Double Commander в РОСА
Из Bugzilla:
Konstantin Vlasov - создал сборку пакета Double Commander - файловый менеджер, и скоро будет доступен в Contrib репозитории.
At the moment the packages are built and published in my(Konstantin Vlasov) personal repository:
x64 - http://abf.rosalinux.ru/downloads/captainflint_personal/repository/rosa2012lts/x86_64/main/release/
x32 - http://abf.rosalinux.ru/downloads/captainflint_personal/repository/rosa2012lts/i586/main/release/
Sources:
https://abf.rosalinux.ru/captainflint/doublecmd
https://abf.rosalinux.ru/captainflint/libQt4Pas (required by dependencies)
Description of the application (taken from the developer's web site):
Double Commander is a cross platform open source file manager with two panels side by side. It is inspired by Total Commander and features some new ideas.
Here are some key features of Double Commander:
* Unicode support
* All operations working in background
* Multi-rename tool
* Tabbed interface
* Custom columns
* Internal text editor (F4) with syntax hightlighting
* Built in file viewer (F3) to view files of in hex, binary or text format
* Archives are handled like subdirectories. You can easily copy files to and from archives. Supported archive types: ZIP, TAR GZ, TGZ, LZMA and also BZ2, RPM, CPIO, DEB, RAR.
* Extended search function with full text search in any files
* Configurable button bar to start external programs or internal menu commands
* Total Commander WCX, WDX and WLX plug-ins support
* File operations logging
* And more...
Изображение Изображение
