LibreCAD in Rosa 2012.1 64 bit [SOLVED]
Giorgio
Operating system: Rosa 2012.1 64 bit Desktop Fresh
Сообщение Giorgio »
I would install LibreCAD in my Rosa 2012.1 64 bit.
From it's site http://librecad.org/cms/home/installati ... kages.html I downloaded LibreCAD 2.0.0 beta 5 and 3 dependencies: libdxflib, libfparser, libmuparser. All files are in rpm version for Mandriva 2011 64 bit.
I installed first the libraries then LibreCAD but installation return an error asking for libdxfrw.so.0()(64bit). I don't find anything containing "dxfrw" in Install & Remove Software nor in the web.
Rosa 2012.1 Desktop Fresh 64 bit, KDE 4.10.4.
Последний раз редактировалось Giorgio 21 июн 2013, 21:50, всего редактировалось 1 раз.
Re: LibreCAD in Rosa 2012.1 64 bit
Giorgio писал(а):I would install LibreCAD in my Rosa 2012.1 64 bit.
Soon there will be QCAD 3.1 in repositories, perhaps it's better to use it instead of LibreCAD.
Giorgio
Сообщение Giorgio »
I installed Qcad then as soon as Qcad 3.1 will be available I'll try it.
In meantime I opened a bug with a package request asking for libdxfrw.so.0()(64bit).
post edit:
The package libdxfrw is available in LibreCAD site, downloaded and installed it allows LibreCAD installation.
Re: LibreCAD in Rosa 2012.1 64 bit [SOLVED]
Meanwhile LibreCAD 2.0.2 is pushed to Contrib/Updates.
