BlueGriffon update to v1.7.2?
BlueGriffon keeps reporting that there is a new version v1.7.2.
Is there a chance for an updated rpm package?
Re: BlueGriffon update to v1.7.2?
Surely there's a chance. bluegriffon is not really easy to update but there's nothing impossibleviking писал(а):BlueGriffon keeps reporting that there is a new version v1.7.2.
Looks like version 1.7.2 has serious issues with build. So perhaps it's better to try next version.
At least you tried. Thank you anyway.Pulfer писал(а):Looks like version 1.7.2 has serious issues with build. So perhaps it's better to try next version.
In fact, I couldn't leave it like that and solved all build issuesviking писал(а):At least you tried. Thank you anyway.
Please test 1.7.2:
32: http://abf-downloads.rosalinux.ru/abondrov_personal/container/1175275/i586/main/release/
or
64: http://abf-downloads.rosalinux.ru/abondrov_personal/container/1175276/x86_64/main/release/
Since there is only one file I didn't add repo or downloaded rpm. I simply installed it like this:Pulfer писал(а):In fact, I couldn't leave it like that and solved all build issuesviking писал(а):At least you tried. Thank you anyway.![]()
Please test 1.7.2:
If it works well, I'll push it to official updates.Код: Выделить всё
32: http://abf-downloads.rosalinux.ru/abondrov_personal/container/1175275/i586/main/release/ or 64: http://abf-downloads.rosalinux.ru/abondrov_personal/container/1175276/x86_64/main/release/
[viking@gemstone ~]$ sudo urpmi http://abf-downloads.rosalinux.ru/abondrov_personal/container/1175276/x86_64/main/release/bluegriffon-1.7.2-1-rosa2012.1.x86_64.rpm
I played with wysiwyg, code and svg editor. I used options from menu, from toolbar and keyboard shotcuts. Even tried wizard.
I haven't noticed any problem so far.
Coolviking писал(а):I did some initial tests and it works great!
I made some more tests and found annoying bug with WYSIWYG editor and tables. When you select last cell in table (or maybe even any cell from last row) merge doesn't work.Pulfer писал(а): CoolI'll push 1.7.2 to official updates then.
Same bug is present in Windows version (I checked), so it's not your fault.
You did great job. Thank you.
I guess we should update BlueGriffon to 1.7.3 as soon as it's released then (if it's released at all).viking писал(а):I made some more tests and found annoying bug with WYSIWYG editor and tables. When you select last cell in table (or maybe even any cell from last row) merge doesn't work.
Same bug is present in Windows version (I checked), so it's not your fault.![]()
Looks like this bug is brought to us with a courtesy of mozilla.Pulfer писал(а):I guess we should update BlueGriffon to 1.7.3 as soon as it's released then (if it's released at all).viking писал(а):I made some more tests and found annoying bug with WYSIWYG editor and tables. When you select last cell in table (or maybe even any cell from last row) merge doesn't work.
It is present it SeaMonkey composer too.
