How to get 32-bit compatibility libraries?
DisappearingOak
Which package can I install on my 64-bit ROSA to get 32-bit compatibility?
Re: How to get 32-bit compatibility libraries?
Basically it depends on what 32bit apps you want to run.DisappearingOak писал(а):Which package can I install on my 64-bit ROSA to get 32-bit compatibility?
I use those repositories:
urpmi.removemedia -a
urpmi.addmedia Main_64_release http://mirrors.coreix.net/rosa/rosa2012lts/x86_64/media/main/release/
urpmi.addmedia --update Main_64_updates http://mirrors.coreix.net/rosa/rosa2012lts/x86_64/media/main/updates/
urpmi.addmedia Contrib_64_release http://mirrors.coreix.net/rosa/rosa2012lts/x86_64/media/contrib/release/
urpmi.addmedia --update Contrib_64_updates http://mirrors.coreix.net/rosa/rosa2012lts/x86_64/media/contrib/updates/
urpmi.addmedia NonFree_64_release http://mirrors.coreix.net/rosa/rosa2012lts/x86_64/media/non-free/release/
urpmi.addmedia --update NonFree_64_updates http://mirrors.coreix.net/rosa/rosa2012lts/x86_64/media/non-free/updates/
urpmi.addmedia Restricted_64_release http://mirrors.coreix.net/rosa/rosa2012lts/x86_64/media/restricted/release/
urpmi.addmedia --update Restricted_64_updates http://mirrors.coreix.net/rosa/rosa2012lts/x86_64/media/restricted/updates/
urpmi.addmedia --update MIB-basic_64 http://mirrors.coreix.net/MIB/rosa2012lts/64/basic/
urpmi.addmedia --raw --update MIB-experts_64 http://mirrors.coreix.net/MIB/rosa2012lts/64/experts/
urpmi.addmedia Main_32_release http://mirrors.coreix.net/rosa/rosa2012lts/i586/media/main/release/
urpmi.addmedia --update Main_32_updates http://mirrors.coreix.net/rosa/rosa2012lts/i586/media/main/updates/
urpmi.addmedia --raw Contrib_32_release http://mirrors.coreix.net/rosa/rosa2012lts/i586/media/contrib/release/
urpmi.addmedia --raw --update Contrib_32_updates http://mirrors.coreix.net/rosa/rosa2012lts/i586/media/contrib/updates/
urpmi.addmedia --raw NonFree_32_release http://mirrors.coreix.net/rosa/rosa2012lts/i586/media/non-free/release/
urpmi.addmedia --raw --update NonFree_32_updates http://mirrors.coreix.net/rosa/rosa2012lts/i586/media/non-free/updates/
urpmi.addmedia --raw Restricted_32_release http://mirrors.coreix.net/rosa/rosa2012lts/i586/media/restricted/release/
urpmi.addmedia --raw --update Restricted_32_updates http://mirrors.coreix.net/rosa/rosa2012lts/i586/media/restricted/updates/
urpmi.addmedia --raw --update MIB-basic_32 http://mirrors.coreix.net/MIB/rosa2012lts/32/basic/
#There is one more thing. If you want that you 32bit apps looks like your 64bit apps, you need to install those libraries:
urpmi libcanberra-gtk0
urpmi libmurrineКод: Выделить всё
urpmi libgtk-aurora-engine-1And this one is used by 32bit QT apps (like skype dynamic)
urpmi libqtgui4
