Problems with urpm-reposync
Hello,
I'm very satisfied by Rosa Marathon 2012.0, I've upgraded it from Mandriva 2011.0 following the guide but, reached to the command urpm-reposync it returns this error:
File "/usr/bin/urpm-reposync", line 1221, in <module>
Main()
File "/usr/bin/urpm-reposync", line 1132, in Main
install_packages()
File "/usr/bin/urpm-reposync", line 817, in install_packages
h = readRpmHeader(ts, f)
File "/usr/bin/urpm-reposync", line 801, in readRpmHeader
h = ts.hdrFromFdno(fd)
_rpm.error: error reading package header
what means??? However the system works well...
Main()
install_packages()
Re: Problems with urpm-reposync
I've tried to re-start the command and now the error is:
There are some unresolved dependencies:
(('kernel-nrjQL-laptop-3.6.6-69rosa.lts', '1', '1'), ('microcode', '0.20120313-1'), 12, None, 0)
Package kernel-nrjQL-laptop-3.6.6-69rosa.lts-1-1 requires microcode[!= 0.20120313-1]
(('mandriva-kde4-config-common', '2012', '7'), ('mandriva-theme-screensaver', None), 0, None, 0)
Package mandriva-kde4-config-common-2012-7 requires mandriva-theme-screensaver
(('one-kde4-config', '2012', '7'), ('mandriva-theme', None), 0, None, 0)
Package one-kde4-config-2012-7 requires mandriva-theme
(('plymouth-system-theme', '0.8.3', '23'), ('plymouth(system-theme)', None), 0, None, 0)
Package plymouth-system-theme-0.8.3-23 requires plymouth(system-theme)
(('dracut', '017', '16'), ('plymouth(system-theme)', None), 0, None, 0)
Package dracut-017-16 requires plymouth(system-theme)
Packages can not be installed. Please, contact urpm-tools developers and provide this output.
Solved all dependences but now I've encountered an error of tsort relations... how may I resolve this issue?
Can you please provide logs with tsort relations error?GiuX писал(а):Solved all dependences but now I've encountered an error of tsort relations... how may I resolve this issue?
yes:
In order to do so I had to remove Nicco's kernel...
Generating transaction...
Checking dependencies...
No errors found in transaction
warning: LOOP:
warning: removing samba4-server-4.0.0-0.6.alpha15.x86_64 "Requires: samba4-python = 4.0.0" from tsort relations.
warning: removing samba4-python-4.0.0-0.6.alpha15.x86_64 "Requires(auto): libsamba-util.so.0()(64bit)" from tsort relations.
warning: removing lib64samba-util0-0.0.1-0.6.alpha15.x86_64 "Requires(auto): libreplace.so()(64bit)" from tsort relations.
warning: LOOP:
warning: removing lib64webkitgtk1.0_0-1.6.3-1.x86_64 "Requires: lib64webkitgtk1.0_0 = 1:1.6.3-1" from tsort relations.
warning: removing webkit1.0-1.6.3-1.x86_64 "Requires: /usr/share/webkitgtk-1.0" from tsort relations.
warning: removing webkit1.0-webinspector-1.6.3-1.x86_64 "Requires(hint): webkit1.0-webinspector" from tsort relations.
warning: LOOP:
warning: removing lib64jack0-1.9.7-4.x86_64 "Requires: jackit >= 1.9.7" from tsort relations.
warning: removing jackit-1.9.7-4.x86_64 "Requires(auto): libjack.so.0()(64bit)" from tsort relations.
warning: LOOP:
warning: removing lib64mtp9-1.1.2-3.x86_64 "Requires: lib64mtp9 = 1.1.2-3" from tsort relations.
warning: removing libmtp-utils-1.1.2-3.x86_64 "Requires: libmtp-utils >= 1.1.2-3" from tsort relations.
warning: LOOP:
warning: removing lib64gpod4-0.8.0-6.x86_64 "Requires: libgpod >= 0.8.0" from tsort relations.
warning: removing libgpod-0.8.0-6.x86_64 "Requires(auto): libgpod.so.4()(64bit)" from tsort relations.
