Aggiornamento/Update - Lame & ffmpeg
MikiLinux
Operating system: Rosa13
Сообщение MikiLinux »
Salve,
in allegato (file spec in formato .zip) gli aggiornamenti di lame (abilitato MP3X) e ffmpeg (4.4.3 -> 5.1.6 - l'aggiornamento non crea conflitti con versioni precedenti) solo per la piattaforma 2021.1.
Al solito verificate/testate/correggete eventuali errori e aggiornate il repositorio.
Hi,
enclosed (specs file, zip format) updates of lame (enabled MP3X) and ffmpeg (4.4.3 -> 5.1.6 - update does not to create conflicts with older versions); these updates only for platform 2021.
As usual checking/correcting/testing any errors and add changes to the repository.
lame-3.100-5.src.zip
(19.2 КБ) 102 скачивания
ffmpeg-5.1.6-1.src.zip
(3.13 КБ) 100 скачиваний
Desktop: Rosa13.2 KDE/Plasma
PC Lab: Rosa13.2 XFCE
Laptop: Rosa13.2 LxQt
https://elettrolinux.com
ffmpeg and other impotant programs not update on stable platform. Update ffmpeg need rebuild all programs that use it, and many program in repo rosa2021.1 not support ffmpeg5
ffmpeg5 and newer in rosa13 (rosa2023.1) only!!!
What you update in lame? in rosa2021.1 mp3x enabled by default.
MikiLinux
irton писал(а): 02 ноя 2024, 04:03 ...and many program in repo rosa2021.1 not support ffmpeg5
Oops ok. I have compiled Audacity with support to avformat 59 (ffmpeg 5), but now i will stop.
Audacity 3.7.0 on 2021.1 with FFMPEG5
But it's always possible to update Audacity to 3.7.0 on 2021.1 platform using avformat58 (ffmpeg4). :-)
irton писал(а): 02 ноя 2024, 04:03 What you update in lame? in rosa2021.1 mp3x enabled by default.
Yep, sorry, my mistake. :-(
MikiLinux писал(а): 02 ноя 2024, 14:25 Oops ok. I have compiled Audacity with support to avformat 59 (ffmpeg 5), but now i will stop.
yes this is one programm, lets go backport all other project from rosa13 to rosa2021.1.
I'm one of the people who fix ffmpeg in rosa13, and this way is hard.
