Salve,
in allegato (file spec in formato .zip) l'aggiornamento dell'editor Bluefish alla versione 2.2.16 solo per la piattaforma 2021.1.
Verificate/testate/correggete eventuali errori e aggiornate il repositorio.
1) Modificato file patch bluefish-2.2.15-shellbang.patch poiché nell'ultima verione:
"The old built-in javascript beautifier has been removed, Bluefish now uses the jsbeautify from your system (if available)."
Pertanto ho aggiunto come dipendenze raccomandate il pacchetto python-jsbeautifier.
Aggiunto shebang al file bluefish-2.2.16/src/plugin_zencoding/zencoding/actions/traverse.py.
2) Aggiunto file patch bluefish-2.2.16-replace-obsolete-macro.patch:
https://sourceforge.net/p/bluefish/code/9101/
3) Rimossa opzione --disable-splash-screen dal configure poiché non più presente.
Hi.
enclosed (spec's file, zip format) Bluefish IDE editor, update only for 2021.1 platform.
Checking/correcting/testing any errors and add the change to the repository.
1) Modified patch file bluefish-2.2.15-shellbang.patch because of:
Then I add python-jsbeautifier in Recommends line (spec file).
Add, also, shebang to the bluefish-2.2.16/src/plugin_zencoding/zencoding/actions/traverse.py file.
2) Add patch file bluefish-2.2.16-replace-obsolete-macro.patch because of:
3) Removed --disable-splash-screen option from the configure because it's no longer available.
2021.1 Aggiornamento Bluefish 2.2.12 -> 2.2.16
- MikiLinux
- Вложения
- bluefish-2.2.16-1.src.zip
- (4.48 КБ) 105 скачиваний
update in 2021.1 and 2023.1