warning: LOOP:
warning: removing samba4-server-4.0.0-0.6.alpha15.x86_64 "Requires: samba4-common = 4.0.0" from tsort relations.
warning: removing samba4-common-4.0.0-0.6.alpha15.x86_64 "Requires: samba4-python = 4.0.0" from tsort relations.
warning: removing samba4-python-4.0.0-0.6.alpha15.x86_64 "Requires(auto): libsamdb.so.0()(64bit)" from tsort relations.
warning: removing lib64samdb0-0.0.1-0.6.alpha15.x86_64 "Requires(auto): libndr.so.0()(64bit)" from tsort relations.
warning: removing lib64ndr0-0.0.1-0.6.alpha15.x86_64 "Requires(auto): liberrors.so()(64bit)" from tsort relations.
warning: LOOP:
warning: removing lib64webkitgtk1.0_0-1.6.3-1.x86_64 "Requires: lib64webkitgtk1.0_0 = 1:1.6.3" from tsort relations.
warning: removing lib64javascriptcoregtk1.0_0-1.6.3-1.x86_64 "Requires(auto): libjavascriptcoregtk-1.0.so.0()(64bit)" from tsort relations.
warning: LOOP:
warning: removing lib64jack0-1.9.8-69.2.x86_64 "Requires(auto): libjacknet.so.0()(64bit)" from tsort relations.
warning: removing jackit-1.9.8-69.2.x86_64 "Requires: jackit >= 1.9.8" from tsort relations.
warning: LOOP:
warning: removing lib64gpod4-0.8.2-2.x86_64 "Requires(auto): libgpod.so.4()(64bit)" from tsort relations.
warning: removing libgpod-0.8.2-2.x86_64 "Requires: libgpod >= 0.8.2" from tsort relations.
warning: LOOP:
warning: removing samba4-server-4.0.0-0.6.alpha15.x86_64 "Requires(auto): libsamdb.so.0()(64bit)" from tsort relations.
warning: removing lib64samdb0-0.0.1-0.6.alpha15.x86_64 "Requires(auto): libauthkrb5.so()(64bit)" from tsort relations.
warning: LOOP:
warning: removing samba4-server-4.0.0-0.6.alpha15.x86_64 "Requires(auto): libdcerpc-samr.so.0()(64bit)" from tsort relations.
warning: removing lib64dcerpc0-0.0.1-0.6.alpha15.x86_64 "Requires(auto): libregistry.so.0()(64bit)" from tsort relations.
warning: removing lib64registry0-0.0.1-0.6.alpha15.x86_64 "Requires(auto): libdcerpc-samba.so()(64bit)" from tsort relations.
warning: LOOP:
warning: removing samba4-server-4.0.0-0.6.alpha15.x86_64 "Requires(auto): libgensec.so.0()(64bit)" from tsort relations.
warning: removing lib64gensec0-0.0.1-0.6.alpha15.x86_64 "Requires(auto): libauthkrb5.so()(64bit)" from tsort relations.
warning: LOOP:
warning: removing samba4-server-4.0.0-0.9.2.alpha21.x86_64 "Requires(auto): libreplace.so()(64bit)" from tsort relations.
warning: removing lib64wbclient0-4.0.0-0.9.2.alpha21.x86_64 "Requires(auto): libwbclient.so.0()(64bit)" from tsort relations.
warning: removing samba4-test-4.0.0-0.9.2.alpha21.x86_64 "Requires(auto): libsmbclient-raw.so.0()(64bit)" from tsort relations.
warning: LOOP:
warning: removing lib64dcerpc0-0.0.1-0.9.2.alpha21.x86_64 "Requires(auto): libdcerpc.so.0()(64bit)" from tsort relations.
warning: removing lib64registry0-0.0.1-0.9.2.alpha21.x86_64 "Requires(auto): libregistry.so.0()(64bit)" from tsort relations.
warning: removing samba4-common-4.0.0-0.9.2.alpha21.x86_64 "Requires(auto): libsamba-credentials.so.0()(64bit)" from tsort relations.
warning: removing lib64gensec0-0.0.1-0.9.2.alpha21.x86_64 "Requires(auto): libgensec.so.0()(64bit)" from tsort relations.
