acrobat reader
manturbo
Operating system: ROSA Desktop Fresh 2012
acrobat reader
Сообщение manturbo »
How I get the acrobat reader installed on my x64 Desktop Fresh 2012 with normal font
benbullard79
Operating system: ROSA Fresh R5
OpenMandriva Lx 2014.1
openSuSE 13.2
Re: acrobat reader
Сообщение benbullard79 »
manturbo писал(а):How I get the acrobat reader installed on my x64 Desktop Fresh 2012 with normal font
I don't know:
http://forum.rosalab.ru/en/viewtopic.php?f=34&t=1019
unless it's a package that isn't available in some countries due to legal reasons?
The .rpm from:
https://get.adobe.com/reader/otherversions/
will install in Fresh/2012.1 x86_64 with 'add32to64media' installed but it won't open.
(acroread:27088): Pango-CRITICAL **: No modules found:
No builtin or dynamically loaded modules were found.
PangoFc will not work correctly.
This probably means there was an error in the creation of:
  '/etc/pango/i386/pango.modules'
You should create this file by running:
  pango-querymodules > '/etc/pango/i386/pango.modules'
Fontconfig warning: "/etc/fonts/conf.d/50-user.conf", line 9: reading configurations from ~/.fonts.conf is deprecated.
[dwight@localhost ~]$ pango-querymodules > '/etc/pango/i386/pango.modules'
bash: /etc/pango/i386/pango.modules: No such file or directory
[dwight@localhost ~]$ sudo pango-querymodules > '/etc/pango/i386/pango.modules'
# pango-querymodules > '/etc/pango/i386/pango.modules'
It may be missing a dependent pango or libpango package.
Thanks,
Ben Bullard
Вернуться в «Desktop»
