Systemd moving - step 2. I need you help!
akdengi
Сообщение akdengi »
Hi all. It's me and i again need you help.
Second step of systemd moving in ROSA Fresh will need drop obsoletes in more systemd distros (mageia and fedora done this) consolehelper and policykit.
We don't drop it from repo, but drop it from you system.
What changed:
- obsolete consolekit, policykit and consolekit-x11
- fix accountservice and enable accounts-daemon.service
- fix xinit
- fix python-slip
- fix lightdm to use logind
- fix systemd to use greeter options in pam
- fix lxsession for use logind
What need to test:
- use KDE and Gnome with new implementation.
- some problem with system
- some problem with login/logout
How test - simple add my private repo and update you system. My repo consists stage1 moving package (mode DM to systemd), than after update if you use non-oficial build kde or gnome or another DE, than kdm/gdm you may see black screen.
Don't panic! Simple Ctrl+F2, login as root and than type
systemctl enable kdm.service or systemctl enable gdm.service or you xyzdm.service
Add repo:
i586
urpmi.addmedia akdengi --update http://abf-downloads.rosalinux.ru/akden ... n/release/
x86_64
sylvainsjc
Operating system: ROSA Linux
Re: Systemd moving - step 2. I need you help!
Сообщение sylvainsjc »
Well... Update done on my VirtualBox machine. Restart without problems.
Played with some logout/login and also with configuration system without problems for the moment
