Kernel Farm for ROSA, OMA, cooker ^ Kernel 3.0.101 - 3.10.63 - 3.12.35 - 3.13.11 - 3.14.46 - 3.15.10 - 3.17.8 - 3.18.17 - 3.19.8 - 4.1.18 : You can try and test all the best kernels for ROSA Marathon and ROSA Fresh!
NicCo
Сообщение NicCo »
You can try and test the best kernels with BFQv7r7 disk I/O scheduler: about 5 seconds less in kernel boot times!
Situation updated to February 02 2015
Go to the latest messages, to read about the latest / current!
Kernel 3.14.30 & Kernel 3.18.5 > http://forum.rosalab.ru/en/viewtopic.ph ... 200#p38141
LATEST NEWS:
Info about Kernel 3.10 series availability on ROSA Marathon >>> http://forum.rosalab.ru/viewtopic.php?f ... 129#p19129
Kernels ONE 3.10.10 (all the kernel flavours prepared and built from ONE only source) > http://forum.rosalab.ru/viewtopic.php?f ... 536#p19536
We have now organized the kernels in a better way, at least we think so...
In ABF we are storing kernels organized in different folders per branch number,
so. for example, we have one folder for all the kernel versions of 3.0.xx serie...
For all the Kernel LTS versions, we are preparing also the Kernel-RT flavour
All versions prepared to install and work starting from MDV 2010 & 2011 upto ROSA 2012LTS & 2012.1
The files are stored in the new ABF folders, instead those for old Mandriva 2010.2 will stay only in MIB
ABF can't build for old MDV2010, for that reason all our rpms for MDV 2010 are the results of local build
INFO about the SRPM build possibilities:
For ROSA Marathon we'll build Kernels LTS: 3.0, 3.2, 3.4, and all the latest kernels up to the 3.8 series
For ROSA Fresh we are building all Kernel versions starting only from the 3.6 to the most recent series
For old distro, we are maintaining build compatibility: you can also rebuild for Mandriva 2010 and 2011
IMPORTANT CONSIDERATION (taken by a user comment I've found in the mandriva international forum):
Nym писал(а):Kernels install separately, they don't overwrite one another. A kernel upgrade does change the default kernel, but the old one will still be on the list at the boot splash, you'd use the arrow keys to select the older one.
So it's not a system killer to try an upgraded kernel. If it doesn't work, select and older one, and remove the newer. I mention this because you may want to try one of the 3.x kernels packaged by MIB. I'm using MIB kernels on a couple laptops because wifi didn't work with the stock kernel. MIB fixed the problems.
[/quote]
The group folders are organized like repositories, so you could also add them using the 'urpmi.addmedia' commands
So, if you feel good, for example, with kernel 3.2 branch, you can leave this repository enabled to receive updates...
Here are the paths of different kernels for MDV2011, RM2012, ROSA2012.1
kernels 3.0.xx >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.1.xx >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.2.xx >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.3.xx >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.4.xx >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.5.xx >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.6.xx >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.7.xx >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.8.xx >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.9.xx >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.10.x >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.11.x >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.12.x >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.13.x >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.14.x >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
kernels 3.15.x >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
Microcode firmwares for cpu AMD / INTEL
http://mib.pianetalinux.org/forum/viewt ... =38&t=3424
kernels drivers >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
Here are the paths of different kernels for MDV2010
Files stay on MIB - Kernel 64bit > Click Here - Kernel 32bit > Click Here
Advice:
Probably, we'll leave only the latest three or four versions, while all the files of the oldest versions may be deleted...
bye, NicCo
Последний раз редактировалось NicCo 22 фев 2016, 18:20, всего редактировалось 491 раз.
NicCo
Kernel Farm for ROSA, OMA, cooker ^ Kernel 3.0.101 - 3.10.63 - 3.12.35 - 3.13.11 - 3.14.46 - 3.15.10 - 3.17.8 - 3.18.17 - 3.19.8 - 4.1.15 : You can try and test all the best kernels for ROSA Marathon and ROSA Fresh!
Сообщение NicCo »
LATEST NEWS:
OpenMandriva 2013.0 kernel rebuilds >>> http://forum.rosalab.ru/en/viewtopic.ph ... 322#p19094
New kernels, organized in different folders
  • Kernel LTS 3.0.28 (RM2012), 3.0.38 (RP1), 3.0.69 (X1) upto 3.0.80, 3.0.84, 3.0.88, 3.0.101
  • Kernel 3.1.10 (EOL)
  • Kernel LTS 3.2.23, ... 3.2.45 upto 3.2.49
  • Kernel 3.3.6 upto 3.3.8 (EOL)
  • Kernel LTS 3.4.5 upto 3.4.55
  • Kernel 3.5.1 upto 3.5.7 (EOL)
  • Kernel 3.6.1 upto 3.6.11 (EOL)
  • Kernel 3.7.1, 3.7.5, 3.7.6, 3.7.7, 3.7.8, 3.7.9 3.7.10
  • Kernel 3.8.1, 3.8.2, 3.8.3, 3.8.4, 3.8.5, 3.8.6, 3.8.7, 3.8.8, 3.8.10, 3.8.11, 3.8.12, 3.8.13 -rt14 -rtQL14, 3.8.13 (release 3)
  • Kernel 3.9.1, 3.9.4, 3.9.5, 3.9.6, 3.9.7, 3.9.8, 3.9.9, 3.9.10, 3.9.11
  • Kernel 3.10 rc3, rc4, rc5, rc6, rc7, 3.10.0, 3.10.1, 3.10.4, 3.10.5, 3.10.6, 3.10.7, 3.10.8, 3.10.9, 3.10.10, 3.10.11, 3.10.12, 3.10.13, 3.10.14, 3.10.15, 3.10.16, 3.10.17, 3.10.18, 3.10.19, 3.10.20, 3.10.21, 3.10.24, 3.10.25, 3.10.26, 3.10.28, 3.10.29, 3.10.30, 3.10.34, 3.10.35, 3.10.36, 3.10.37, 3.10.38, 3.10.40, 3.10.41, 3.10.44, 3.10.46, 3.10.49, 3.10.53
  • Kernel 3.11, 3.11.0, 3.11.1, 3.11.2, 3.11.3, 3.11.4, 3.11.6, 3.11.7, 3.11.8, 3.11.9, 3.11.10 (EOL)
  • Kernel 3.12.5, 3.12.6, 3.12.7, 3.12.8, 3.12.9, 3.12.10, 3.12.11, 3.12.12, 3.12.13, 3.12.15, 3.12.16, 3.12.17, 3.12.18, 3.12.20, 3.12.23, 3.12.24, 3.12.27
  • Kernel 3.13, 3.13.6, 3.13.7, 3.13.8, 3.13.9, 3.13.10, 3.13.11
  • Kernel 3.14, 3.14.6, 3.14.8, 3.14.9, 3.14.10, 3.14.13, 3.14.17
  • Kernel 3.15, 3.15.6, 3.15.7, 3.15.8, 3.15.9, 3.15.10
    Soon:
    • some missing drivers(?), firmwares (??), cpu microcodes (done!)
Drivers for new kernels >>> http://abf.rosalinux.ru/downloads/kerne ... epository/
In this new folder, we'll store some important driver suited for new kernels
bye, NicCo
Последний раз редактировалось NicCo 24 дек 2015, 11:12, всего редактировалось 316 раз.
NicCo
Re: Kernel Farm with drivers for ROSA Linux and Mandriva
Сообщение NicCo »
Update ^ to 07 September 2012
Go To the previous msg!
latest maintained kernels to be avaialble are
3.0.42 - 3.2.28 - 3.3.8 - 3.4.10
now, our latest friend is is Kernel 3.5.3... :)
You have not write about kernel.
You can read more about kernel-nrj-laptop from http://abf.rosalinux.ru/downloads/kerne ... n/release/
I use it.
NicCo
Сообщение NicCo »
You can read all kernel News, here:
Latest from packagers & testing
http://mib.pianetalinux.org/forum/viewforum.php?f=38
NicCo писал(а):You can read all kernel News, here:
OK. But this topic is also needed.
NicCo
Kernel 3.7.7 nrj nrjQL for ROSA 2012 2012.1 & MDV 2010 2011
Сообщение NicCo »
Today we are aligning again with the "latest stable kernel" 3.7.7
this recent kernel is prepared with the new source model (nrj V4)
for this version I sent to rebuild only 1 flavours: desktop
but soon I'll send to rebuild other some kernel flavours...
next to be rebuilt would be -realtime, -laptop, -netbook
(if we need some else we can rebuild all other flavours)
MORE INFO:
Kernel 3.7.7 for ROSA 2012.0 / 2012.1 & Mdv 2010 / 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3763
Kernel 3.7.7 nrjQL for ROSA 2012.0 / 2012.1 & MDV 2010 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3764
%changelog
* Wed Feb 13 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.7.7-1
+ update to 3.7.7 stable (34 fixes all over)
- update AUFS3 to 3.7 20130212
- specific for nrjQL addons:
- update BFQ v6 I-O-sched for-3.7
- update tuxonice 3.7.7 20130212
- remove microcode from "requires", now it's in "suggests"
- Kernel 3.7 for mdv 2010.2, 2011.0, cooker, rosa.lts2012.0, rosa2012.1
- MIB (Mandriva International Backports) - http://mib.pianetalinux.org/
- The rel -1 (mainline serie), with official kernel sources and addons,
- instead (-69) will be used for development and experimental flavours,
- Yin & Yang (69) release - a very complete but experimental flavours...
Apart the usual general fixes, new git versions for AUFS and TuxOnIce,
we notice the amazing new version v 6 of the BFQ (disk I/O scheduler):
I remind you that is available as default for all the nrjQL flavour series...
BFQ v6:
- Replacement of the cooperating-queue merging mechanism borrowed from
CFQ with Early Queue Merge (EQM), a unified mechanism to get a
sequential read pattern, and hence a high throughput, with any set of
processes performing interleaved I/O. EQM also preserves low latency.
(see http://algo.ing.unimo.it/people/paolo/d ... iption.php
for more details). Contributed by Mauro Andreolini and Arianna Avanzini.
The code for detecting whether two queues have to be merged is a
slightly modified version of the CFQ code for detecting whether two
queues belong to cooperating processes and whether the service of a
queue should be preempted to boost the throughput.
- Fix a bug that caused the peak rate of a disk to be computed as zero
in case of multiple I/O errors. Subsequent estimations of the weight
raising duration caused a division-by-zero error.
Please start testing 3.7.7 and reporting your experiences to MIB forum
Последний раз редактировалось NicCo 11 мар 2013, 20:55, всего редактировалось 1 раз.
NicCo
Kernel 3.7.8 nrj nrjQL for ROSA 2012 2012.1 & MDV 2010 2011
Сообщение NicCo »
Today we are aligning again with the "latest stable kernel" 3.7.8
Main News of this version:
  • all nrj flavours use BFQ v6 (disk I/O), enabled by default
  • all nrj laptop flavours since now use the full preemption
Please, test:
- the disk I/O behaviour and performances
- the new laptop flavours behaviour
for this version I've sent to rebuild 4 flavours (arch 32 & 64bit) for RM2012 (2012.0) & Fresh 2012 (2012.1):
-desktop, -realtime, -laptop, -netbook
(if you need some else we can rebuild all other flavours, at your specific request, i.e. some -pae flavours)
MORE INFO:
Kernel 3.7.8 for ROSA 2012.0 / 2012.1 & Mdv 2010 / 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3771
Kernel 3.7.8 nrjQL for ROSA 2012.0 / 2012.1 & MDV 2010 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3772
Changelog >
%changelog
* Sat Feb 16 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.7.8-1
+ update to 3.7.8 stable (69 fixes all over)
- update AUFS3 to 3.7 20130215
- update tuxonice 3.7.8 20130215
- updated scripts:
- all nrj flavours use BFQ v6 (disk I/O) enabled by default
- all nrj laptop flavours since now use the full preemption
Please start testing 3.7.8 and reporting your experiences to MIB forum
- the main feature to check is the disk I/O behaviour and performances
akdengi
Сообщение akdengi »
Hi - Did this symlink present in kernel ?
ln -s /usr/src/linux-3.7.8-nrj-laptop-1rosa/include/generated/uapi/linux/version.h /usr/src/linux-3.7.8-nrj-laptop-1rosa/include/linux/version.h
for example
This need for comple dmks modules, lilke NVIDIA blobs...
