Проблемы експорта по NFS
bas
Сообщение bas »
Учитель
exports
# /etc/exports: the access control list for filesystems which may be exported
# to NFS clients. See exports(5).
/home/school/teacher *(no_all_squash,async,secure,no_subtree_check,ro)
/home/school/pupils *(no_all_squash,async,secure,no_subtree_check,rw)
/home/school/my00 *(no_all_squash,async,secure,no_subtree_check,rw)
/home/school/my01 *(no_all_squash,async,secure,no_subtree_check,rw)
/home/school/my02 *(no_all_squash,async,secure,no_subtree_check,rw)
/home/school/my03 *(no_all_squash,async,secure,no_subtree_check,rw)
/home/school/my04 *(no_all_squash,async,secure,no_subtree_check,rw)
/home/school/my05 *(no_all_squash,async,secure,no_subtree_check,rw)
/home/school/my06 *(no_all_squash,async,secure,no_subtree_check,rw)
/home/school/my07 *(no_all_squash,async,secure,no_subtree_check,rw)
/home/school/my08 *(no_all_squash,async,secure,no_subtree_check,rw)
/home/school/my09 *(no_all_squash,async,secure,no_subtree_check,rw)
/home/school/my10 *(no_all_squash,async,secure,no_subtree_check,rw)
Ученик
auto.mnt
pupils -rw,soft,intr,rsize=8192,wsize=8192 10.32.59.226:/home/school/pupils
teacher -ro,soft,intr,rsize=8192,wsize=8192 10.32.59.226:/home/school/teacher
my -rw,soft,intr,rsize=8192,wsize=8192 10.32.59.226:/home/school/my10
auto.master
# Sample auto.master file
# This is an automounter map and it has the following format
# key [ -mount-options-separated-by-comma ] location
# For details of the format look at autofs(5).
#/misc /etc/auto.misc
# NOTE: mounts done from a hosts map will be mounted with the
# "nosuid" and "nodev" options unless the "suid" and "dev"
# options are explicitly given.
#/net -hosts
# Include /etc/auto.master.d/*.autofs
+dir:/etc/auto.master.d
# Include central master map if it can be found using
# nsswitch sources.
# Note that if there are entries for /net or /misc (as
# above) in the included master map any keys that are the
# same will not be seen as the first read key seen takes
# precedence.
+auto.master
/school /etc/autofs/auto.mnt --timeout 60
1)Папки в /home/school/ есть и со значком глобуса, но доступа к ним не было даже после перезагрузки. В 2011 залазил для этого в Центр управления Mandriva – Сетевые службы — Предоставление общего доступа к файлам и каталогам с помощью NFS. Теперь эту штуку не нашел... Спасло из консоли systemctl restart nfs-server.service, но почему не спасала просто перезагрузка? Кстати, а как теперь доступ в графике делать по nfs?
2)Дальше все равно проблема - на всех папках (которые прописаны в export и в autofs у учеников) владелец root, все права на запись стоят (просмотр и изменение содержимого - все 3 списка). НО записать файл ученик в pupils не может - пишет проверьте наличие прав. Почему?
Re: Проблемы експорта по NFS
bas писал(а): все права на запись стоят (просмотр и изменение содержимого - все 3 списка). НО записать файл ученик в pupils не может - пишет проверьте наличие прав. Почему?
Та же проблема, включая http://forum.rosalab.ru/viewtopic.php?f=39&t=1507
akdengi
Сообщение akdengi »
nfs://
Утилиты ВСЕ ДОСТУПНЫ...
/usr/sbin/draknfs
Ну или ставим gigolo
bas
Сообщение bas »
akdengi писал(а):nfs://
Не понял про что это вы.
akdengi писал(а):nНу или ставим gigolo
Гугл только музыкальную группу выдал :( что и как надо делать?
akdengi
Сообщение akdengi »
В строке URL набираете nfs://адрес и получаете доступ (как и smb:// mtp:// или file://)
urpmi gigolo трудно сделать?
bas
Сообщение bas »
на учительском компе форефокс на nfs:// выдал чего-то не то, нет страницы что-ли (не помню)
сделать не трудно, а что это даст и что надо делать дальше?
bas писал(а):>>urpmi gigolo трудно сделать?
http://bit.ly/WMOhC6
bas
Сообщение bas »
Редиска, вы Юля.
Как я вычитал это отдельная программа и подключаемся, щелкаем на иконке подключения и работаем с удаленным ресурсом как с обычной директорией...
А надо чтобы открыл dolphin и никуда не подключаясь открыл папку, а она общая...
В 2011 еду все работало. А тут нет доступа... :(
Ну это Саше Казанцеву на лысину капать надо, как творцу Еду-Мадривы. Но если уж он сам сказал про Жиголо, то вряд ли хочет копаться до собаки... :(
bas писал(а):dolphin и никуда не подключаясь открыл
Он на самом деле подключается, это и ребёнку же понятно. :-P но сказали к терапевту, значит -- к терапевту, т.е. Жиголо.
А вы настраивали не через system-config-nfs?
Я дома через неё настраивал, так вроде ни одной проблемы не вылезло.
bas
Сообщение bas »
system-config-nfs что-то много ругался на параметры которые делал он же только в 2011...
сделал им - он оставил только *(sync,rw) если не ошибаюсь...
Вопрос - копирую файлы и папки в общую папку, а у них нет прав для других, т.е. по сети они не открываются, надо руками следом ставить права. Как это изменить?
bas
Сообщение bas »
УУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУУ!!!!
Скопировал файл export на флешку. Восстановил систему из образа.
Вернул export, создал нужные каталоги (они с глобусами), поставил system-config-nfs, он все записи видит. НО не фига теперь не работает...
Что еще может быть???? Все было также но уже работало (правда, с правами были проблемы)...
bas
Сообщение bas »
[root@pc00 pupil]# systemctl restart nfs-server.service
Job for nfs-server.service failed. See 'systemctl status nfs-server.service' and 'journalctl' for details.
[root@pc00 pupil]#
хотел перезапустить сервер nfs (как делал в м2011), что он мне выдал?
bas
Сообщение bas »
/etc/export (на 10.32.59.226):
/school/teacher *(ro,sync)
/school/pupils *(rw,sync)
Каталоги существуют...
на 10.32.59.230:
[root@pc10 pupil]# mount 10.32.59.226:/school/teacher /home/pupil/123
mount.nfs: Connection timed out
[root@pc10 pupil]# ping 10.32.59.226
PING 10.32.59.226 (10.32.59.226) 56(84) bytes of data.
64 bytes from 10.32.59.226: icmp_req=1 ttl=64 time=0.435 ms
64 bytes from 10.32.59.226: icmp_req=2 ttl=64 time=0.256 ms
64 bytes from 10.32.59.226: icmp_req=3 ttl=64 time=0.283 ms
Вообще сервер nfs ни черта работать не хочет... :evil: =@ =@ =@ =@ =@ =@ =@ =@
bas
Сообщение bas »
/usr/sbin/draknfs
и
system-config-nfs
создают разные конфиги....
Помучался с /usr/sbin/draknfs вроде бы что-то заработало, но в параметрах экспотра если разрешено писать, на папке разрешено всем, в параметрах импорта разрешено писать - в эту экспортируемую/импортируемую папку писать нельзя, только в подпапку...
