Установка Virtualbox (решено)
termim
Operating system: SuSE, Rosa
Сообщение termim »
Пытаюсь установить Virtualbox на лаптоп с ядром 6.12 - не находит файл symvers.gz.
Пробовал на ядро 6.10 - нет инклудов в репозитории.
Как победить?
dl termim # dnf in virtualbox
Last metadata expiration check: 0:07:55 ago on Sun 20 Apr 2025 11:57:02 AM EDT.
Dependencies resolved.
Package Architecture Version Repository Size
Installing:
virtualbox x86_64 7.1.6-2 mirror-rosa-x86_64-main 55 M
Installing dependencies:
dkms-virtualbox noarch 7.1.6-2 mirror-rosa-x86_64-main 20 k
kernel-source-virtualbox noarch 7.1.6-2 mirror-rosa-x86_64-main 792 k
Transaction Summary
Install 3 Packages
Total download size: 56 M
Installed size: 193 M
Is this ok [y/N]: y
Downloading Packages:
(1/3): dkms-virtualbox-7.1.6-2-rosa13.noarch.rpm 44 kB/s | 20 kB 00:00
(2/3): kernel-source-virtualbox-7.1.6-2-rosa13.noarch.rpm 142 kB/s | 792 kB 00:05
(3/3): virtualbox-7.1.6-2-rosa13.x86_64.rpm 2.3 MB/s | 55 MB 00:24
Total 2.3 MB/s | 56 MB 00:24
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
Preparing : 1/1
Installing : kernel-source-virtualbox-7.1.6-2.noarch 1/3
Installing : virtualbox-7.1.6-2.x86_64 2/3
Running scriptlet: virtualbox-7.1.6-2.x86_64 2/3
Failed to preset unit: Refusing to operate on linked unit file virtualbox.service
Installing : dkms-virtualbox-7.1.6-2.noarch 3/3
Running scriptlet: dkms-virtualbox-7.1.6-2.noarch 3/3
+ /usr/sbin/dkms --rpm_safe_upgrade add -m virtualbox -v 7.1.6-2
Creating symlink /var/lib/dkms/virtualbox/7.1.6-2/source ->
/usr/src/virtualbox-7.1.6-2
DKMS: add completed.
+ /usr/sbin/dkms --rpm_safe_upgrade build -m virtualbox -v 7.1.6-2
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...(bad exit status: 2)
./vboxbuild /lib/modules/6.12.16-generic-3rosa13-x86_64/build....
/usr/sbin/dkms: line 1452: /var/lib/dkms/virtualbox/7.1.6-2///module/symvers.gz: No such file or directory
DKMS: build completed.
+ /usr/sbin/dkms --rpm_safe_upgrade install -m virtualbox -v 7.1.6-2
vboxdrv.ko.zst:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /lib/modules/6.12.16-generic-3rosa13-x86_64/kernel/3rdparty/vbox/
vboxnetflt.ko.zst:
- Original module
- Installation
vboxnetadp.ko.zst:
- Original module
- Installation
depmod...
DKMS: install completed.
+ /usr/sbin/rmmod vboxnetflt
+ /usr/sbin/rmmod vboxnetadp
+ /usr/sbin/rmmod vboxdrv
+ /usr/sbin/modprobe vboxdrv
+ /usr/sbin/modprobe vboxnetflt
+ /usr/sbin/modprobe vboxnetadp
Running scriptlet: virtualbox-7.1.6-2.x86_64 3/3
ENG: Any host system user who is going to use USB devices from VirtualBox guests
must be a member of vboxusers group. A user can be made a member of the group
vboxusers through the GUI user/group management or at the command line with
sudo usermod -a -G vboxusers username
To enable USB 2.0 and USB 3.0 devices support you need to install VirtualBox
Extension Pack from https://www.virtualbox.org/
To work with shared folders, you also need to add the guest system user to vboxsf group
RUS: Для подключения в виртуальной машине портов USB необходимо добавить
пользователя хост-системы в группу vboxusers.
Это можно сделать либо через графический интерфейс системы, либо в терминале командой
Для включения режима USB 2.0 и USB 3.0 необходимо установить VirtualBox
Extension Pack с сайта https://www.virtualbox.org/
Для работы с общими папками необходимо внести пользователя гостевой системы
в группу vboxsf
/usr/lib/sysusers.d/libvirt-qemu.conf:1: Conflict with earlier configuration for group 'kvm' in /usr/lib/sysusers.d/basic.conf:32, ignoring line.
Installed:
dkms-virtualbox-7.1.6-2.noarch kernel-source-virtualbox-7.1.6-2.noarch virtualbox-7.1.6-2.x86_64
Complete!
dl termim #
Последний раз редактировалось termim 22 апр 2025, 00:36, всего редактировалось 1 раз.
Re: Установка Virtualbox
termim писал(а): 20 апр 2025, 19:20 Пытаюсь установить Virtualbox на лаптоп с ядром 6.12 - не находит файл symvers.gz.
Его давно не наблюдаю.
Vbox и без него работает.
Когда драйвера nvidia с dkms-nvidia устанавливаю, тоже упоминает про symvers.gz,
но и все на этом.
На работу не влияет.
И смотрю, вроде забыли установить
virtualbox-guest-additions
dkms-vboxadditions
termim
Сообщение termim »
VictorR2007 писал(а): 21 апр 2025, 18:58 И смотрю, вроде забыли установить
dkms-vboxadditions
Эти пакеты для гостевых систем и то не для всех нужны. У меня на десктопе они не установлены, а VB работает без проблем.
Sartorius
Сообщение Sartorius »
termim писал(а): 22 апр 2025, 00:23 У меня на десктопе они не установлены, а VB работает без проблем.
И разрешение экрана в гостевой ОС без них корректно изменяется?
termim
Re: Установка Virtualbox (решено)
Сообщение termim »
Для 6.12 проблему решило:
sudo rmmod kvm_amd
А для 6.10 проблема установки остаётся - в репозитории пропал пакет kernel-6.10-generic-devel-6.10.13. Но это терпимо, раз 6.12 работает.
termim
Сообщение termim »
Sartorius писал(а): 22 апр 2025, 00:29 И разрешение экрана в гостевой ОС без них корректно изменяется?
В OpenSUSE и Росе меняется, в других давно не смотрел. Я так понимаю, это уже давно из коробки.