NicCo
Сообщение NicCo »
akdengi писал(а):This need for comple dmks modules, lilke NVIDIA blobs...
Thanks, for the question / suggestion:
only with 3.7.8 we realized that the problem was caused by the new path of version.h
at the begin i thought that was an error of 3.7, and I waited for a mainstream solution
then I verified that also new kernel 3.8 has the same new path for version.h
other distros like fedora, suggest to create manually the symlinks as a workaround,
but i dont like at all suggesting these genre of operations to the "everyday users"...
We discussed a clean solution with A. Burmashev, and finally yesterday a clean
fix was added to the spec, and verified in internal build 3.7.9
today, new kernel 3.7.9 will be prepared with the fix, and will be send to ABF
For the future:
with new drivers, dkms, etc we should take care of new version.h path natively
next dkms drivers should address the problem,
the symlinks are only a backport workaround,
fixing dkms issues, but not a official solution
none other symlink is in the/include/linux/
bye, NicCo
Последний раз редактировалось NicCo 21 фев 2013, 00:14, всего редактировалось 1 раз.
NicCo
Kernel 3.7.9 nrj nrjQL for ROSA 2012 2012.1 & MDV 2010 2011
Сообщение NicCo »
Today we are aligning again with the latest stable kernel 3.7.9
these kernels are prepared with the new source model (nrj V4)
Now we have only four flavours available:
desktop, realtime, laptop, netbook
(we can rebuild other flavours, as usual, if we need some else like i.e a -pae)
MORE INFO:
Kernel 3.7.9 for ROSA 2012.0 / 2012.1 & Mdv 2010 / 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3781
Kernel 3.7.9 nrjQL for ROSA 2012.0 / 2012.1 & MDV 2010 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3782
Please start testing 3.7.9 and reporting your experiences to MIB forum
the main features to test are:
- the build "on the fly" of the dkms drivers
Changelog >
%changelog
* Wed Feb 20 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.7.9-69
+ update to 3.7.9 stable (12 fixes all over)
- update AUFS3 to 3.7.9 20130218
- update tuxonice 3.7.9 20130218
- add a workaround to fix issue with dkms drivers for recent distros:
- /linux/version.h symlink to /include/generated/uapi/linux/version.h
Последний раз редактировалось NicCo 11 мар 2013, 20:54, всего редактировалось 1 раз.
NicCo
Kernel 3.0.66 nrj nrjQL for ROSA 2012.0 & MDV 2010 2011
Сообщение NicCo »
This could be considered as the february monthly kernel update for ROSA Marathon:
the "latest stable kernel" 3.0.66 of Kernel LTS, an update for ROSA Marathon 2012
In this moment I'm writing with it from my RM2012 - x8664
utente ~/Documenti $ uname -a
Linux localhost.localdomain 3.0.66-nrj-desktop-1rosa.lts #1 SMP PREEMPT Sat Feb 23 02:04:09 MSK 2013 x86_64 x86_64 x86_64 GNU/Linux
There are avaialable almost all flavours possibile with MIB Kernels:
Generic: kernel-nrj-desktop and then
nrj-laptop, nrj-netbook, nrj-realtime, server
Cpu optimized:
nrj-desktop-core2, nrj-netbook-atom
PAE versions:
nrj-desktop-pae, nrj-laptop-pae, nrj-netbook-pae, nrj-realtime-pae
nrj-desktop-core2-pae,
the same scheme for all the flavours of experimental nrjQL branch
MORE INFO:
Kernel 3.0.66 for ROSA Marathon 2012.0 & Mdv 2010 / 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3785
Kernel 3.0.66 nrjQL for ROSA Marathon 2012.0 & MDV 2010 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3786
Please start testing 3.0.66 and reporting your experiences to MIB forum
thanks for Your attention
bye, NicCo
Последний раз редактировалось NicCo 11 мар 2013, 20:53, всего редактировалось 2 раза.
NicCo
Kernel 3.4.33 nrj nrjQL for ROSA 2012.0 & MDV 2010 2011
Сообщение NicCo »
Today we are aligning with the "latest stable kernel" v 3.4.33
of Kernel LTS 3.4 series, update for ROSA Marathon 2012
Now we have ony 2 flavours available, precisely the ones I'm testing
kernel-nrj-desktop-3.4.33 and kernel-nrjQL-desktop-3.4.33
In this moment I'm writing wiith it in my RM2012 - 64
Linux localhost.localdomain 3.4.33-nrj-desktop-1rosa.lts #1 SMP PREEMPT Thu Feb 28 19:20:19 MSK 2013 x86_64 x86_64 x86_64 GNU/Linux
MORE INFO:
Kernel 3.4.33 for ROSA Marathon 2012.0 & Mdv 2010 / 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3795
Kernel 3.4.33 nrjQL for ROSA Marathon 2012.0 & MDV 2010 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3796
If you need different kernel flavours, you can import the srpm into your personal repo,
change some %define builds, and send to rebuild:
example, if you need nrj-desktop-pae > disable nrj-desktop, enable nrj-desktop-pae
# Build nrj desktop (i686 / 4GB) / x86_64 / sparc64 sets
%define build_nrj_desktop        0
# Build nrj desktop686 pae (i686 / 64GB)
%ifarch %{ix86}
%define build_nrj_desktop_pae    1
Please start testing 3.4.33 and reporting your experiences to MIB forum
bye, NicCo
NicCo
Kernel 3.2.39 for ROSA Marathon 2012.0 & Mdv 2010 2011
Сообщение NicCo »
Today we are aligning with the "latest stable kernel" v 3.2.39
of Kernel LTS 3.2 series, update for ROSA Marathon 2012
Now we have only 1 flavour available, precisely the one I'm testing:
kernel-nrj-desktop-3.2.39,
I remind You that kernel 3.2 is not still available in the nrjQL serie
Linux localhost.localdomain 3.2.39-nrj-desktop-1rosa.lts #1 SMP PREEMPT Thu Feb 28 19:45:26 MSK 2013 x86_64 x86_64 x86_64 GNU/Linux
MORE INFO:
Kernel 3.2.39 for ROSA Marathon 2012.0 & Mdv 2010 / 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3797
%ifarch %{ix86}
Please start testing 3.2.39 and reporting your experiences to MIB forum
bye, NicCo
Последний раз редактировалось NicCo 11 мар 2013, 20:52, всего редактировалось 1 раз.
NicCo
Kernel 3.7.10 nrj/nrjQL for ROSA 2012 2012.1 & Mdv 2010 2011
Сообщение NicCo »
Today we are aligning with the "latest stable kernel" v 3.7.10
of Kernel 3.7 series, this is the EOL (End of Line) final version
%changelog
* Sun Mar 03 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.7.10-1
+ update to 3.7.10 stable (79 fixes all over)
- With this version, 3.7 has reached the EOL status (End of Life)
+ update to nrj v4 - rel 1.3 (05 mar 2013)
- On request of Alexander Khryukin, fixed configs and scripts for ARM:
- fixed configs, removed all warnings, enabled again all arm defconfigs
- defconfigs for kirkwood, versatile, iop32x have BFQ enable by default
kernel-nrj-desktop-3.7.10, and kernel-nrjQL-desktop-3.7.10
Tomorrow should be available the most of possible different flavours
MORE INFO:
Kernel 3.7.10 for ROSA 2012.0 / 2012.1 & Mdv 2010 / 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3803
Kernel 3.7.10 nrjQL for ROSA 2012.0 / 2012.1 & Mdv 2010 / 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3804
%ifarch %{ix86}
Please start testing 3.7.10 and reporting your experiences to MIB forum
bye, NicCo
Последний раз редактировалось NicCo 11 мар 2013, 20:52, всего редактировалось 3 раза.
NicCo
Kernel 3.8.1 nrj nrjQL for ROSA 2012 2012.1, MDV2010 2011 co
Сообщение NicCo »
Today we are aligning with the "latest stable kernel" v 3.8.1
of Kernel 3.8 series, this is the first version, also for cooker
%changelog
* Sun Mar 10 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.8.1-1
+ update to 3.8.1 stable
+ update to nrj v4 - rel 1.4 (09 mar 2013)
- This version is first attempt to merge stuff with OpenMandriva devel:
- it should build from mdv2010/2011, rosa2012.0/2012.1, and cooker 2013
- Kernel 3.8 for mdv 2010.2, 2011.0, cooker, rosa.lts2012.0, rosa2012.1
We have tested it with famous virtualization software like:
Vmware 9.0.2, VMPlayer 5.0.2, VirtualBox 4.2.8 > OK versions for 3.8
Now we have only 5 flavours available, precisely the one I'm testing:
desktop, laptop, netbook, realtime, server
MORE INFO:
Kernel 3.8.1 for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3814
Kernel 3.8.1 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3815
Here MIB Kernels (nrj & nrjQL) also for OpenMandriva 2013.0
http://mib.pianetalinux.org/forum/viewt ... =38&t=3816
%ifarch %{ix86}
now an unique SRPM is able to produce kernels good from mdv 2010 to cooker
and also I fixed all scripts and the configs to support Alex Khryuskin ARM port.
New SRPMS can be rebuilt and installed into the following Linux distros:
  • MDV 2010.2 - 32 & 64
  • MDV 2011.0 - 32 & 64
  • ROSA 2012.0 - 32 & 64
  • ROSA 2021.1 - 32 & 64
  • OpenMandriva (cooker) - 2013.0 32 & 64
  • OpenMandriva (cooker) - 2013.0 ARM cpu
The actual kernel for cooker 2013.0 is Kernel nrjQL 3.7.6-70 based on nrjQL 3.7.6-69 with the proper modifies:
the same modifies have been imported in this new kernel serie 3.8 together with a lot of general improvments...
We like preparing all kernels in a way that these can be installed and used from the old to the newest distros
Naturally, this is only a first attempt to prepare srpms that can produce kernels suited also for OpenMandriva:
and so, we invite all the cooker boys to try this new kernel 3.8.1, installing and reporting their feedback about
DOWNLOADS:
Kernel 3.8.1 for OpenMandriva 2013.0 - 64bit - Click link below to see if already / still available (*)
Kernel 3.8.1 for OpenMandriva 2013.0 - 32bit - Click link below to see if already / still available (*)
You can also add the folder as a repository, where you would find all upcoming versions of Kernel 3.8
urpmi-addmedia Kernel_38x http://abf.rosalinux.ru/downloads/kernels_38x_personal/repository/cooker/x86_64/main/release/
urpmi.addmedia Kernel_38x http://abf.rosalinux.ru/downloads/kernels_38x_personal/repository/cooker/i586/main/release/
Please start testing 3.8.1 and reporting your experiences to MIB forum
bye, NicCo
NicCo
Kernel 3.8.2 nrj QL for ROSA 2012 2012.1, MDV2010 2011 2013
Сообщение NicCo »
Kernel 3.8.2 nrj & nrjQL for ROSA 2012.0 2012.1, MDV2010 2011 and cooker openmandriva 2013
Today we are aligning with the "latest stable kernel" v 3.8.2
%changelog
* Mon Mar 11 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.8.2-1
+ update to 3.8.2 stable (80 fixes all over)
+ Patch added from ZEN:
- Virtual (SCSI) HBA for Virtual CD emulation module
+ update to the patches:
- AUFS3 to 3.8 20130310
- TOI to 3.8.2 20130310
+ some spec cleanup for cooker
+ defconfigs updated for VHBA, enable for x86/x86_64, disable for ARM
* Sun Mar 10 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.8.1-69
We have tested it with some famous virtualization software like:
Now we have main 5 flavours available, precisely the ones I'm testing:
MORE INFO:
Kernel 3.8.2 for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3819
Kernel 3.8.2 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3820
%ifarch %{ix86}
DOWNLOADS:
Kernel 3.8.2 for OpenMandriva 2013.0 - 64bit - Click link below to see if already / still available (*)
Kernel 3.8.2 for OpenMandriva 2013.0 - 32bit - Click link below to see if already / still available (*)
Please start testing 3.8.2 and reporting your experiences to MIB forum
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA, Mandriva & Cooker ^now 3.8.2
Сообщение NicCo »
Important News to use properly Kernel 3.8 with new working drivers
Read Here: > http://mib.pianetalinux.org/forum/viewt ... 477#p21477
NicCo
Re: Kernel Farm for Linux ROSA, Mandriva & Cooker ^now 3.8.3
Сообщение NicCo »
Kernel 3.8.3 nrj & nrjQL for ROSA 2012.0 2012.1, MDV2010 2011 and cooker openmandriva 2013
Today we are aligning with the "latest stable kernel" v. 3.8.3
before updating kernel, if you use proprietary drivers is better updating them...
