How to get installer to use vesa driver?
benbullard79
Operating system: ROSA Fresh R5
OpenMandriva Lx 2014.1
openSuSE 13.2
Сообщение benbullard79 »
This issue pertains to every version of ROSA I've used but at the moment I'm trying to install Marathon RP1 EE x86_64. :cry: What is the correct kernel option to get installer to use vesa driver? I've tried 'blacklist=nouveau xdriver=vesa xforce=vesa' in every combination and that doesn't do it. I've also tried simply 'vesa' which also doesn't work. This machine has this graphics:
$ lspci
00:05.0 VGA compatible controller: nVidia Corporation C51PV [GeForce 6150] (rev a2)
which is an nvidia chipset on ASUS M2NPV-VM mobo. It works with either nvidia or vesa drivers but not with nouveau or nv.
'Nuther question. Will ROSA installers work in text mode. I'm thinking that they won't.
Thanks,
Ben Bullard
Re: How to get installer to use vesa driver?
benbullard79 писал(а):'Nuther question. Will ROSA installers work in text mode. I'm thinking that they won't.
Long-term plans may be, but not at the moment, you're right.
Regarding vesa option -- kindly file the bug to have opportinity to discuss it (at least) with devs .
benbullard79
openSuSE 13.2
Thanks for the reply. I'm buried with work for a couple of days. I'll file a bug report later this week.
Thanks,
Ben Bullard
Вернуться в «Marathon (ROSA LTS)»
