how to install Epson Stylus all-in-one printer/scanner
rob
Operating system: rosa 12 lxde
Сообщение rob »
I’m running Rosa 12 LXDE from Live USB. Before I decide to installit on my hard disk I want to make sure that my printer/scanner works properly. The Epson stylus DX8450 is not recognized, I tried to install manually but it was not in the list. How should I do this?
Re: how to install Epson Stylus all-in-one printer/scanner
As we can see on THIS page, it should work with gutenprint (printer functionality). Would you like to try this driver and share your results here? Meaning you must install cups&gutenprint and xsane in the live mode and try the printer/scanner. Remember that after rebooting all installed packages will disappear.
rob
Сообщение rob »
I downloaded and installed gutenprint. Installing xsane failed with this essage: urpmi database is locked, process 2819 is already using it (/usr/bin/perl /usr/sbin/drakrpm-edit-media). So still no scanner and no printer.
Well. Could you please boot from scratch into the live mode again and install everything from repos (from GUI)?
rob
Сообщение rob »
I started in LXDE control center:
programs - edit software sources - Add. (default choices)
then
Add/remove programs
- installed Cups 1.4.8, Xsane 0.998, and finally gutenprint 5.2.7
hardware
- setup printer: this choice seems dead(?). There is no respons when I click (or double-) on this button.
- setup scanner: not my Epson in the lists. There is no generic printer or so.
Perhaps the system needs a reboot, but as I'm working in a Live session, all the work is lost on reboot.
In Libreoffice writer there is a generic printer but it gives no output.
I swiched the printer off and on again.
I can start Xsane scanner but the scanner is not recognised.
Strange, strange...
Вернуться в «Marathon (ROSA LTS)»