About new video drivers for kernel 3.8, we suggest reading
> http://mib.pianetalinux.org/forum/viewt ... 508#p21508
Changelog Kernel 3.8.3 MIB
%changelog
* Fri Mar 15 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.8.3-69
+ update to 3.8.3 stable (144 fixes all over)
+ Imported "Build kernel-headers in here" from OpenMandriva kernel
- drop Haswell id fixup: gpu-drm-i915-Fix-Haswell-CRW-PCI-IDs.patch
+ patches new entries are placed in /extras folder:
- kernel-esfq.patch
- kernel-inittmpfs.patch
- btrfs-lz4-3.8-20130314.patch
- ureadahead-3.8-20130314.patch
+ patches updated:
- AUFS3 to 3.8 20130315
- TOI to 3.8.3 20130315
- VHBA 3.8 20130314
+ NRJ 4, scripts v 1.5:
- nrjQL_server & nrjQL_server_computing: dynticks enable to save energy
-desktop, -laptop, -netbook, -realtime, -server
MORE INFO:
Kernel 3.8.3 for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3824
Kernel 3.8.3 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3825
%ifarch %{ix86}
DOWNLOADS:
Kernel 3.8.3 for OpenMandriva 2013.0 - 64bit - Click link below to see if already / still available (*)
Kernel 3.8.3 for OpenMandriva 2013.0 - 32bit - Click link below to see if already / still available (*)
Please start testing 3.8.3 and reporting your experiences to MIB forum
bye, NicCo
NicCo
LTS Kernel 3.0.69 nrj & nrjQL for ROSA Marathon 2012.0
Сообщение NicCo »
LTS Kernel 3.0.69 nrj and nrjQL for ROSA Marathon 2012.0 & Mandriva 2010 2011
Today we are aligning with the "latest stable kernel" 3.0.69
of the LTS 3.0 series, the most suited for ROSA Marathon...
Please, test:
- the new nrj-laptop flavours behaviour
MORE INFO:
Kernel 3.0.69 for ROSA Marathon 2012.0 & Mandriva 2010 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3826
Kernel 3.0.69 nrjQL for ROSA Marathon 2012.0 & MDV 2010 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=3827
Changelog >
%changelog
* Sat Mar 16 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.0.69-1
+ update to 3.0.69-1
- enabled BFQ (Disk I/O sched) on all nrj flavours
- updated create_configs with some cleanup & fixes
- enabled again ARM arch in in create_config script
- enabled NRJ PREEMPT mode in all -laptop flavours
- moved some patches in their proper patch folders
- Kernel 3.0 for mdv 2010.2, 2011.0, cooker, rosa.lts2012.0, rosa2012.1
- This is -1 (mainline serie), with official kernel sources and addons,
* Fri Feb 22 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.0.66-1
+ update to 3.0.66-1
- update BFQ (Disk I/O scheduler) to v6 for kernel 3.0
* Thu Jan 24 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.0.60-1
+ update to 3.0.60
- spec/scripts/patches now are model V3 like kernel 3.6.11
- more info and description > /3.0.60-rosa1/queue/news.txt
Please start testing 3.6.69 and reporting your experiences to MIB forum
Последний раз редактировалось NicCo 30 мар 2013, 13:45, всего редактировалось 2 раза.
NicCo
Kernel 3.8.4 nrj & nrjQL for ROSA 2012 2012.1, MDV 2010 2011
Сообщение NicCo »
Kernel 3.8.4 nrj & nrjQL for ROSA 2012 2012.1, MDV 2010 2011 & Cooker
Today we are aligning with the "Latest Stable Kernel ": kernel 3.8.4 https://www.kernel.org/
now there are available only the kernel-nrj-desktop-3.8.4 and kernel-nrjQL-desktop-3.8.4,
for rosa 2012.o, 2012.1 and cooker
but later today, ABF permitting, there should be available laptop, netbook, realtime, server
MORE INFO:
Kernel 3.8.4 for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3835
Kernel 3.8.4 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3836
Please start testing any desktop kernel 3.8.4: report your experiences to MIB forum
bye, NicCo
And here can give the answers?
Or theme only for informations?
NicCo
Сообщение NicCo »
VictorR2007 писал(а):And here can give the answers?
I have answered positively to your request to update this place
I have answered positively to Kazancev request / suggestion
but I attend this forum not too frequently... (not daily) - so it's better use MIB for feedback and requests
bye, NicCo
Последний раз редактировалось NicCo 29 мар 2013, 17:29, всего редактировалось 8 раз.
NicCo
Kernel 3.8.5 nrj & nrjQL for ROSA 2012 2012.1, MDV 2010 2011
Сообщение NicCo »
Kernel 3.8.5 nrj & nrjQL for ROSA 2012 2012.1, MDV 2010 2011 & Cooker
Today we are aligning with the "Latest Stable Kernel ": kernel 3.8.5 https://www.kernel.org/
now there are available only the kernel-nrj-desktop-3.8.5 and kernel-nrjQL-desktop-3.8.5,
for rosa 2012.0, 2012.1 and cooker
MORE INFO:
Kernel 3.8.5 for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3840
Kernel 3.8.5 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3841
Please start testing any desktop kernel 3.8.5: report your experiences to MIB forum
bye, NicCo
Последний раз редактировалось NicCo 30 мар 2013, 00:02, всего редактировалось 2 раза.
NicCo
LTS Kernel 3.2.42 nrj for ROSA Marathon 2012
Сообщение NicCo »
Hi,
Today we are aligning with the "Latest Stable Kernel of LTS 3.2 series" > Kernel 3.2.42
now there are available only the kernel-nrj-desktop-3.2.42 for ROSA Marathon (2012.0)
but tomorrow, ABF permitting, there should be available laptop, netbook, realtime, server
MORE INFO:
Kernel 3.2.42 for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3842
Please start testing any desktop kernel 3.2.42: report your experiences to MIB forum
bye, NicCo
Последний раз редактировалось NicCo 30 мар 2013, 13:43, всего редактировалось 2 раза.
NicCo
LTS Kernel 3.4.38 nrj & nrjQL for ROSA Marathon 2012
Сообщение NicCo »
Hi,
Today we are aligning with the "Latest Stable Kernel of LTS 3.4 series" > Kernel 3.4.38
actually for ROSA Marathon (2012.0) there are available the following flavours:
-nrj-desktop, -nrj-netbook, and -server
-nrj-QL-desktop, -nrjQL-laptop, -nrjQL-netbook, -nrjQL-realtime, -nrjQL-server
MORE INFO:
Kernel 3.4.38 for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3843
Kernel 3.4.38 nrjQL for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3844
Please start testing any desktop kernel 3.4.38: report your experiences to MIB forum
bye, NicCo
Последний раз редактировалось NicCo 08 апр 2013, 11:08, всего редактировалось 2 раза.
NicCo
Re: Kernel Farm for Linux ROSA, Mandriva & Cooker ^now 3.8.6
Сообщение NicCo »
Hi,
Today we are aligning with the "Latest Stable Kernel ": kernel 3.8.6 https://www.kernel.org/
Thanks to the request and/or suggestion of oiram73,
I have added 'experimental' Reiser4 FS, please, test this new feature!
now there are available only the kernel-nrj-desktop-3.8.6 and kernel-nrjQL-desktop-3.8.6,
but in few hour, ABF permitting, there should be available laptop, netbook, realtime, server
MORE INFO:
Kernel 3.8.6 for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3863
Kernel 3.8.6 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3864
Please start testing any desktop kernel 3.8.6: report your experiences to MIB forum
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA, Cooker & Mandriva ^now 3.8.7
Сообщение NicCo »
Hi,
Today we are aligning with the "Latest Stable Kernel ": kernel 3.8.7 https://www.kernel.org/
I have added 'experimental' ZSwap, please, test this new feature!
INFO : > zswap: compressed swap caching > Zswap: Compressed Swap Caching For Linux
now there are available only the kernel-nrj-desktop-3.8.7 and kernel-nrjQL-desktop-3.8.7,
MORE INFO:
Kernel 3.8.7 for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3874
Kernel 3.8.7 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3875
Please start testing any desktop kernel 3.8.7: report your experiences to MIB forum
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA, Cooker & Mandriva ^now 3.8.8
Сообщение NicCo »
Hi,
Today we are aligning with the "Latest Stable Kernel ": kernel 3.8.8 https://www.kernel.org/
now there are available only the kernel-nrj-desktop-3.8.8 and kernel-nrjQL-desktop-3.8.8,
MORE INFO:
Kernel 3.8.8 for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3877
Kernel 3.8.8 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3878
Please start testing any desktop kernel 3.8.8: report your experiences to MIB forum
bye, NicCo
NicCo
Re:Kernel Farm for Linux ROSA, Cooker & Mandriva ^now 3.8.12
Сообщение NicCo »
Hi,
Today we are aligning with the "Latest Kernel 3.8.x": now is kernel 3.8.12
Availability: full for ROSA 2012.0, 2012.1 and cooker, in 32 & 64bit arch
soon will be available only kernel-nrj-desktop and kernel-nrjQL-desktop
later today or early tomorrow, there should be available:
- 5 different flavours: nrj-desktop, nrj-laptop, mrj-netbook, nrj-realtime, server
- 5 different flavours nrjQL-desktop, nrjQL-laptop, nrjQL-netbook, nrjQL-realtime, nrjQL-server
(it's possible to import srpm and build different flavour like 32-pae enabled or any other cpu oriented)
MORE INFO:
Kernel 3.8.12 for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3918
Kernel 3.8.12 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3919
Kernel 3.8.12 vanilla for ROSA2012 2012.1, MDV2010/11 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3920
Please start testing any kernel flavour 3.8.12: report your experiences to MIB forum
bye, NicCo
NicCo
Re:Kernel Farm for Linux ROSA, Cooker & Mandriva ^now 3.8.13
Сообщение NicCo »
Hi,
Today we are aligning with the "Latest Kernel 3.8.x": now is kernel 3.8.13
soon will be available only -nrj-desktop, -nrjQL-desktop, -vanilla, -rt
MORE INFO:
Kernel 3.8.13 for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3925
Kernel 3.8.13 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3926
Kernel 3.8.13 vanilla for ROSA2012 2012.1, MDV2010/11 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3927
Below, examples of rpm file names for new kernel-vanilla
kernel-vanilla-3.8.13-1.src.rpm
kernel-vanilla-3.8.13-1omv-1-1-omv2013.0.i586.rpm
kernel-vanilla-devel-3.8.13-1omv-1-1-omv2013.0.i586.rpm
kernel-vanilla-devel-latest-3.8.13-1-omv2013.0.i586.rpm
kernel-vanilla-doc-3.8.13-1-omv2013.0.noarch.rpm
kernel-vanilla-latest-3.8.13-1-omv2013.0.i586.rpm
kernel-vanilla-source-3.8.13-1omv-1-1-omv2013.0.noarch.rpm
kernel-vanilla-source-latest-3.8.13-1-omv2013.0.noarch.rpm
Kernel 3.8.13 RT for ROSA2012 2012.1, MDV2010/11 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3928
Below, examples of rpm file names for new kernel-rt
kernel-rt-3.8.13-rt8.1.src.rpm
kernel-rt-3.8.13-rt8.1omv-1-1-omv2013.0.i586.rpm
kernel-rt-devel-3.8.13-rt8.1omv-1-1-omv2013.0.i586.rpm
kernel-rt-devel-latest-3.8.13-rt8.1-omv2013.0.i586.rpm
kernel-rt-doc-3.8.13-rt8.1-omv2013.0.noarch.rpm
kernel-rt-latest-3.8.13-rt8.1-omv2013.0.i586.rpm
kernel-rt-source-3.8.13-rt8.1omv-1-1-omv2013.0.noarch.rpm
kernel-rt-source-latest-3.8.13-rt8.1-omv2013.0.noarch.rpm
Please start testing any kernel flavour 3.8.13: report your experiences to MIB forum
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA, Cooker & Mandriva ^now 3.8.1
Сообщение NicCo »
We have a newborn kernel... called rtQL or RTQL (RT with nrjQL)
READ MORE:
Kernel rtQL 3.8.13 for ROSA2012 2012.1, MDV2010/11 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3939
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA, Cooker & OMA ^now rtQL 3.8.1
Сообщение NicCo »
Kernel 3.9: What's New? - WIP > Soon for ROSA and Cooker...
