Rosa 2012 ee do not want to install
karol
Operating system: Rosa Marathon 2012 RP1,OpenMandriva 2013 alpha
Сообщение karol »
hello
When installed, the system shows in August,Welcome screen with the bar,showing the charging system ,and then pops up a black screen and this message:dracut Warrning ~/dev/disk/by-label/ROSA.2012.MARATHON.i586.101" does not exist ,dracut Warrning ~/dev/napper/live-rw" does not exist .Very please help, because ,I do not know what to do. Cheers, and welcome in advance thank you for your help Charles :(
d_uragan
Re: Rosa 2012 ee do not want to install
Сообщение d_uragan »
Which machine do you have? It is especially interesting to know which matherboard is used and does it has EFI or usual BIOS (sorry if I ask for too many technical details:)).
ROSA 2012 Marathon has problems with booting on some EFI machines. On some of them, this can be fixed by modifying EFI/BIOS settings (choosing 'Legacy' mode for EFI or something like that - it depends on your motherboard).
karol
Сообщение karol »
Class Intel Celeron M
Code 353 CPU
0.9 GHz CPU clock
Frequency of 400 MHz FSB
Capacity Cache 512 KB
Intel 910GML
technical specyfication
d_uragan
Hm, for that chipset it is unliklely to be EFI problem...
Could you please try to boot Alpha iso from here:
http://mirror.rosalab.ru/iso/ROSA.Deskt ... 2.1.Alpha/
We have updated several components related to boot process (though not all of them yet), maybe this will help.
karol
Сообщение karol »
I downloaded Rose 2012 RP,and all was well, the,until the system was supposed to start,jumped if grub2 error,and I do not know what to do help :(
karol писал(а):I downloaded Rose 2012 RP,and all was well, the,until the system was supposed to start,jumped if grub2 error,and I do not know what to do help :(
I think your issue is similar to the one from THIS topic. In short -- you should check that GRUB installs on the device (e.g. /dev/sda), and do not install it on the partition (e.g. /dev/sda6, sda4, sda1 etc)
karol
Сообщение karol »
Thanks friend :)
Вернуться в «Marathon (ROSA LTS)»
