Kicad - update to 9.0.2 version
MikiLinux
Operating system: Rosa13
Сообщение MikiLinux »
Aggiornamento a KiCad 9.0.2 su ROSA 13
Nessun problema riscontrato. Se volete, potete aggiornare il repository ufficiale.
CIao
Update of KiCad 9.0.2 on ROSA 13.
No problems encountered. If you want, you can update the official repository.
KiCAD - Project Manager
KiCAD - Schematic Editor
KiCAD - PCB editor
KiCAD - PCB editor
KiCAD - PCB 3D Visualizer
KiCAD - PCB 3D Rendering
Desktop: Rosa13.2 KDE/Plasma
PC Lab: Rosa13.2 XFCE
Laptop: Rosa13.2 LxQt
https://elettrolinux.com
MikiLinux
Re: Kicad - update to 9.0.2 version
In allegato i file per la compilazione e il packaging.
Enclosed the files for compilation and packaging.
kicad-9.0.2-1.src.zip
Spec file &C.
(570.67 КБ) 253 скачивания
