2012 Desktop Alpha 2 first impressions
English-speaking forum for talkers =)
ferri
Сообщение ferri »
I have problematic graphic card ATI Mobility Radeon X1350 for kernels 3.5.x and higher. It is impossible normal booting with kernels 3.5.x and higher.
But it was enough to add nomodeset at the end of the kernel booting options and booting started without any problem.
I do not prefer RocketBar. So I replaced it with Default Panel. But there is bug because it is without classical KDE menu.
I must state that there is feeling a lot of work from this alpha 2. :D
Последний раз редактировалось ferri 17 окт 2012, 08:08, всего редактировалось 1 раз.
rugyada
Re: 2012 Desktop Alpha 2 first impressions
Сообщение rugyada »
ferri писал(а):So I replaced it with Default Panel. But there is bug because it is without classical KDE menu.
For KDE standard/kickoff menu
urpmi kickoff
and add object to the panel
:wink:
ferri
Сообщение ferri »
I know, but I was in live regime without internet.
And it is working without additional steps in ROSA Marathon.
ferri писал(а):I know, but I was in live regime without internet.
In next ISO kickoff menu will be available by default again. It was missing by mistake.
ferri
Сообщение ferri »
After
urpmi --update --auto-update
I see that some hdlists (main, contrib) has updated.
But there are not any updated packages finally.
Is it correct?
ferri писал(а):After
Is it correct?
Should be quite many already. Few hundreds at least.
ferri
Сообщение ferri »
Pulfer писал(а): Should be quite many already. Few hundreds at least.
So it seems that I have a problem. Because I have added sources but any updates for Alpha 2 so far.
ferri писал(а):So it seems that I have a problem. Because I have added sources but any updates for Alpha 2 so far.
I guess I know the reason. You need to mark main, contrib, non-free and restricted repositories as update repos. All updates appear in /release repos (not in /updates) until 2012.1 final is released.
I suggest to edit /etc/urpmi/urpmi.cfg file and add "update" line for /release repos. Like:
main\ (Desktop2012.1-1) [your mirror url] {
update
ferri
Сообщение ferri »
Pulfer писал(а): I suggest to edit /etc/urpmi/urpmi.cfg file and add "update" line for /release repos. Like:
update
You were right. :)
Already working. Thanks.
ferri
Сообщение ferri »
http://mirror.rosalinux.com/rosa/rosa20 ... ktop.Beta/
Are these images official, because there is not any message so far?
Please wait a liitle :)
ferri
Сообщение ferri »
Pulfer писал(а): In next ISO kickoff menu will be available by default again. It was missing by mistake.
I downloaded Beta 1 32bit, tried in live regime, but kickoff is missing.
I'm really sorry about that. :oops: Kickoff was added to ISO packages list right after beta ISO build started 1 week ago. I was little late. But as now it's in ISO packages list, next time it will be 100% included in ISO.
ferri
Сообщение ferri »
Pulfer писал(а): I'm really sorry about that. :oops: Kickoff was added to ISO packages list right after beta ISO build started 1 week ago. I was little late. But as now it's in ISO packages list, next time it will be 100% included in ISO.
Never mind. :D
ferri
Сообщение ferri »
Still missing in RC. :(
Вернуться в «Off the wall»