warning: removing lib64samba-util0-0.0.1-0.9.2.alpha21.x86_64 "Requires(auto): libsamba-util.so.0()(64bit)" from tsort relations.
warning: removing lib64samdb0-0.0.1-0.9.2.alpha21.x86_64 "Requires(auto): libsamdb.so.0()(64bit)" from tsort relations.
warning: LOOP:
warning: removing samba4-python-4.0.0-0.9.2.alpha21.x86_64 "Requires: samba4-python = 4.0.0" from tsort relations.
warning: removing samba4-server-4.0.0-0.9.2.alpha21.x86_64 "Requires(auto): libserver-role.so()(64bit)" from tsort relations.
warning: removing lib64samba-hostconfig0-0.0.1-0.9.2.alpha21.x86_64 "Requires(auto): libsamba-hostconfig.so.0()(64bit)" from tsort relations.
warning: LOOP:
warning: removing lib64samba-policy0-0.0.1-0.9.2.alpha21.x86_64 "Requires(auto): libsamba-policy.so.0()(64bit)" from tsort relations.
warning: removing samba4-server-4.0.0-0.9.2.alpha21.x86_64 "Requires(auto): liberrors.so()(64bit)" from tsort relations.
warning: removing lib64ndr0-0.0.1-0.9.2.alpha21.x86_64 "Requires(auto): libndr-standard.so.0()(64bit)" from tsort relations.
warning: LOOP:
warning: removing lib64dcerpc0-0.0.1-0.9.2.alpha21.x86_64 "Requires(auto): libdcerpc-binding.so.0()(64bit)" from tsort relations.
warning: removing samba4-server-4.0.0-0.9.2.alpha21.x86_64 "Requires(auto): libauthkrb5.so()(64bit)" from tsort relations.
warning: LOOP:
warning: removing samba4-common-4.0.0-0.9.2.alpha21.x86_64 "Requires: samba4-common = 4.0.0" from tsort relations.
warning: removing samba4-server-4.0.0-0.9.2.alpha21.x86_64 "Requires(auto): libdcerpc-samba.so()(64bit)" from tsort relations.
Running transaction...Re: Problems with urpm-reposync
I guess these are not errors but just warnings about packages requiring each other. Quite normal behavior.GiuX писал(а):yes:
But the programs are not replaced, urpm-reposync terminates so...
Throwing urpm-reposync -v -a it reports:
o.O I'm so confused...
rpm_callback was called: RPMCALLBACK_TRANS_START, 6, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 0, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 1, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 2, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 3, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 4, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 5, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 6, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 7, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 8, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 9, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 10, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 11, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 12, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 13, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 14, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 15, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 16, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 17, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 18, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 19, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 20, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 21, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 22, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 23, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 24, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 25, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 26, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 27, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 28, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 29, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 30, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 31, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 32, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 33, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 34, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 35, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 36, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 37, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 38, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 39, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 40, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 41, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 42, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 43, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 44, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 45, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 46, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 47, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 48, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 49, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 50, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 51, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 52, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 53, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 54, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 55, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 56, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 57, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 58, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 59, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 60, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 61, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 62, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 63, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 64, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 65, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 66, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 67, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 68, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 69, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 70, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 71, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 72, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 73, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 74, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 75, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 76, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 77, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 78, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 79, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 80, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 81, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 82, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 83, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 84, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 85, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 86, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 87, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 88, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 89, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 90, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 91, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 92, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 93, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 94, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 95, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 96, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 97, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 98, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 99, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 100, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 101, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 102, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 103, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 104, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 105, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 106, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 107, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 108, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 109, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 110, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 111, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 112, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 113, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 114, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 115, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 116, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 117, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 118, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 119, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 120, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 121, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 122, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 123, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 124, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 125, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 126, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 127, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 128, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 129, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 130, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 131, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 132, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 133, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 134, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 135, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 136, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 137, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 138, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 139, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 140, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 141, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 142, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 143, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 144, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 145, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 146, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 147, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 148, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 149, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 150, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 151, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 152, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 153, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 154, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 155, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 156, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 157, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 158, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 159, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 160, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 161, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 162, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 163, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 164, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 165, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 166, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 167, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 168, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 169, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 170, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 171, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 172, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 173, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 174, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 175, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 176, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 177, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 178, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 179, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 180, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 181, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 182, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 183, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 184, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 185, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 186, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 187, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 188, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 189, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 190, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 191, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 192, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 193, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 194, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 195, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 196, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 197, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 198, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 199, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 200, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 201, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 202, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 203, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 204, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 205, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 206, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 207, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 208, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 209, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 210, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 211, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 212, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 213, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 214, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 215, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 216, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 217, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 218, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 219, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 220, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 221, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 222, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 223, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 224, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 225, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 226, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 227, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 228, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 229, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 230, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 231, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 232, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 233, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 234, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 235, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 236, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 237, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 238, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 239, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 240, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 241, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 242, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 243, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 244, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 245, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 246, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 247, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 248, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 249, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 250, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 251, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 252, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 253, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 254, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 255, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 256, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 257, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 258, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 259, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 260, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 261, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 262, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 263, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 264, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 265, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 266, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 267, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 268, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 269, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 270, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 271, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 272, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 273, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 274, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 275, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 276, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 277, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 278, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 279, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 280, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 281, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 282, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 283, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 284, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 285, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 286, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 287, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 288, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 289, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 290, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 291, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 292, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 293, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 294, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 295, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 296, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 297, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 298, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 299, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 300, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 301, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 302, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 303, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 304, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 305, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 306, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 307, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 308, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 309, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 310, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 311, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 312, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 313, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 314, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 315, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 316, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 317, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 318, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 319, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 320, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 321, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 322, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 323, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 324, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 325, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 326, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 327, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 328, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 329, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 330, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 331, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 332, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 333, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 334, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 335, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 336, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 337, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 338, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 339, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 340, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 341, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 342, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 343, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 344, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 345, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 346, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 347, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 348, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 349, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 350, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 351, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 352, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 353, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 354, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 355, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 356, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 357, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 358, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 359, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 360, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 361, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 362, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 363, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 364, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 365, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 366, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 367, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 368, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 369, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 370, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 371, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 372, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 373, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 374, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 375, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 376, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 377, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 378, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 379, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 380, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 381, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 382, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 383, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 384, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 385, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 386, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 387, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 388, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 389, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 390, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 391, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 392, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 393, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 394, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 395, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 396, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 397, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 398, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 399, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 400, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 401, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 402, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 403, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 404, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 405, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 406, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 407, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 408, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 409, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 410, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 411, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 412, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 413, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 414, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 415, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 416, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 417, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 418, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 419, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 420, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 421, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 422, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 423, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 424, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 425, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 426, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 427, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 428, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 429, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 430, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 431, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 432, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 433, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 434, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 435, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 436, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 437, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 438, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 439, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 440, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 441, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 442, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 443, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 444, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 445, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 446, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 447, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 448, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 449, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 450, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 451, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 452, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 453, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 454, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 455, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 456, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 457, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 458, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 459, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 460, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 461, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 462, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 463, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 464, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 465, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 466, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 467, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 468, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 469, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 470, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 471, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 472, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 473, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 474, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 475, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 476, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 477, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 478, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 479, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 480, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 481, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 482, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 483, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 484, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 485, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 486, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 487, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 488, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 489, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 490, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 491, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 492, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 493, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 494, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 495, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 496, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 497, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 498, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 499, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 500, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 501, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 502, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 503, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 504, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 505, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 506, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 507, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 508, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 509, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 510, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 511, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 512, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 513, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 514, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 515, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 516, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 517, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 518, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 519, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 520, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 521, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 522, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 523, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 524, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 525, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 526, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 527, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 528, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 529, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 530, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 531, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 532, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 533, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 534, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 535, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 536, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 537, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 538, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 539, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 540, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 541, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 542, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 543, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 544, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 545, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 546, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 547, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 548, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 549, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 550, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 551, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 552, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 553, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 554, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 555, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 556, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 557, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 558, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_PROGRESS, 559, 560, None, 1
rpm_callback was called: RPMCALLBACK_TRANS_STOP, 6, 560, None, 1Re: Problems with urpm-reposync
Hmm... I'll tell urpm-reposync's developer to investigate this issue. I'm confused too...GiuX писал(а):Throwing urpm-reposync -v -a it reports:
GiuX
The devs are asking to wait a little, the update of the package it's on its way to the repos.
ps -- kindly use 'code' tags while posting long outputs, for everybody's convenience
The last error is something weird, but I've encountered it before. urpm-reposync creates a large transaction for rpm and rpm should run it, but sometimes it does nothing but "RPMCALLBACK_TRANS_PROGRESS". It looks like a bug in rpm or python rpm binding. I could not resolve this issue yet.