READ MORE:
http://mib.pianetalinux.org/forum/viewt ... =38&t=3943
bye, NicCo
NicCo
Kernel Farm for Linux ROSA, Cooker & OMA ^now vanilla 3.9.1
Сообщение NicCo »
Kernel vanilla 3.9.1 for ROSA2012 2012.1, MDV2010/11 cooker
READ MORE:
http://mib.pianetalinux.org/forum/viewt ... =38&t=3944
bye, NicCo
Последний раз редактировалось NicCo 28 май 2013, 12:01, всего редактировалось 1 раз.
NicCo
Kernel Farm for Linux ROSA, Cooker & OMA ^now Vanilla 3.9.4
Сообщение NicCo »
Kernel vanilla 3.9.4 for ROSA2012 2012.1, MDV2010/11 cooker
READ MORE:
http://mib.pianetalinux.org/forum/viewt ... =38&t=3946
(Kernel nrj & nrjQL preparation has started since a while, work in progress, should be available in mid June)
bye, NicCo
NicCo
Kernel Farm for Linux ROSA, Cooker & OMA ^ Vanilla 3.10 rc3
Сообщение NicCo »
Kernel vanilla 3.10 rc3 for ROSA2012 2012.1, MDV2010/11 cooker
Kernel 3.10: Feature set defined - Soon for ROSA & cooker...
http://mib.pianetalinux.org/forum/viewt ... =38&t=3947
READ MORE:
http://mib.pianetalinux.org/forum/viewt ... =38&t=3949
bye, NicCo
Последний раз редактировалось NicCo 29 май 2013, 17:58, всего редактировалось 3 раза.
NicCo
Kernel Farm for Linux ROSA, Cooker & OMA ^now is LTS 3.0.80
Сообщение NicCo »
Today we are aligning with the "Latest Stable Kernel of LTS 3.0 series" > Kernel 3.0.80
now there are available only the kernel-nrj-desktop-3.0.80 for ROSA Marathon X1 (2012.0)
MORE INFO:
Kernel 3.0.80 for ROSA Marathon X1 (2012.0)
http://mib.pianetalinux.org/forum/viewt ... =38&t=3950
Kernel 3.0.80 nrjQL for ROSA Marathon X1 (2012.0)
http://mib.pianetalinux.org/forum/viewt ... =38&t=3951
For ROSA Marathon we'll build Kernels LTS: 3.0, 3.2, 3.4, and all the latest kernels up to the 3.10 series
For ROSA Fresh we are building all Kernel versions starting only from the 3.6 up to the most recent series
For old distro, we are maintaining build compatibility: you can also rebuild for your Mandriva 2010 and 2011
Please start testing any desktop kernel 3.0.80: report your experiences to MIB forum
bye, NicCo
Последний раз редактировалось NicCo 29 май 2013, 17:57, всего редактировалось 2 раза.
NicCo
Kernel Farm for Linux ROSA, Cooker & OMA ^now is LTS 3.2.45
Сообщение NicCo »
Today we are aligning with the "Latest LTS Kernel 3.2.x": now is kernel 3.2.45
I remind You that LTS 3.2 is the only kernel to have long support upto 2016, while 3.0/3.4 ends in 2013/2014
Availability: only for ROSA Marathon X1 2012.0:
now it's available the kernel-nrj-desktop-3.2.45
then, later or tomorrow, we will rebuild upto 3 different flavours: > -nrj-desktop, -nrj-netbook, -server
MORE INFO:
Kernel 3.2.45 for ROSA Marathon X1 (2012.)
http://mib.pianetalinux.org/forum/viewt ... =38&t=3952
Please start testing any desktop kernel 3.2.45: report your experiences to MIB forum
bye, NicCo
NicCo
Kernel Farm for Linux ROSA, Cooker & OMA ^LTS 3.0.80, 3.2.45
Сообщение NicCo »
Today we are aligning with the "Latest LTS Kernel 3.4.x": now is kernel 3.4.47
now are available all the flavours that we rebuild for it
MORE INFO:
Kernel 3.4.47 for ROSA Marathon X1 (2012.)
http://mib.pianetalinux.org/forum/viewt ... =38&t=3953
Kernel nrjQL 3.4.47 for ROSA Marathon X1 (2012.)
http://mib.pianetalinux.org/forum/viewt ... =38&t=3954
Please start testing any desktop kernel 3.4.47: report your experiences to MIB forum
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA, Cooker & OMA ^LTS 3.0.80, 3.
Сообщение NicCo »
About Kernel-rt
Kernel-rt 3.8.13-rt10 for ROSA2012 2012.1, mdv10/11 cooker
Kernel rt version 3.8.13 with the -rt10 patch
http://mib.pianetalinux.org/forum/viewt ... 147#p22147
About new "hybrid Kernel rtQL" (or RTQL)
Kernel-rtQL 3.8.13-rt10 for ROSA2012 2012.1, mdv10/11 cooker
Kernel rtQL version 3.8.13 with -rt10 patch and the TOI full enabled
http://mib.pianetalinux.org/forum/viewt ... 146#p22146
Having all these 3 versions, is usefull only because help us to check and verify better
all the progresses and eventual regressions from the latest versions -rt8 to upto -rt10
i.e.lately has been reported by GvM that rt9 had a regression with a module of vmware
we hope that this newest -rt10 is working well for vmware vms and for everything else...
DOWNLOADS: as usual the packages will be here:
http://abf-downloads.rosalinux.ru/kernels_38x_personal/
If You try and test some of these realtime kernels,
please, post Your feedback to the above MIB links
NicCo
Kernel Farm for Linux ROSA, Cooker & OMA ^nrj & nrjQL 3.9.1
Сообщение NicCo »
Hi,
Today we are finally completing the first version of new serie "Latest Kernel 3.9.x":
right now is incoming the first kernel 3.9.1 (as reference point), ASAP will follow the most recent 3.9.5
We've received some good suggestions, and all of them have been accepted...
%changelog
* Tue Jun 11 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.9.1-1
+ update to 3.9.1 stable
- all the defconfigs have been prepared for 3.9 series
- all the patches have been updated for the 3.9 series
- update kernel specs
- update kernel scripts
- on mainline nrj kernels we apply again > create_configs-withBFQ
- We've received some good suggestions, and all have been accepted
- 1> suggestions and requests received by Per Øyvind Karlsen (POK)
  * TOI (tuxonice) was only in laptop/netbook, now in all flavours
  * CONFIG_PM_AUTOSLEEP=y
  * CONFIG_SFI =m
  * CONFIG_BLK_DEV_DRBD=m
  * # CONFIG_DRBD_FAULT_INJECTION is not set
  * CONFIG_HW_RANDOM_TIMERIOMEM=m
  * CONFIG_DRM_VIA=m
  * CONFIG_FB_ATY128_BACKLIGHT=y
  * CONFIG_USB_RIO500=m
  * CONFIG_DRM_VMWGFX_FBCON=y
  * CONFIG_SND_PCSP=m
  * CONFIG_SND_HDA_POWER_SAVE_DEFAULT=10
  * CONFIG_SND_AC97_POWER_SAVE_DEFAULT=10
- 2> suggestions from an advanced user to A.Burmashev
  * CONFIG_TCP_CONG_ADVANCED=y
  * CONFIG_TCP_CONG_BIC=m
  * CONFIG_TCP_CONG_CUBIC=y
  * CONFIG_TCP_CONG_WESTWOOD=m
  * CONFIG_TCP_CONG_HTCP=m
  * CONFIG_TCP_CONG_HSTCP=m
  * CONFIG_TCP_CONG_HYBLA=m
  * CONFIG_TCP_CONG_VEGAS=m
  * CONFIG_TCP_CONG_SCALABLE=m
  * CONFIG_TCP_CONG_LP=m
  * CONFIG_TCP_CONG_VENO=m
  * CONFIG_TCP_CONG_YEAH=m
  * CONFIG_TCP_CONG_ILLINOIS=m
  * CONFIG_DEFAULT_CUBIC=y
  * # CONFIG_DEFAULT_RENO is not set
- Kernel 3.9 for mdv 2010.2, 2011.0, cooker, rosa.lts2012.0, rosa2012.1
Availability: it will be full for ROSA 2012.0, 2012.1 and cooker, in 32 & 64bit arch
soon will be available only -nrj-desktop, -nrjQL-desktop, while later today there should be available:
You can also verify the "build status" in realtime, here from ABF:
https://abf.rosalinux.ru/kernels_39x/Ke ... uild_lists
MORE INFO:
Kernel 3.9.1 nrj for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3970
Kernel 3.9.1 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3971
Kernel 3.9.1 vanilla for ROSA2012 2012.1, MDV2010/11 cooker
Kernel 3.9.1 -rt & rtQL for ROSA2012 2012.1, MDV2010/11 cooker
- I remind You that for 'odd' number kernel versions, -rt and rtQL not available
Please start testing any kernel flavour 3.9.1: report your experiences to MIB forum
bye, NicCo
NicCo
Kernel Farm for Linux ROSA, Cooker & OMA ^ nrj & nrjQL 3.9.5
Сообщение NicCo »
Hi,
Today we are aligning again with the "Latest Stable Kernel: 3.9.5"
MORE INFO:
Kernel 3.9.5 nrj for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3976
Kernel 3.9.5 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3977
Kernel 3.9.5 vanilla for ROSA2012 2012.1, MDV2010/11 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3978
Kernel 3.9.5 -rt & rtQL for ROSA2012 2012.1, MDV2010/11 cooker
Please start testing any kernel flavour 3.9.5: report your experiences to MIB forum
bye, NicCo
NicCo
Kernel Farm for Linux ROSA, Cooker & OMA ^ vanilla 3.10 rc5
Сообщение NicCo »
Hi,
Kernel 3.10 rc5 is available for ROSA Marathon, Fresh and also Cooker
Kernel vanilla 3.10 rc5 ROSA2012 2012.1, MDV2010/11 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3979
These first test are important expecially for ROSA Marathon, where there is an LTS kernel serie:
3.10.x is very important, the reason is that's the most probable candidate to be the next LTS kernel,
while the maintainance for LTS Kernel 3.0.x should be finished by this year (october/november 2013)
In my marathon x64, kernel 3.10 series (in that early development status) install and runs just fine...
It would be possible, in the 2014 year or later, to move on this newest LTS Kernel 3.10 for Marathon,
or to propose it as a valid alternative with all possibilities to update it for some years to come...
(naturally we need to update also all the proprietary drivers with compatible versions)
WORK IN PROGRESS
After Kernel 3.10 rc5, I'm already preparing for sending to ABF:
-1) a fixed version of kernel 3.8.13 (release 3.8.13-2):
getting all suggestions by POK, and by other forum user (reported by A.B)
-2) kernel 3.9.6 in all their usual flavours (nrj & nrjQL & vanilla series)
bye, NicCo
NicCo
Kernel Farm for Linux ROSA & OM Cooker:^ nrj & vanilla 3.9.6
Сообщение NicCo »
Hi,
Today we are aligning again with the "Latest Stable Kernel: 3.9.6"
MORE INFO:
Kernel 3.9.6 nrj for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3984
Kernel 3.9.6 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3986
Kernel 3.9.6 vanilla for ROSA2012 2012.1, MDV2010/11 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=3985
Kernel 3.9.6 -rt & rtQL for ROSA2012 2012.1, MDV2010/11 cooker
Please start testing any kernel flavour 3.9.6: report your experiences to MIB forum
bye, NicCo
NicCo
Kernel Farm for Linux ROSA & OM Cooker^ 3.8.13 REL2
Сообщение NicCo »
Hi,
Today we are completing the first maintaining release (Release 2) of Kernel 3.8.13 (EOL)
Alexander Burmashev писал(а):
"I'm very interested to the new just added patch: scsi_storvsc_avoid-usage-of-WRITE_SAME.patch
That's particularly very important for me.
