Install
ragwing
Operating system: Rosa Destkop 2012
Install
Сообщение ragwing »
I want to install PHP, MySql and Apache2. I have downloaded them to my Downloads directory. How do I install them. There is no package for them that I can find.
How do I login as root from a terminal? So I can configure, make and make install them.
Re: Install
ragwing писал(а):How do I login as root from a terminal?
Tell me you're joking. You said you were using Linux previously in your life... :shock:
tuxcore82
Operating system: Rosa Linux Fresh 2012 x86_64, Fedora 17 x86_64
Re: Install
Сообщение tuxcore82 »
In Konsole type:
su -
After you press enter, you will be prompted for your root password.
Вернуться в «Desktop»
