I installed Pinta by install/remove software but it isnt starting when i clicked on it from welcome menu...
Removed and installed by console, same result...
What you offer me to make it usable?
Thanks.
PS: i cant see Klook in program list when i clicked a pic file right click open with... i tried to install Klook again, it says me it is already installed.... I wanted to see the same as showed here Klook installed, but i cant see.... What you offer for this also?
[solved]Pinta doesnt start
Последний раз редактировалось Majestic 20 авг 2013, 16:14, всего редактировалось 2 раза.
Think twice before giving a decide...
Re: Pinta doesnt start
Klook does not work click the right mouse button. You open Dolphin select multiple files, and press "Space". Then Klook starts.Majestic писал(а):
Thanks for the Klook trick. Do you have any offer for Pinta to work? or do you want to offer me a usefull KDE simple picture editing app?
Kolorpaint, mtPaint, myPaint, Gnome-Paint and etc. All this program there are in repo.
Thank you for alternative program offers.
I removed pinta, it has been using mono so that im not using it anymore....