Actually, ROSA installation on Hyper-V machines may be blocked by a bug, and this patch should fix!
I guess it is not so critical for cooker, since it may be used 3.9 kernels ( where it is fixed upstream )."
MORE INFO: about Release 2 of Kernels 3.8.13
Kernel NRJ 3.8.13 for ROSA 2012 2012.1 & MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... 262#p22262
Kernel nrjQL 3.8.13 for ROSA 2012 2012.1 MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... 261#p22261
Kernel vanilla 3.8.13 for ROSA2012 2012.1, MDV2010/11 cooker
http://mib.pianetalinux.org/forum/viewt ... 273#p22273
http://mib.pianetalinux.org/forum/viewt ... 272#p22272
http://mib.pianetalinux.org/forum/viewt ... 271#p22271
Please start testing any kernel flavour 3.8.13 2th release: report your experiences to MIB forum
bye, NicCo
NicCo
Kernel Farm for Linux ROSA & OM Cooker^ 3.8.13 RTQL11
Сообщение NicCo »
When an 'OS' must go beyond the actual paradigms...
Kernel rtQL (rt + nrjQL) description, targets and goals
Hi.
Today, here the new version of Kernel-rt 3.8.13 (EOL) with the latest -rt11 patchset
(the main source for -rt11 > https://www.kernel.org/pub/linux/kernel ... ts/rt/3.8/)
MORE INFO:
Kernel-rtQL 3.8.13 with -rt11 and -rtQL for ROSA 2012.0, 2012.1 & OM cooker
http://mib.pianetalinux.org/forum/viewt ... 277#p22277
Kernel-rt 3.8.13 with -rt11 patch for ROSA 2012.0, 2012.1 & OM cooker
http://mib.pianetalinux.org/forum/viewt ... 276#p22276
Please start testing kernel rt and/or rtQL flavour 3.8.13 > report your experiences to MIB forum
bye, NicCo
NicCo
Kernel Farm for Linux ROSA & OM Cooker^ 3.10 rc6
Сообщение NicCo »
Hi,
Kernel vanilla 3.10 rc6 for ROSA 2012.0 2012.1, OM cooker, mdv2010 2011
Kernel 3.10 rc6 is available for ROSA Marathon, Fresh and also for Cooker
I hope that someone of you, can try this, test, report his feedback about...
MORE INFO:
Kernel vanilla 3.10 rc6 ROSA2012 2012.1, cooker MDV2010/11
http://mib.pianetalinux.org/forum/viewt ... =38&t=3987
%changelog
* Sun Jun 16 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.10.0-0-rc6.1
+ kernel 3.10 rc6
- verified defconfigs and removed all warnings build related to kconfig
- new key value request > # CONFIG_ATH9K_LEGACY_RATE_CONTROL is not set
- (this kernel is still in early development stadium)
- Kernel 3.10 for mdv 2010.2, 2011.0, cooker, rosa.lts2012.0, rosa2012.1
- This kernel has no MIB or other patches, and no third-party drivers
WORK IN PROGRESS:
After Kernel 3.10 rc6, that is what I'm already working on for sending to ABF:
  • Kernel 3.9.7
  • LTS Kernel monthly maintainance:
    • preparing Kernel nrj and nrjQL for LTS Kernel 3.0 (3.0.83 or 3.0.84)
    • apply suggestions by POK and all those reported by A..Burmashev
  • NEW KERNELS (first time ports for these flavours):
    • preparing Kernel vanilla for LTS Kernel 3.0.xx
    • preparing new Kernel rt for LTS Kernel 3.0.xx
    • preparing new Kernel rtQL for LTS Kernel 3.0.xx
  • the same work and new kernel flavours for LTS Kernels 3.2.x & 3.4.x series
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker^ 3.10.0 rc6
Сообщение NicCo »
NEW KERNEL PROJECT
Kernel-nrj-vanilla? > let's try ASAP next kernels with NRJ!
http://mib.pianetalinux.org/forum/viewt ... =38&t=3992
NicCo
Kernel Farm for Linux ROSA & OM Cooker^ 3.8.13 REL3
Сообщение NicCo »
Hi
http://mib.pianetalinux.org/forum/viewt ... 328#p22328
"I inform You all, that kernel 3.8 serie, with EOL 3.8.13 is not dead for us:
you surelly noticed we have maintained it to a newer release as -2, but
we'll continue to support and update with all new fixes, patches, ecc...
The main reason, apart that 3.8 is the official kernel for ROSA Fresh is:
kernels "even" numbered are more supported, the only ones with the rt
so it's NOT possible having the RT/RTQL kernel for 3.9,
I remind you that rt branch is supported for so long time...
an example -rt for kernel 3.0 has reach rt108 version"
New release 3 of all our usual 5 kernel flavours are available:
You can read about the changelogs, clicking the below links
Kernel nrjQL 3.8.13 - release 3
http://mib.pianetalinux.org/forum/viewt ... 357#p22357
Kernel NRJ 3.8.13 - release 3
http://mib.pianetalinux.org/forum/viewt ... 358#p22358
Kernel-rtQL 3.8.13 -rt11 - release 3 (rtQL2)
http://mib.pianetalinux.org/forum/viewt ... 355#p22355
later will follow the update of vanilla, and the first release
of new kernel-vanilla-nrj-desktop & kernel-vanilla-nrj-laptop
bye, NicCo
NicCo
Kernel Farm for Linux ROSA & OM Cooker^ nrj QL vanilla 3.9.7
Сообщение NicCo »
Hi,
Today we are aligning again with the "Latest Stable Kernel: 3.9.7"
MORE INFO:
Kernel 3.9.7 nrj for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4002
Kernel 3.9.7 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4003
Kernel 3.9.7 vanilla for ROSA2012 2012.1, MDV2010/11 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4004
Kernel 3.9.7 vanilla-nrj-desktop for ROSA2012 2012.1, MDV2010/11 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4007
Kernel 3.9.7 vanilla-nrj-laptop for ROSA2012 2012.1, MDV2010/11 cooker
Kernel 3.9.7 -rt & rtQL for ROSA2012 2012.1, MDV2010/11 cooker
Please start testing any kernel flavour 3.9.7: report your experiences to MIB forum
bye, NicCo
NicCo
Kernel Farm for Linux ROSA & OM Cooker^ RT12 rt & rtQL 3.8.13
Сообщение NicCo »
Hi.
Date: Fri, 21 Jun 2013 17:37:54 +0200 > Kernel-3.8.13-RT12 > http://www.spinics.net/lists/kernel/msg ... cSoSnyB6e0
ASAP, here are available for You, dear ROSA customers, kernel rt and our even more powerfull hybrid rtQL
Dear RT Folks,
I'm pleased to announce the 3.8.13-rt12 release.
changes since v3.8.13-rt11:
- added the missing "acpi/rt: Convert acpi_gbl_hardware lock back to a
raw_spinlock_t", reported by Steven.
- added an option to the i915 driver to disable the expensive wbinvd. A
warning is printed once on RT if wbinvd is not disabled to let the
user know about this problem. This problem was decoded by Carsten Emde.
- disable the trace_i915_gem_ring_dispatch() tracepoint on RT. Earlier
it was reported that using this trace point leads to "scheduled while
atomic" warnings. To fix this I pulled out the function in question out
of the tracing macro. Upstream complains that this leads to too much
overhead if the tracing point is not enabled so not it is gone.
kernel-rt 3.8.13 rt12.1
http://mib.pianetalinux.org/forum/viewt ... 391#p22391
kernel-rtQL 3.8.13 rt12.1
http://mib.pianetalinux.org/forum/viewt ... 393#p22393
Please start testing any kernel flavour 3.8.13 RT12: report your experiences to forum
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker^ 3.10 rc7 vanilla & vanilla-nrj-x
Сообщение NicCo »
Hi to all.
Today we are aligning again with the > "mainline: 3.10-rc7"
https://abf.rosalinux.ru/kernels_3_10x/ ... uild_lists
MORE INFO:
Kernel vanilla 3.10 rc7 ROSA 2012.0 2012.1, OM 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4008
Kernel-vanilla-nrj-desktop & -laptop 3.10-rc7 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4009
Please start testing any kernel flavour 3.10 rc7: report your experiences to MIB forum
bye, NicCo
NicCo
Kernel Farm for Linux ROSA & OM Cooker^ 3.9.8 nrj nrjQL vanilla & vanilla-nrj-x
Сообщение NicCo »
Right now, we are completing the latest version of new serie "Latest Kernel 3.9.x": really ASAP 3.9.8
MORE INFO:
Kernel 3.9.8 for ROSA 2012.0 2012.1 & Mdv 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4016
Kernel 3.9.8 nrjQL for ROSA 2012 2012.1, MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4017
Kernel vanilla 3.9.8 for ROSA2012 2012.1 & OM 2010/11 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4018
Kernel-vanilla-nrj-desktop 3.9.8 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4019
Kernel-vanilla-nrj-laptop 3.9.8 for ROSA & OM
Kernel 3.9.8 -rt & rtQL for ROSA2012 2012.1, MDV2010/11 cooker
Please start testing any kernel flavour 3.9.8: report your experiences to forum
bye, NicCo
NicCo
Kernel Farm for Linux ROSA & OM Cooker^ 3.0.84, 3.2.48, 3.4.51
Сообщение NicCo »
Hi,
Monthly June update for all LTS Kernel: 3.0.84, 3.2.48, 3.4.51
Kernel 3.0.84 for ROSA Marathon 2012.0
http://mib.pianetalinux.org/forum/viewt ... =38&t=4025
Kernel nrjQL 3.0.84 for ROSA Marathon 2012.0
http://mib.pianetalinux.org/forum/viewt ... =38&t=4026
Kernel 3.2.48 for ROSA Marathon 2012.0
http://mib.pianetalinux.org/forum/viewt ... =38&t=4027
Kernel 3.4.51 for ROSA Marathon 2012.0
http://mib.pianetalinux.org/forum/viewt ... =38&t=4028
Kernel nrjQL 3.4.51 for ROSA Marathon 2012.0
http://mib.pianetalinux.org/forum/viewt ... =38&t=4029
bye, NicCo
NicCo
Kernel Farm for Linux ROSA & OM Cooker^ 3.10.0 vanilla
Сообщение NicCo »
Hi,
finally we can install also the first kernel 3.10.0 stable plain vanilla...
MORE INFO:
Kernel vanilla 3.10.0 ROSA 2012.0 2012.1 OM2013.0 and cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4034
bye, NicCo
Последний раз редактировалось NicCo 04 июл 2013, 14:37, всего редактировалось 1 раз.
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker^ 3.10.0 vanilla nrj desktop/laptop
Сообщение NicCo »
Hi,
finally we can install also the first stable kernel 3.10.0 vanilla with -nrj-desktop & -nrj-laptop flavours
from MIB Topic: > Differences from plain vanilla:
Ondemand governor (instead of Performance), full Preempt, RCU preempt & boost, 300Hz for laptop
For the complete nrj and nrjQL series is necessary waiting the availability of all the features patches,
these would be available at the end of July, or the early August
MORE INFO:
Kernel-vanilla-nrj-desktop & -laptop 3.10.0 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4036
bye, NicCo
Последний раз редактировалось NicCo 04 июл 2013, 21:59, всего редактировалось 1 раз.
