Looking for a GUI Multimedia Converter application
Non-Desktop related topics
linuxlover
Сообщение linuxlover »
Hello guys.I was looking for a GUI multimedia converter such as winff or transmageddon but it is not in the default repos.I tried using arista,but for some unknown reason I can't add files in it for converting. :?
dareksmok
i5-4570 CPU @ 3.20GHz
NVIDIA GeForce GT 1030
8 GB RAM
Re: Looking for a GUI Multimedia Converter application
Сообщение dareksmok »
Home Page - MobileMediaConverter. http://www.miksoft.net/mobileMediaConverter.php
After unpacking the archive: mmc-lin-180.tar.gz
http://www.miksoft.net/products/mmc-older/
Run the program by pressing twice on the file named "mmc".
2013.07.08
mirovideoconverter-3.0.2-1-rosa2012.1.noarch.rpm
http://mrb.mandrivausers.ro/MRB/2012.1/i686/MRB-rpms/
2013.10.16
qeven-0.3.2-4-rosa2012.1.i586.rpm
2013.09.08
urpmi sinthgunt
Последний раз редактировалось dareksmok 13 фев 2014, 00:14, всего редактировалось 4 раза.
ROSA Fresh R10 MATE - 64 bit
dareksmok
8 GB RAM
linuxlover писал(а):Hello guys.I was looking for a GUI multimedia converter such as winff or transmageddon but it is not in the default repos.I tried using arista,but for some unknown reason I can't add files in it for converting.
In this situation
Create Conversion-> Source-> Choose File
dareksmok
8 GB RAM
QWinFF http://qwinff.github.io/ - is a GUI for FFmpeg, a powerful command-line media converter. FFmpeg can read audio and video files in various formats and convert them into other formats. QWinFF provides an intuitive graphical interface and a rich set of presets to help you use ffmpeg easily without having to type a single command. Advanced users can also adjust conversion parameters like bitrate and sample rate in detail.
qwinff-0.1.8-1-rosa2012.1.i586.rpm http://mrb.mandrivausers.ro/MRB/2012.1/i686/MRB-rpms/
