I think install Rosa 2012 in my computer but i have a ATI Radeon graphic card on it. This may be a problem?? Which type of graphic card is better to run correctly ROSA?
Thankyou very much
Rosa 2012 and ATI
Re: Rosa 2012 and ATI
Proprietary will be avalible only for ATI/AMD > HD5xxx
For all other catd using free ati driver
And if it's not support you card only vesa drivet (thas will be many troubles).
javierperez35
i have download the file
how can i install propietary driver? please what is the way step by step.
thankyou
thankyou
You need Internet enabled.
1. Enable non-free repo
2. Run XFdrake
3. Upper button - yes-yes-yes (NOT PRESS TEST!)
4. Reboot
5. Profit
2. Run XFdrake
4. Reboot
5. Profit
I have AMD Radeon HD 4350 but no proprietary driver support. Too bad because need it to play games on steam.
Pentium Dual Core E5400 4GB Ram Asus R7 240 2GB DDR3 Rosa Desktop Fresh R7 64bit
AMD droped ALL proprietary driver support for all card < HD5xxx We cannot help you.