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker^ 3.8.13 -rt -rtQL -rt13
Сообщение NicCo »
Hi,
for a " ROSA RTOS "... > http://en.wikipedia.org/wiki/Real-time_operating_system
Kernel-rtQL 3.8.13 with -rt13 and ROSA -rtQL patches for ROSA Marathon 2012.0, ROSA Fresh 2012.1 and OM cooker
MORE INFO:
Kernel-rt 3.8.13 -rt13 for ROSA 2012 2012.1, OM cooker
http://mib.pianetalinux.org/forum/viewt ... 492#p22492
Kernel-rtQL 3.8.13 -rt13 for ROSA2012 2012.1 OM cooker
http://mib.pianetalinux.org/forum/viewt ... 493#p22493
Please start testing kernel rt & rtQL 3.8.13 -rt13: report your experiences to forum
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker^ 3.9.9 vanillas
Сообщение NicCo »
Hi,
today we will sync with kernel stable 3.9.9, first we start with all the vanilla flavours
For complete nrj and nrjQL series it should prepared and would be available for tomorrow
from MIB Topic: > Differences from plain vanilla to vanilla nrj xxx:
MORE INFO:
Kernel vanilla 3.9.9 for ROSA2012 2012.1 & OM 2010/11 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4038
Kernel-vanilla-nrj-desktop 3.9.9 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4039
Kernel-vanilla-nrj-laptop 3.9.9 for ROSA & OM
Please start testing any kernel flavour 3.9.9: report your experiences to forum
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ 3.9.9 nrj and nrjQL series
Сообщение NicCo »
Hi,
Right now, we are completing the availability of the latest version of kernel serie 3.9 : 3.9.9
in afew hours there should be available:
MORE INFO:
Kernel nrj 3.9.9 for ROSA 2012 2012.1 & OM 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4041
Kernel nrjQL 3.9.9 for ROSA 2012 2012.1 MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4042
These have been already released yesterday
Kernel 3.9.9 -rt & rtQL for ROSA2012 2012.1, MDV2010/11 cooker
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ solved issue between -RT & Pulseaudio!
Сообщение NicCo »
IMPORTANT NEWS: for all the professional users of ROSA -rt & rtQL kernel series
our kernel tester, Mario Moles, found a proper way to resolve the issue happening between a kernel rt / rtQL with pulseaudio:
here we encountered the issue for the first time
http://mib.pianetalinux.org/forum/viewt ... 055#p22055
here, our latest best kernel for a ROSA RTOS
here, the solution found by our tester
http://mib.pianetalinux.org/forum/viewt ... 509#p22509
oiram73 писал(а):The problem with pulseaudio and kernel-rt is solved:
https://launchpad.net/kxstudio/+announcement/6610
Simply edit the file /etc/pulse/daemon.conf with rlimit-rttime = -1
Now pulseaudio no more crashes!
:D :) ;) :lol:
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel 3.9.10
Сообщение NicCo »
Kernel nrj 3.9.10 for ROSA 2012 2012.1 & OM 2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4050
Kernel nrjQL 3.9.10 for ROSA 2012 2012.1 MDV2010 2011 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4051
Kernel vanilla 3.9.10 for ROSA2012 2012.1 & OM2010/11 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4052
Kernel-vanilla-nrj-desktop 3.9.10 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4053
Kernel-vanilla-nrj-laptop 3.9.10 for ROSA & OM
Kernel 3.9.10 -rt & rtQL for ROSA2012 2012.1, MDV2010/11 cooker
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ rt & rtQL v.14 kernel 3.8.13
Сообщение NicCo »
Hi,
for a " ROSA RTOS and/or OM Lx RTOS"... > http://en.wikipedia.org/wiki/Real-time_operating_system
Kernel-rtQL 3.8.13 with -rt14 and ROSA -rtQL patches for ROSA 2012.0, ROSA 2012.1 and OM cooker ...
MORE INFO:
Kernel-rt 3.8.13 -rt14 for ROSA 2012 2012.1, OM cooker
http://mib.pianetalinux.org/forum/viewt ... 545#p22545
Kernel-rtQL 3.8.13 -rt14 for ROSA2012 2012.1 OM cooker
http://mib.pianetalinux.org/forum/viewt ... 546#p22546
Warnings:
1> to solve the pulseaudio crashes with an rt and/or rtQL kernels:
2> It has been reported a bad freeze issue with ATI fglrx driver...
Suggestions:
If you are an ATI video card owner, use Xorg open ATI driver, otherwise:
1> it's better NOT install kernel RT and/or RTQL (problem with crashes)
2> don't install kernel > 3.9 (es. 3.10): recent fglrx blob dont support it!
NicCo
Сообщение NicCo »
Kernel vanilla 3.10.1 for ROSA 2012.0 2012.1, OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4058
Kernel-vanilla-nrj-desktop 3.10.1 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4059
Kernel-vanilla-nrj-laptop 3.10.1 for ROSA & OM
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ 3.9.11 nrj nrjQL & vanillas
Сообщение NicCo »
We are completing the availability of the latest and last version of kernel serie 3.9.x : 3.9.11
Note: https://lwn.net/Articles/560036/
"this is the LAST 3.9-stable kernel. It is now dead, end-of-life"
Availability: it will be full for ROSA 2012.0, 2012.1 and cooker, in 32 & 64bit arch,
soon will be available:
plus the most recent flavours named: kernel-vanilla, kernel-vanilla-nrj-desktop, kernel-vanilla-nrj-laptop
MORE INFO:
Kernel vanilla 3.9.11 for ROSA2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4063
Kernel-vanilla-nrj-desktop 3.9.11 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4064
Kernel-vanilla-nrj-laptop 3.9.11 for ROSA & OM
Kernel nrj 3.9.11 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4065
Kernel nrjQL 3.9.11 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4066
Kernel 3.9.11 -rt & rtQL for ROSA2012 2012.1, MDV2010/11 cooker
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ 3.10.1 nrj nrjQL & vanillas
Сообщение NicCo »
Finally all the patches that we need to prepare full kernel 3.10 are available:
The adventure with new nrj & nrjQL 3.10 begins today with our first 3.10.1!
Note: now there are some build issues, but only for Marathon x86_64:
we hope to fix soon so we can try kernel 3.10 also for 2010.0 x86_64!
(The build issues are related to gcc 4.6.1 version in ROSA Marathon...)
Availability: for ROSA 2012.0, 2012.1 and cooker, in 32 & 64bit arch,
MORE INFO:
Kernel nrj 3.10.1 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4069
Kernel nrjQL 3.10.1 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4070
a few days ago, on 20 July, we released all kernel vanilla for 3.10.1
Kernel 3.10.1 -rt & rtQL for ROSA2012 2012.1, MDV2010/11 cooker
- rt patches have not yet been released, -rt and rtQL not available
Testing proprietary drivers (ATI and NVidia) for kernel 3.10 series
now these drivers are available only for ROSA Fresh 2012.1...
http://mib.pianetalinux.org/forum/viewt ... 586#p22586
Please start testing any kernel flavour 3.10.1: report your experiences to forum
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ LTS 3.0.88, 3.2.49, 3.4.55
Сообщение NicCo »
Hi,
Monthly July update for all LTS Kernel: 3.0.88, 3.2.49, 3.4.55
Kernel 3.0.88 for ROSA Marathon 2012.0
http://mib.pianetalinux.org/forum/viewt ... =38&t=4072
Kernel nrjQL 3.0.88 for ROSA Marathon 2012.0
http://mib.pianetalinux.org/forum/viewt ... =38&t=4073
Kernel 3.2.49 for ROSA Marathon 2012.0
http://mib.pianetalinux.org/forum/viewt ... =38&t=4074
Kernel 3.4.55 for ROSA Marathon 2012.0
http://mib.pianetalinux.org/forum/viewt ... =38&t=4075
Kernel nrjQL 3.4.55 for ROSA Marathon 2012
http://mib.pianetalinux.org/forum/viewt ... =38&t=4076
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ nrj & nrjQL 3.10.4
Сообщение NicCo »
Today we are synced again with latest stable kernel with nrj & nrjQL 3.10.4
MORE INFO:
Kernel nrj 3.10.4 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4077
Kernel nrjQL 3.10.4 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4078
the vanilla flavours and the kernel rt /rtQL will follow soon...
Последний раз редактировалось NicCo 04 авг 2013, 14:29, всего редактировалось 2 раза.
NicCo
Сообщение NicCo »
finally also vanillas are here:
Kernel vanilla 3.10.4 for ROSA 2012.0 2012.1, OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4079
Kernel-vanilla-nrj-desktop & -laptop 3.10.4 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4080
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ nrj nrjQL 3.10.5
Сообщение NicCo »
Today we are synced again with latest stable kernel with nrj & nrjQL 3.10.5:
if everything is ok, should be published by ABF in about 4 hours since now
Availability: for ROSA 2012.1 and cooker, in 32 & 64bit arch,
Note: now there are some build issues, but only for Marathon:
we hope to fix soon so we can try kernel 3.10 also for 2012.0!
MORE INFO:
Kernel nrj 3.10.5 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4083
Kernel nrjQL 3.10.5 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4084
the kernel vanilla and rt /rtQL will follow soon...
Последний раз редактировалось NicCo 12 авг 2013, 23:09, всего редактировалось 3 раза.
sylvainsjc
Operating system: ROSA Linux
Сообщение sylvainsjc »
Hi NicCo,
All fine there :beer:
[root@rosa ~]# inxi -F
System:    Host: rosa.lxde.acer Kernel: 3.10.5-nrj-laptop-1rosa i686 (32 bit)
           Desktop LXDE (Openbox 3.5.0) Distro: RosaDesktop.Fresh 2012.1 belka
Machine:   System: Acer product: Aspire 1620 version: 0100 serial: LXA2605038436C2EC9M000
           Mobo: Acer model: Aspire 1620 version: Rev serial: LXA2605038436C2EC9M000
           Bios: Phoenix version: V1.15 date: 06/28/04
CPU:       Single core Intel Pentium 4 CPU (-HT-) cache: 512 KB flags: (sse sse2)
           Clock Speeds: 1: 1500.00 MHz 2: 1500.00 MHz
Graphics:  Card: Advanced Micro Devices [AMD] nee ATI M9+ 5C61 [Radeon Mobility 9200 (AGP)]
           X.org: 1.13.4 drivers: v4l,radeon tty size: 144x53 Advanced Data: N/A for root
Audio:     Card: Advanced Micro Devices [AMD] nee ATI IXP150 AC'97 Audio Controller driver: snd_atiixp
           Sound: Advanced Linux Sound Architecture ver: k3.10.5-nrj-laptop-1rosa
Network:   Card-1: Advanced Micro Devices [AMD] nee ATI IXP200 3COM 3C920B Ethernet Controller
           IF: N/A state: N/A speed: N/A duplex: N/A mac: N/A
           Card-2: Intel PRO/Wireless LAN 2100 3B Mini PCI Adapter driver: ipw2100
           IF: eth1 state: up mac: 00:04:23:8c:e0:b6
           Card-3: Realtek RTL-8139/8139C/8139C+ driver: 8139too
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: 00:0a:e4:59:e7:1a
Drives:    HDD Total Size: 40.0GB (12.3% used) 1: /dev/sda IC25N040ATCS05 40.0GB
Partition: ID: / size: 12G used: 3.5G (32%) fs: rootfs ID: / size: 12G used: 3.5G (32%) fs: ext4
           ID: /home size: 22G used: 1.2G (6%) fs: ext4 ID: swap-1 size: 3.09GB used: 0.00GB (0%) fs: swap
           ID: swap-2 size: 0.09GB used: 0.00GB (0%) fs: swap ID: swap-3 size: 0.09GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 49.0C mobo: 48.0C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 130 Uptime: 6 min Memory: 142.1/497.2MB Client: Shell inxi: 1.7.24
[root@rosa ~]#
NicCo
Сообщение NicCo »
Kernel vanilla 3.10.5 for ROSA 2012.0 2012.1, OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4090
Kernel-vanilla-nrj-desktop & -laptop 3.10.5 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4091
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ OpenMandriva 2013.0
Сообщение NicCo »
IMPORTANT INFO
Since kernel 3.10.6 the ABF rebuilds will be 4 (+omv 2013.0)
http://mib.pianetalinux.org/forum/viewt ... =38&t=4094
Since few days Cooker has been forked into two branches: cooker and openmandriva2013.0 (frozen for omv20130.0 release),
so, since this 3.10.6 our rebuilds will follow this scheme and will be made be also for cooker and openmandriva2013.0 both...
People with OpenMandriva 2013.0 LX testing new kernels 3.10 should remove the previous kernel cooker repo and replace it with the new openmandriva2013.0
(naturally the above suggestion is only for those who want to stay with stable OpenMandriva 2013.0, not for the followers of cooker developments...)
urpmi.removemedia Kernel_3.10
urpmi.addmedia Kernel_3.10 http://abf-downloads.rosalinux.ru/kernels_3_10x_personal/repository/openmandriva2013.0/x86_64/main/release/
urpmi.addmedia Kernel_3.10 http://abf-downloads.rosalinux.ru/kernels_3_10x_personal/repository/openmandriva2013.0/i586/main/release/
There are already available all the vanillas 3.10.6:
http://mib.pianetalinux.org/forum/viewt ... =38&t=4092
http://mib.pianetalinux.org/forum/viewt ... =38&t=4093
while all the nrj & nrjQL flavours would follow soon...
