Hi,
I'm a user of Mandriva 2011 and I want to use Rosa Marathon 2012 now. In my Mandriva configuration I replaced some of the Rosa addons, one of them is the Rocketbar. I want to use a default panel instead of the Rocketbar but I can only add a panel (the black one) on the top, left or right side of the screen. If I try to add it to the bottom of the screen it automatically changes to a panel with the same look of the Rocketbar (the light blue one). How can I have the default panel (dark one) at the bottom of the screen?
Thanks
Esteban
Costa Rica
Replace the Rocketbar with a panel
esteban1972
Re: Replace the Rocketbar with a panel
Just use another plasma theme.esteban1972 писал(а):Hi,
Thanks
Esteban
Costa Rica
