После запуска
sudo kroko-cli autoinstall
получаю
Объем загрузки: 389 M
Загрузка пакетов:
(1/13): auto-krokodil-filesystem-0.25-1-rosa2021.1.noarch.rpm 107 kB/s | 7.6 kB 00:00
(2/13): egl-wayland-1.1.11-1-rosa2021.1.x86_64.rpm 82 kB/s | 9.3 kB 00:00
(3/13): lib64nvidia-egl-gbm1-1.1.0-2-rosa2021.1.x86_64.rpm 216 kB/s | 18 kB 00:00
(4/13): nvidia525-blacklist-525.116.03-1-rosa2021.1.x86_64.rpm 265 kB/s | 7.1 kB 00:00
(5/13): lib64nvidia-egl-wayland1-1.1.11-1-rosa2021.1.x86_64.rpm 353 kB/s | 32 kB 00:00
(6/13): kernel-modules-nvidia525-6.1-generic-525.116-34563573.104.e5433-rosa2021.1.x86_64.rpm 4.1 MB/s | 42 MB 00:10
(7/13): nvidia525-doc-html-525.116.03-1-rosa2021.1.x86_64.rpm 440 kB/s | 174 kB 00:00
(8/13): nvidia525-dracut-525.116.03-1-rosa2021.1.x86_64.rpm 183 kB/s | 7.4 kB 00:00
(9/13): nvidia525-power-525.116.03-1-rosa2021.1.x86_64.rpm 425 kB/s | 179 kB 00:00
(10/13): nvidia525-wayland-525.116.03-1-rosa2021.1.x86_64.rpm 188 kB/s | 7.0 kB 00:00
(11/13): plasma5-kwin-wayland-nvidia-5.27.8-1-rosa2021.1.noarch.rpm 167 kB/s | 6.1 kB 00:00
(12/13): nvidia525-cuda-opencl-525.116.03-1-rosa2021.1.x86_64.rpm 2.3 MB/s | 42 MB 00:18
[MIRROR] nvidia525-core-525.116.03-1-rosa2021.1.x86_64.rpm: Curl error (28): Timeout was reached for http://mirror.rosalinux.ru/rosa/rosa202 ... x86_64.rpm [Operation too slow. Less than 1000 bytes/sec transferred the last 10 seconds]
[MIRROR] nvidia525-core-525.116.03-1-rosa2021.1.x86_64.rpm: Curl error (28): Timeout was reached for http://mirror.yandex.ru/rosa/rosa2021.1 ... x86_64.rpm [Operation too slow. Less than 1000 bytes/sec transferred the last 10 seconds]
[FAILED] nvidia525-core-525.116.03-1-rosa2021.1.x86_64.rpm: No more mirrors to try - All mirrors were already tried without success
Ошибка: Ошибка при загрузке пакетов:
Cannot download nvidia525-core-525.116.03-1-rosa2021.1.x86_64.rpm: All mirrors were tried
Загруженные пакеты были сохранены в кэше до следующей успешной транзакции.
Вы можете удалить кэшированные пакеты, выполнив «dnf clean packages».
ROSA 2021.1 - x86_64 - Main 129 kB/s | 3.4 kB 00:00
Зависимости разрешены.
Отсутствуют действия для выполнения.
Выполнено!
Уже месяц ничего не получается
Не могу загрузить драйверы для видеокарты NVIDIA [Решено]
pipets@msn.com
Последний раз редактировалось pipets@msn.com 10 янв 2024, 16:21, всего редактировалось 1 раз.
pipets@msn.com
Спасибо.
Отключение антивируса помогло
Антивирус в Linux?..
Это вполне нормально.
Что хочет делать, то и делает со своим компом.
Если хочется установить антивирус для спокойствия, то и правильно.
Для души спокойнее, а это самое главное.
Стресс губит здоровье.
За 8 лет юзания Роса, я 3 раза устанавливал Dr Web для проверки всей системы, вирусов ноль.
