLIBC_2.7),libpthread.so.0,libpthread.so.0(GLIBC_2.0),libpthread.so.0(GLIBC_2.2) for libfontconfig1-2.10.93-2plf-plf2012.1.i586
chosen glibc-2.15-8-rosa2012.1.i586 for libc.so.6(GLIBC_2.4)
not selecting glibc-2.15-8-rosa2012.1.i586 since the more recent glibc-2.15-8-rosa2012.1.i586 is installed
chosen glibc-2.15-8-rosa2012.1.i586 for libpthread.so.0(GLIBC_2.2)
chosen glibc-2.15-8-rosa2012.1.i586 for libc.so.6(GLIBC_2.1.3)
chosen glibc-2.15-8-rosa2012.1.i586 for libc.so.6(GLIBC_2.3.4)
chosen glibc-2.15-8-rosa2012.1.i586 for libc.so.6(GLIBC_2.1)
chosen glibc-2.15-8-rosa2012.1.i586 for libc.so.6(GLIBC_2.3.3)
chosen glibc-2.15-8-rosa2012.1.i586 for libc.so.6(GLIBC_2.0)
chosen glibc-2.15-8-rosa2012.1.i586 for libpthread.so.0(GLIBC_2.0)
chosen glibc-2.15-8-rosa2012.1.i586 for libc.so.6(GLIBC_2.7)
chosen glibc-2.15-8-rosa2012.1.i586 for libc.so.6(GLIBC_2.2)
selecting fontconfig-2.10.93-2plf-plf2012.1.i586
set_rejected: fontconfig-2.10.93-1plf-plf2012.1.i586
requiring libc.so.6,libc.so.6(GLIBC_2.0),libc.so.6(GLIBC_2.2),libc.so.6(GLIBC_2.3.4),libpthread.so.0,libpthread.so.0(GLIBC_2.0) for fontconfig-2.10.93-2plf-plf2012.1.i586
Le paquetage glibc-2.15-8-rosa2012.1.i586 est déjà installé
glibc is not in potential orphans
Pour satisfaire les dépendances, les paquetages suivants vont être installés :
 Paquetage                      Version      Révision      Dist  DEpoch Arch
(média « restricted updates »)
 fontconfig                     2.10.93      2plf          plf   2012.1 i586
 libfontconfig1                 2.10.93      2plf          plf   2012.1 i586
un espace additionnel de 0o sera utilisé.
189Ko de paquets seront récupérés.
Procéder à l'installation des 2 paquetages ? (O/n)
sylvainsjc
md5sum mismatch :(
It sucks :evil: I'm still having this problem with last updates ??? how to implement a way to find a solution ?
First try with "urpmi --auto-update"
échec de la récupération de [http://mirror.rosalab.ru/rosa2012.1/repository/x86_64/media/contrib/updates/media_info/synthesis.hdlist.cz] (inégalité md5sum)
problème de lecture du fichier de synthèse du média « contrib updates (distrib6) »
I abort and relaunch "urpmi --auto-update"
Third try
    http://mirror.rosalab.ru/rosa2012.1/repository/x86_64/media/non-free/updates/media_info/synthesis.hdlist.cz
échec de la récupération de [http://mirror.rosalab.ru/rosa2012.1/repository/x86_64/media/non-free/updates/media_info/synthesis.hdlist.cz] (inégalité md5sum)
problème de lecture du fichier de synthèse du média « non-free updates (distrib8) »
Full log with debug mode and failure to install updates
urpmi-failure.log
(103.85 КБ) 1020 скачиваний
sylvainsjc
This command launched 20 times never fail
wget http://mirror.rosalab.ru/rosa2012.1/repository/x86_64/media/main/updates/media_info/synthesis.hdlist.cz
sylvainsjc
This evening, I've changed the downloader from wget to curl on the laptop, on the desktop and on the VirtualBox images : all updates installed correctly then...
Look the problem when it happens : https://dl.dropboxusercontent.com/u/471 ... %3A46.webm
Screencast made with Rosa media Player ;)
sylvainsjc
problem is still there :evil:
main update is disable again and I don't know why ???
[root@Rosa2012Fresh ~]# urpmq --list-url
main (distrib1) ftp://mirror.yandex.ru/rosa/rosa2012.1/repository/x86_64/media/main/release
Main32 (distrib3) ftp://mirror.yandex.ru/rosa/rosa2012.1/repository/i586/media/main/release
Main32 Updates (distrib4) ftp://mirror.yandex.ru/rosa/rosa2012.1/repository/i586/media/main/updates
contrib (distrib5) ftp://mirror.yandex.ru/rosa/rosa2012.1/repository/x86_64/media/contrib/release
contrib updates (distrib6) ftp://mirror.yandex.ru/rosa/rosa2012.1/repository/x86_64/media/contrib/updates
non-free (distrib7) ftp://mirror.yandex.ru/rosa/rosa2012.1/repository/x86_64/media/non-free/release
non-free updates (distrib8) ftp://mirror.yandex.ru/rosa/rosa2012.1/repository/x86_64/media/non-free/updates
Non-free32 (distrib9) ftp://mirror.yandex.ru/rosa/rosa2012.1/repository/i586/media/non-free/release
Non-free32 Updates (distrib10) ftp://mirror.yandex.ru/rosa/rosa2012.1/repository/i586/media/non-free/updates
restricted (distrib11) ftp://mirror.yandex.ru/rosa/rosa2012.1/repository/x86_64/media/restricted/release
restricted updates (distrib12) ftp://mirror.yandex.ru/rosa/rosa2012.1/repository/x86_64/media/restricted/updates
Restricted32 (distrib13) ftp://mirror.yandex.ru/rosa/rosa2012.1/repository/i586/media/restricted/release
Restricted32 Updates (distrib14) ftp://mirror.yandex.ru/rosa/rosa2012.1/repository/i586/media/restricted/updates
akdengi
Сообщение akdengi »
We knew about problem, but one solution is only set urpmi.cfg as non-writed or disable mdk-applet. We investigate this problem but it not a simple :(
sylvainsjc
If you need some specifics tests, just ask ;-)
