# rpm -qa | grep nspluginwrapper
nspluginwrapper-i386-0.9.90.1-6-rosa2012.1.x86_64
# nspluginwrapper --help
nspluginwrapper: command not found
# urpmi -v nspluginwrapper-1.4.4-1-mdv2012.0.x86_64.rpm nspluginwrapper-i386-1.4.4-1-mdv2012.0.x86_64.rpm
In order to satisfy the 'libnss3.so' dependency, one of the following packages is needed:
1- libnss3-3.14.1-2-rosa2012.1.i586: Network Security Services (NSS) (to install)
2- bluegriffon-1.6.2-3-rosa2012.1.i586: The next-generation Web Editor (to install)
What is your choice? (1-2) 1
In order to satisfy the 'libplc4.so' dependency, one of the following packages is needed:
1- libnspr4-4.9.4-1-rosa2012.1.i586: Netscape Portable Runtime (to install)
Package Version Release Dist DEpoch Arch
(medium "main")
libblkid1 2.22 3 rosa 2012.1 i586 (suggested)
libext2fs2 1.42.5 1 rosa 2012.1 i586 (suggested)
libgssapi_krb5_2 1.10.3 4 rosa 2012.1 i586 (suggested)
libk5crypto3 1.10.3 4 rosa 2012.1 i586 (suggested)
libkeyutils1 1.2 13 rosa 2012.1 i586 (suggested)
libkrb5_3 1.10.3 4 rosa 2012.1 i586 (suggested)
libkrb5support0 1.10.3 4 rosa 2012.1 i586 (suggested)
libldap2.4_2 2.4.33 1 rosa 2012.1 i586 (suggested)
libopenssl1.0.0 1.0.1c 1 rosa 2012.1 i586 (suggested)
libuuid1 2.22 3 rosa 2012.1 i586 (suggested)
(medium "main updates")
libcurl4 7.29.0 1 rosa 2012.1 i586 (suggested)
libnspr4 4.9.4 1 rosa 2012.1 i586 (suggested)
libnss3 3.14.1 2 rosa 2012.1 i586 (suggested)
libsasl2 2.1.25 6 rosa 2012.1 i586 (suggested)
libssh2_1 1.4.3 1 rosa 2012.1 i586 (suggested)
(command line)
nspluginwrapper 1.4.4 1 mdv 2012.0 x86_64
nspluginwrapper-i386 1.4.4 1 mdv 2012.0 x86_64
8.9MB of additional disk space will be used.
6.3MB of packages will be retrieved.
Proceed with the installation of the 17 packages? (Y/n) Y
# nspluginwrapper -i /opt/Adobe/Reader9/Browser/intellinux/nppdf.so