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ nrj & nrjQL 3.10.6
Сообщение NicCo »
Today we are synced again with latest stable kernel with nrj & nrjQL 3.10.6
With this version we have rebuilt also another 2 flavours, 32bit with PAE for PC with 4Gb or more ram:
  • kernel-nrj-desktop-pae
  • kernel-nrj-laptop-pae
  • kernel-nrjQL-desktop-pae
  • kernel-nrjQL-laptop-pae
- 7 different flavours: nrj-desktop, nrj-desktop-pae, nrj-laptop, nrj-laptop-pae, mrj-netbook, nrj-realtime, server
- 7 different flavours nrjQL-desktop, nrjQL-desktop-pae, nrjQL-laptop, nrjQL-laptop-pae, nrjQL-netbook, nrjQL-realtime, nrjQL-server
MORE INFO:
Kernel nrj 3.10.6 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4095
Kernel nrjQL 3.10.6 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4096
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ 3.10.6 nrj & nrjQL +pae
Сообщение NicCo »
Info about Kernel 3.10 series availability on ROSA Marathon
>>> http://mib.pianetalinux.org/forum/viewt ... =38&t=4097
I have great News!
The fix should reach official Marathon updates very soon, perhaps in few hours:
so, since next stable version 3.10.7 we'll publish again kernel 3.10 for Marathon!
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ 3.10.7 nrj & nrjQL +pae
Сообщение NicCo »
Today we are synced again with latest stable kernel with nrj & nrjQL 3.10.7
MORE INFO:
Kernel nrj 3.10.7 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4099
Kernel nrjQL 3.10.7 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4100
NicCo
Сообщение NicCo »
A new hybrid creature, called Kernels ONE, is borning now...
More Info:
http://mib.pianetalinux.org/forum/viewt ... =38&t=4101
NicCo
Сообщение NicCo »
Kernels ONE development is almost done:
and you can also try & test it since now...
Kernel-3.10.8-rc1-ONE - STATUS: rc1
http://mib.pianetalinux.org/forum/viewt ... 686#p22686
It's already possible testing - add the ONE personal repo
http://abf-downloads.rosalinux.ru/kerne ... epository/
More Info from the begin:
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel-3.10.8 ONE - STATUS: final
Сообщение NicCo »
Kernel-3.10.8-70-ONE
STATUS: final (if builds & testing will be ok, like we hope)
> http://mib.pianetalinux.org/forum/viewt ... 688#p22688
REBUILD IN PROGRESS...:
Final version of NRJ V5 with stable LTS Kernel 3.10.8
> https://abf.rosalinux.ru/kernels_one/Ke ... uild_lists
SRPMS for Kernel 3.10.8 with the "old model" (nrj v4) have been also already prepared
nrj > kernel-3.10.8-1.src.rpm > https://abf.rosalinux.ru/kernels_3_10x/ ... uild_lists
nrjQL > kernel-3.10.8-69.src.rpm > https://abf.rosalinux.ru/kernels_3_10x/ ... uild_lists
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel-3.10.9 ONE - STATUS: final
Сообщение NicCo »
Kernel-3.10.9-70-ONE
> http://mib.pianetalinux.org/forum/viewt ... 693#p22693
Final version of NRJ V5 with stable LTS Kernel 3.10.9
SRPMS for Kernel 3.10.9 with the "old model" (nrj v4) have been also already prepared
Kernel nrj 3.10.9 for ROSA 2012 2012.1 & OM 2013 cooker Kernel
http://mib.pianetalinux.org/forum/viewt ... =38&t=4112
Kernel nrjQL 3.10.9 for ROSA 2012 2012.1 & OM 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4114
NicCo
Сообщение NicCo »
Hi
Reported here: http://bugs.rosalinux.ru/show_bug.cgi?id=2530
A bad issue on latest kernel versions 3.10.8 and 3.10.9 caused an "it hangs on boot" in the most of cases,
the problem has been already successfully fixed, an the new fixed rpms for 3.10.9 are already available...
More Info: Kernel 3.10.8/9 nrj-desktop-1rosa 64 bits
http://mib.pianetalinux.org/forum/viewt ... f=6&t=4113
(kernel 3.10.8 is defective and will be soon removed from the ABF repos...)
About the latest rebuilds generating all the fixed 3.10.9 RPMS
http://mib.pianetalinux.org/forum/viewt ... 719#p22719
http://mib.pianetalinux.org/forum/viewt ... 720#p22720
Various Helps and News for Kernel 3.10 series
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel-3.10.10 ONE - STATUS: final
Сообщение NicCo »
It's time of the latest lts kernel 3.10.10 into several -nrj / -nrjQL / -vanilla / -rt / different flavours!
Availability complete: for ROSA 2012.1, ROSA 2012.0, omv2013.0 and cooker, in 32 & 64bit arches both:
perhaps :wink: , it's the most complete and featured lts kernel series ever... 8) 8) 8)
- 7 different nrj flavours:
  • nrj-desktop,
  • nrj-desktop-pae,
  • nrj-laptop,
  • nrj-laptop-pae,
  • nrj-netbook,
  • nrj-realtime,
  • server
- 7 different nrjQL flavours:
  • nrjQL-desktop,
  • nrjQL-desktop-pae,
  • nrjQL-laptop,
  • nrjQL-laptop-pae,
  • nrjQL-netbook,
  • nrjQL-realtime,
  • nrjQL-server
(It's possible to import srpm and build different flavour like 32-pae enabled or any other cpu oriented)
and also...
- 3 different vanilla flavours:
  • kernel-vanilla,
  • kernel-vanilla-nrj-desktop,
  • kernel-vanilla-nrj-laptop
- 2 different RT flavours
  • kernel-rt,
  • kernel-rtQL
MORE INFO:
Kernel nrj 3.10.10 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4125
Kernel nrjQL 3.10.10 for ROSA 2012 2012.1 & OM 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4126
A new hybrid: Kernels One (NRJ V5) is borning, right now...
http://mib.pianetalinux.org/forum/viewt ... 771#p22771
Kernel vanilla 3.10.10 ROSA 2012.0 2012.1, OM 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4127
Kernel-vanilla-nrj-desktop 3.10.10 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4128
Kernel-vanilla-nrj-laptop 3.10.10 for ROSA & OM
Kernel-rt 3.10.10 -rt7 for ROSA 2012 2012.1, OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4129
Kernel-rtQL 3.10.10 -rt7 for ROSA 2012 2012.1, OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4130
Various Helps and Suggestions for Kernel 3.10 series
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel 3.11.0
Сообщение NicCo »
Kernel 3.11: the adventure begins...
General Info about Kernel 3.11:
http://kernelnewbies.org/Linux_3.11
http://www.phoronix.com/scan.php?page=s ... Linux+3.11
First ROSA and OMV availability:
Kernel vanilla 3.11.0 ROSA 2012.0 2012.1 OMV 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4134
After the first installation and the successfull reboot on my reference development PC with ROSA Marathon x64
$ uname -a
Linux localhost.localdomain 3.11.0-vanilla.1rosa.lts #1 SMP Wed Sep 4 19:32:23 CEST 2013 x86_64 x86_64 x86_64 GNU/Linux
ROADMAP for Kernel 3.11 developments:
- Today: I've prepared the plain kernel-vanilla, and installed on my PC
- Tomorrow I hope to complete; vanilla-nrj-desktop & vanilla-nrj-laptop
For the complete and full featured nrj and nrjQL series, we need to wait
for all the patchset availability:
I try to guess for about the end of September, or for early/mid October.
Please start testing, if possible, any kernel vanilla 3.11:
report Your experiences and feedback to the forums...
thanks for your attention
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ new Kernel 3.11.0
Сообщение NicCo »
Kernel-vanilla-nrj-desktop & -laptop 3.11.0 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4135
DIfferences from plain vanilla:
Ondemand governor (instead of Performance), full Preempt, RCU preempt & boost, BFQ as I/O scheduler,
  • kernel-vanilla-nrj-desktop 3.11.0
  • kernel-vanilla-nrj-laptop 3.11.0
    • 300Hz for laptop instead than 1000Hz
Goals: having the chance to try ASAP new kernels, also with full Preemption enabled "NRJ v4 mode", in this way we can start trying the NRJ kernels much before, even up to one or two months earlier than usual, we can also verify if some patch used in mainline featured kernel may cause regressions or unstability, it's a good bench test for developing...
Kernel behaviour: like a "kernel-vanilla" plus a faster disk I/O, a greater PowerSaving, a better multitasking and a better multimedia desktop experience!
%changelog
* Thu Sep 05 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.11.0
+ kernel 3.11.0 stable - it's the flavour > kernel-vanilla-nrj-desktop
- This flavour differs from "kernel-vanilla" for the following adds:
  * PREEMPT
  * PREEMPT RCU TREE
  * RCU BOOST
  * ONDEMAND as default (vanilla is "PERFORMANCE")
  * BFQ is added and configured as the default I/O
- Kernel 3.11 for mdv 2010.2, 2011.0, cooker, rosa.lts2012.0, rosa2012.1
- MIB (Mandriva International Backports) - http://mib.pianetalinux.org/
- This kernel has none MIB or other patches and none third-party drivers
* Sun Sep 01 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.10.10
+ kernel 3.10.10 stable - it's the flavour > kernel-vanilla-nrj-desktop
%changelog
+ kernel 3.11.0 stable - it's the flavour > kernel-vanilla-nrj-laptop
  * CONFIG_HZ=300 (instead than HZ=1000)
  * PREEMPT
  * PREEMPT RCU TREE
  * RCU BOOST
+ kernel 3.10.10 stable - it's the flavour > kernel-vanilla-nrj-laptop
Re: Kernel Farm for Linux ROSA & OM Cooker ^ new Kernel 3.11.0 (Vanilla NRJ now with BFQ!)
What is the difference kernel "nrj-laptop" from the "nrj-desktop"?
NicCo
Сообщение NicCo »
Question:
PastorDi писал(а):What is the difference kernel "nrj-laptop" from the "nrj-desktop"?
Answer:
I presume your question is related to latest kernel-vanilla-nrj-xxx, so:
It was already explained above, in my description msg, look carefully
NicCo писал(а): DIfferences from plain vanilla:
Using 300 Hz instead of 1000 Hz into the CFS scheduler, should result in the most of laptop PCs:
  • CONS: less responsiveness
  • PROS: less cpu temp and greater battery lasting, especially true in idle times
The other Kernels, the nrj and nrjQL series, have many more diffs from desktop to laptop...
it's possible, in the next versions, add also these kernel keys to the new vanilla-nrj-laptop
bye, NicCo
Thanks.
NicCo
Сообщение NicCo »
Monthly update for all ROSA Marathon LTS Kernel: 3.0.94, 3.2.50, 3.4.60 (WIP) - - August 2013 edition
Kernel 3.0.94
Kernel 3.0.94 for ROSA Marathon 2012.0 & Mandriva 2010 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=4136
Since this version 3.0.94 was enabled again BFQ as default I/O scheduler for all nrj flavours
Kernel nrjQL 3.0.94 for ROSA Marathon 2012.0 & MDV 2010 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=4137
Kernel 3.2.50
Kernel 3.2.50 for ROSA Marathon 2012.0 & Mandriva 2010 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=4138
Since this version 3.2.50: BFQ was added and configured as default I/O scheduler for all nrj flavours
Kernel 3.4.60
Kernel 3.4.60 for ROSA Marathon 2012.0 & MDV 2010 2011.0
http://mib.pianetalinux.org/forum/viewt ... =38&t=4140
Since this version 3.4.60: BFQ was added and configured as default I/O scheduler for all nrj flavours
Kernel nrjQL 3.4.60 for ROSA Marathon 2012.0 & MDV 2010 2011
http://mib.pianetalinux.org/forum/viewt ... =38&t=4141
NicCo
Сообщение NicCo »
Kernel 3.10.11: https://lwn.net/Articles/566063/
Changelog:
"Linux kernel 3.10.11 introduces ARM, x86, and PowerPC fixes, as well as many updated drivers, including Nouveau, i915, iSCSI, and a few wireless ones."
