very slow repos
English-speaking forum for talkers =)
netean
Operating system: Now fully Linux. (Kubuntu), Linux Mint (KDE) Koraraa 17 (Fedora KDE based) and... when I can get grub to work.. soon to be a 32bit and 64bit (and very happy) Rosa user
very slow repos
Сообщение netean »
Is it just me?
I'm finding that trying to update, install or just access the mirror list of repositories is incredibly slow.. 5-10Kbs a second for example?
For me, it's been like this for the past few days - just accessing the repositories from the package manager, generally internet and browsing is absolutely fine (4Gbps). Not just one computer either, problem seems to be with all my Rosa 2012.1 installs.
I've tried removed the repo list and re-adding.. (tried several times) and still the same
I'm in the UK and using BT broadband, anyone else in the UK seeing anything similar, or it is just me?
netean
Re: very slow repos
Сообщение netean »
ok.. maybe it is just me.. speed back tonormal again..
must be going mad!
Re: very slow repos
The next time check in the console: traceroute mirror.rosalab.ru
There will immediately see which node you have a "failure."
lisa
Re: very slow repos
Сообщение lisa »
Hi netean,
It's always slow for me due to dial-up, but recently I switched the following setting in Control Centre>Software Management>Configure Media Sources...>Options>Global Options>Download program to use> and switched from default 'curl' to 'wget'. I use wvdial dial-up utility and now I do not get disconnected so much (seemed like I would get disconnected about every 20 minutes, but this varied).
Lisa Marie
Вернуться в «Off the wall»