About the first problem - I'll take a look.
Thanks Guys, I'm downloading now the requested update, I'm so grateful
Another issue is incoming:
[3/12] xulrunner
Problem deps for xulrunner: []
Emulating package removing: xulrunner
File "/usr/bin/urpm-reposync", line 1332, in <module>
Main()
File "/usr/bin/urpm-reposync", line 1214, in Main
process_packages()
File "/usr/bin/urpm-reposync", line 818, in process_packages
emulate_remove(act, updating=True)
File "/usr/bin/urpm-reposync", line 743, in emulate_remove
deps = installed.packages[pkg][tag]
KeyError: 'provides'
I've manually resolved the dependence of xulrunner (replacing the old package) but now there is the usually problem with Nicco's kernel that I cannot explain... I've configurated the repos, I report the list:
including this repo:
Processing medium Micro...
(http://abf.rosalinux.ru/downloads/kerne ... in/release)
Loading the list of installed packages...
Processing medium Main_64_release...
Processing medium Main_64_updates...
Processing medium Contrib_64_release...
Processing medium Contrib_64_updates...
Processing medium NonFree_64_release...
Processing medium NonFree_64_updates...
Processing medium Restricted_64_release...
Processing medium Restricted_64_updates...
Processing medium MIB-basic_64...
Processing medium MIB-experts_64...
Processing medium Main_32_release...
Processing medium Main_32_updates...
Processing medium Contrib_32_release...
Processing medium Contrib_32_updates...
Processing medium NonFree_32_release...
Processing medium NonFree_32_updates...
Processing medium Restricted_32_release...
Processing medium Restricted_32_updates...
Processing medium MIB-basic_32...
Processing medium MIB-Kernel-3.6.x...
Computing actions list...
>>>ERROR: Package kernel-nrjQL-laptop-3.6.6-69rosa.lts has unsatisfied dependencies: [microcode >= 0:0.20120313-1]
>>> Contact repository maintaiers and send them this information, please.
Последний раз редактировалось GiuX 13 ноя 2012, 01:11, всего редактировалось 1 раз.
Why these?
Why these?
Processing medium MIB-basic_32...Re: Problems with urpm-reposync
In order to replace also the x586 rpm...
However i'm trying to disable them...
Removed the MIB-Kernel repository, it returns the RPMCALLBACK error...
I've tried, nothing... there's a problem with RPMs...
I've tried to do this command:
what does it mean???
urpm-reposync --runselftest
test_nevr_parse (__main__.Tests) ... FAIL
test_version_compare (__main__.Tests) ... ok
FAIL: test_nevr_parse (__main__.Tests)
File "/usr/bin/urpm-reposync", line 874, in test_nevr_parse
self.assertEqual(self.p1.EVR, '1.0')
AssertionError: '0:1.0' != '1.0'
Ran 2 tests in 0.002s
FAILED (failures=1)Re: Problems with urpm-reposync
I print to you this output:
Seems that there's a problem with python code...
Excuse me if I could to seem too insistent...
urpm-reposync -v
File "/usr/bin/urpm-reposync", line 934, in <module>
Main()
File "/usr/bin/urpm-reposync", line 773, in Main
repository.load_from_repository(ms)
File "/usr/lib/python2.7/site-packages/rpm5utils/synthesis.py", line 429, in load_from_repository
eprint(_("File can not be processed! Url: ") + synthesis_list)
NameError: global name 'eprint' is not defined
Well, I guess it's very helpful for urpm-reposync developerGiuX писал(а):Seems that there's a problem with python code...
After a little bit of work, I was able to download the requested rpm but there's the usually RPMCALLBACK errors, even in text mode...
With a clean installation of RM2012.0 the script works