ROADMAP for Kernel 3.10.11 rpms availability:
- Today: right now, I'am preparing kernel flavours nrj and nrjQL series
- Tomorrow I hope to complete the rt/rtQL flavours, will follow vanillas...
I remind You that the newest kernel serie 3.11 should be considered only for testing on cooker developments, furthermore I inform You that our recent proprietary drivers for Fresh (ati, nvidia, broadcom) must be yet properly patched, or replaced with newer version, to work with kernels 3.11
Work in progress...
Последний раз редактировалось NicCo 12 сен 2013, 17:24, всего редактировалось 1 раз.
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ new Kernel 3.10.11 LTS series
Сообщение NicCo »
perhaps, the most complete and featured lts kernel series ever...
  • nrj-desktop,
  • nrj-desktop-pae,
  • nrj-laptop,
  • nrj-laptop-pae,
  • nrj-netbook,
  • nrj-realtime,
  • server
  • nrjQL-desktop,
  • nrjQL-laptop,
  • nrjQL-laptop-pae,
  • nrjQL-netbook,
  • nrjQL-realtime,
  • nrjQL-server
Since previous version we have rebuilt also another 2 flavours, 32bit with PAE for PC with 4Gb or more ram
and also...
  • kernel-vanilla,
2 different RT flavours:
  • kernel-rt,
  • kernel-rtQL
MORE INFO:
Kernel nrj 3.10.11 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4150
Kernel nrjQL 3.10.11 for ROSA 2012 2012.1 & OM 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4151
http://mib.pianetalinux.org/forum/viewt ... 829#p22829
Kernel vanilla 3.10.11 ROSA 2012.0 2012.1, OM 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4146
Kernel-vanilla-nrj-desktop 3.10.11 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4147
Kernel-vanilla-nrj-laptop 3.10.11 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4148
http://mib.pianetalinux.org/forum/viewt ... =38&t=4149
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel 3.11.1 LTS vanilla: Full availability!
Сообщение NicCo »
Kernel 3.11.1
you can consider this as a development branch for testing & cooker purposes,
you can use it in stable distro like rosa maratton & fresh or into omv2013.0:
please, be carefull that actually there're none proprietary drivers suited for it
Today I've prepared the new Kernel 3.11.1, into 3 vanilla flavours: now ABF is building in progress...
VANILLA LEGENDA
kernel-vanilla:
this is the pure vanilla, none patches, clean configs (no PREEMPT, ecc.)
kernel-vanilla-nrj-desktop:
none patches but it's the closest to kernel-nrj-desktop for his internal configs
kernel-vanilla-nrj-laptop:
none patches but it's the closest to kernel-nrj-laptop for his internal configs
Последний раз редактировалось NicCo 17 сен 2013, 15:05, всего редактировалось 1 раз.
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel lts 3.10.12
Сообщение NicCo »
Kernel 3.10.12
brief desciption from Softpedia:
"Linux kernel 3.10.12 brings mostly networking fixes, especially for IPv4 and IPv6 protocols, and lots of updated or patched drivers, also networking related."
An important fix: in all rt / rtQL and nrj & nrjQL, there will be an important patch requested by A.B.
from the changelog:
- add patch linux-fixuClibc.patch
- (it was recommended by Alexander Burmashev: uClibc builds on kernel 3.10
- we have a lot of such stuff in cooker, especially recommended for cooker...)
about the issue:
https://lkml.org/lkml/2013/7/12/9
http://landley.net/hg/aboriginal/file/1 ... libc.patch
%changelog
* Mon Sep 16 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.10.12-rt7.rtQL1
+ kernel 3.10.12 (LTS) - realtime kernel with -rt7 plus rtQL1 patches
- add patch 115: linux-fixuClibc.patch
- drop patches 113 and 114
- This kernel contains also some other patches to improve the hw support
MORE INFO
Kernel vanilla 3.10.12 ROSA 2012.0 2012.1, OM 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4157
Kernel-vanilla-nrj-desktop & -laptop 3.10.12 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4158
Kernel-rt 3.10.12 -rt7 for ROSA 2012 2012.1, OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4159
Kernel-rtQL 3.10.12 -rt7 for ROSA 2012 2012.1, OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4160
Kernel nrj 3.10.12 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4161
Kernel nrjQL 3.10.12 for ROSA 2012 2012.1 & OM 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4162
http://mib.pianetalinux.org/forum/viewt ... 858#p22858
bye, NicCo
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel lts 3.10.13 nrj, nrjQL, vanilla and rt series
Сообщение NicCo »
Kernel 3.10.13
http://www.spinics.net/lists/stable/msg20936.html
%changelog
* Fri Sep 27 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.10.13-69
+ update to 3.10.13 stable
- update patch
- * /patches-QL/tuxonice-for-linux-3.10.13-2013-09-27.patch
- The rel -1 (mainline serie), with official kernel sources and addons,
- the rel -69 is used for development and the experimental flavours,
- the rel -70 is merge of mainline & experimental flavours in ONE srpm
- Yin & Yang (69) release - a very complete but experimental flavours...
Availability: right now, ABF is building in progress nrj & nrjQL...
Kernel nrj 3.10.13 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4178
Kernel nrjQL 3.10.13 for ROSA 2012 2012.1 & OM 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4179
http://mib.pianetalinux.org/forum/viewt ... 931#p22931
Kernel vanilla 3.10.13 ROSA 2012.0 2012.1, OM 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4185
Kernel-vanilla-nrj-desktop & -laptop 3.10.13 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4186
Последний раз редактировалось NicCo 08 окт 2013, 23:58, всего редактировалось 2 раза.
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel lts 3.10.14 nrj, nrjQL, vanilla and rt series
Сообщение NicCo »
Kernel 3.10.14
http://www.spinics.net/lists/stable/msg21438.html
Kernel nrj 3.10.14 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4189
Kernel nrjQL 3.10.14 for ROSA 2012 2012.1 & OM 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4190
all the others kernel flavours will follow soon...
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel lts 3.10.15 nrj, nrjQL, vanilla and rt series
Сообщение NicCo »
Kernel 3.10.15
http://lwn.net/Articles/569540/
%changelog
* Sat Oct 05 2013 Nicolo' Costanza <abitrules@yahoo.it> 3.10.15-69
+ update to 3.10.15 stable
- sync: new /patches
- modified all the defconfigs for:
  * # CONFIG_FW_LOADER_USER_HELPER is not set
  * # CONFIG_X86_GOLDFISH is not set
- update the patch for TOI:
  * /patches-QL/tuxonice-for-linux-3.10.15-2013-10-06.patch
- change CK1 and BFS patches from the previous one only patch named:
  * /patches-QL/ck1-3.10.patch (that has been dropped)
- to 7 single patches exploded from it
  * /patches-QL/3.10-sched-bfs-440.patch
  * /patches-QL/bfs440-grq_urwlocks.patch
  * /patches-QL/ck1-version.patch
  * /patches-QL/hz-default_1000.patch
  * /patches-QL/hz-no_default_250.patch
  * /patches-QL/kconfig-expose_vmsplit_option.patch
  * /patches-QL/preempt-desktop-tune.patch
  * /patches-QL/urw-locks.patch
Kernel nrj 3.10.15 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4202
Kernel nrjQL 3.10.15 for ROSA 2012 2012.1 & OM 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4203
Kernel-rt 3.10.15 -rt9 for ROSA 2012 2012.1, OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4198
Kernel-rtQL 3.10.15 -rt9 for ROSA2012 2012.1 OMV2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4199
Kernel vanilla 3.10.15 ROSA 2012.0 2012.1, OM 2013.0 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4200
Kernel-vanilla-nrj-desktop & -laptop 3.10.15 for ROSA & OM
http://mib.pianetalinux.org/forum/viewt ... =38&t=4201
Kernel 3.10.15 ONE
(A new hybrid: Kernels One (NRJ V5) is borning, right now...)
http://mib.pianetalinux.org/forum/viewt ... 031#p23031
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel lts 3.11.1 nrj, nrjQL
Сообщение NicCo »
Kernel 3.11.1 nrj and nrjQL: Here first full featured release!
I remind to all that kernel 3.11 may be not compatible with your old installed proprietary driver (Ati fglrx, Nvidia, broadcom-wl and all dkms-xxx):
before to try any installation, inform you about driver compatibility, update drivers if available, only after you can install safely new 3.11 kernels!
My first test results:
I use Marathon x64 with all free and open driver, none problems
I've tested VMWare 10 and VMPlayer 6: it works out of the box!
Kernel nrj 3.11.1 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4205
Kernel nrjQL 3.11.1 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4206
For this first version, I've sent to rebuild:
  • kernel-server
  • kernel-nrj-laptop
  • kernel-nrjQL-realtime
bye, NicCo
Последний раз редактировалось NicCo 08 окт 2013, 19:44, всего редактировалось 3 раза.
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel 3.11.1 : finally also nrj and nrjQL
Thank you.
Kernel nrj 3.10.15 very good.
I will try 3.11.1.
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel 3.11.4 : finally also nrj nrjQL and ONE
Сообщение NicCo »
VictorR2007 писал(а):Thank you.
I will try 3.11.1.
Thanks for your feeedback!
I advice You that ABF is rebuilding all new kernels 3.11.4, right now...
https://forums.openmandriva.org/en/disc ... mment_1107
Please, don't complain with me about proprietary driver malfunctioning! I'm testing successfully 3.11, only with all free soft and drivers... :Yahoo!:
The only installed app needing proprietary modules rebuild is VMWare: I've tested VMWare 10 and VMPlayer 6: it works out of the box!
NicCo писал(а):I remind to all that kernel 3.11 may be not compatible with your old installed proprietary driver (Ati fglrx, Nvidia, broadcom-wl and all dkms-xxx):
bye
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel 3.10.15 & 3.11.4 : nrj nrjQL vanilla rt rtQL and ONE
Сообщение NicCo »
Am I allowed to send my own feedback? > if yes...
http://mib.pianetalinux.org/forum/viewt ... 054#p23054
MORE INFO:
Kernel nrj 3.11.4 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4207
Kernel nrjQL 3.11.4 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4208
NicCo
Re: Kernel Farm for Linux ROSA & OM Cooker ^ Kernel 3.10.16 & 3.11.4 : nrj nrjQL vanilla rt rtQL and ONE
Сообщение NicCo »
Kernel 3.10.16
Kernel nrj 3.10.16 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4215
Kernel nrjQL 3.10.16 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4216
Kernel-rt 3.10.16 -rt11 for ROSA 2012 2012.1, OM 2013 cooker
Kernel-rtQL 3.10.16 -rt11 for ROSA 2012 2012.1, OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4217
NicCo
Сообщение NicCo »
Kernel 3.11.6
right now sending to ABF the just released kernel 3.11.6
most builds are in progress...
nrj > https://abf.rosalinux.ru/kernels_3_11x/ ... uild_lists
nrjQL > https://abf.rosalinux.ru/kernels_3_11x/ ... uild_lists
Kernel nrj 3.11.6 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4220
Kernel nrjQL 3.11.6 for ROSA 2012 2012.1 & OM 2013 cooker
http://mib.pianetalinux.org/forum/viewt ... =38&t=4221
%changelog
* Sat Oct 19 2013 Nicolo' Costanza 3.11.6-69
+ update to 3.11.6 stable
- add 'on request' by 'Bero' aka Bernhard Rosenkränzer:
* add: linux-3.11.4-saa716x.patch > driver for SAA7160 based DVB cards
* add: to the /configs/*.config the proper keys for the SAA7160 driver
- add 3.11-haswell-intel_pstate.patch > to support P-state in new Haswell
- add 'on request' by Eugene Shatokhin: if debug > DEBUG_INFO_REDUCED=y
- add /specs folder with 4 kernel.spec, so you can use any other .specs
- drop to cleanups two old and really not used patches:
* /patches-NRJ/kernel-inittmpfs.patch
* /patches-NRJ/vhba-3.8-20130427.patch
- update: tuxonice-for-linux-3.11.6-2013-10-19.patch
- fix: missing XEN configs to all the -server flavours with config_xen();
- small fixes and aestetic cleanups to all the create_configs-* /scripts
Вернуться в «Marathon (ROSA LTS)»
