Plasma 6 volume plasmoid
erfan
Operating system: Rosa Fresh 13 Plasma 6
Сообщение erfan »
This time I have a wish regarding the volume plasmoid on plasma 6. :)
Often I need to adjust the volume of the system and the apps too, or raise the volume over 100%. On the built-in plasmoid the two are on a separate tab, so, I do not see all elements at the same time and I have to navigate from one tab to the other, to check them. In plasma 5 I have used Win7 Volume Mixer applet – https://store.kde.org/p/1100894/ – to achieve this. But it is not ported to plasma 6.
My questions are:
1. Do you know if somewhere can be found a porting of it to plasma 6? Or ....
2. Rosa developers, contributors are interested in porting this applet to plasma 6, because it has some advantages, functional and visual too, over the built in applet?[/list]
Or, if non of previous is possible ...
3. Could I simply edit some file which controls the built-in volume applet to show the devices and applications tabs in one single place, one under the other? How?
Thank You for Your help!
Вернуться в «Desktop»
