Spotify on Rosa
MitraMai
Operating system: Rosa fresh
Spotify on Rosa
Сообщение MitraMai »
Hello
Has anyone been able to install the official Spotify-client on Rosa Fresh? I know there is inofficial .rpm-packages for Fedora (converted with alien) and that some have installed it on Mageia. I'm new to Mandriva-based distros so I guess I could use some help.
dareksmok
i5-4570 CPU @ 3.20GHz
NVIDIA GeForce GT 1030
8 GB RAM
Re: Spotify on Rosa
Сообщение dareksmok »
1 # install " libopenssl0"
urpmi libopenssl0
2 # install "spotify-client-qt-0.6.2.291-1pclos2011.i586.rpm".( Caution! version PC linux )
More on: http://chomikuj.pl/pogoda/Linux/Rosa/Multimedia/Spotify
The web site translation, I recommend add-on for firefox: https://addons.mozilla.org/en-US/firefo ... b-dl-users
Последний раз редактировалось dareksmok 29 июн 2013, 22:20, всего редактировалось 2 раза.
ROSA Fresh R10 MATE - 64 bit
dareksmok
8 GB RAM
Re: Spotify on Rosa
The Spotify, it works fine on Wine 1.4 - under certain conditions.
1 - Requires package (wine-gecko HTML), the package will be "downloaded from the Internet" by the wine, when you first start the program.
2 - wine configuration is required, so open the terminal as a normal user and type.
winecfg
After opening the configuration dialog in the "Audio" at each position change settings - "Default System" - to another.
This may be the first item in the list, otherwise if you do not do Spotyfy sound will be distorted.
3 - To make sure you can still change the settings in the "Applications".
Add applications-> userus-> username-> Application Data-> Spotify-> spotify.exe
subsequently assign the operating system to the program and at the end save all changes by pressing the "Apply" button.
In short, the program works very decently.
