New KDM version is available, fixed issue of long users' lis
Its main graphical component - list of users was completely reworked and rewritten in QML, which increased speed of animation and allowed to implement it like user feed (carousel). Thus the problem of not showing a complete list of users when they do not fit in the width of the screen is solved. Now you can scroll users by closed circle.
You can install it from here:
http://abf.rosalinux.ru/downloads/mur_p ... n/release/
Package name is kdm-4.8.3-3.
Questions and bugreports are welcome.
- sylvainsjc
Re: New KDM version is available, fixed issue of long user l
Great. I'll try it when I'm back home
- sylvainsjc
Well kdm-4.8.3-3 installed; The first boot and shutdown was very very long (don't know why) but the following were normal
I've got only 3 users, I remarks that now it's the full user's name (GECOS) that is proposed instead of the account user's name
All works fine at this time
Good!
to see some screenshots would be nice also
- sylvainsjc
Re: New KDM version is available, fixed issue of long users'
How do you make a screenshot of KDM?
I tried to /etc/X11/xdm/Xsetup_0 write "sleep 20 && import -window root /tmp/1.jpg" but nothing happened.
- sylvainsjc
LOL Easy !!! I also have ROSA 2012 installed in VirtualBox to make some tests before proceeding on my desktop
So a screenshot of the VB? I see.
I've been doing screenshots of KDM but ... I do not remember how to do it.
- sylvainsjc
Hi,
The last official update is blocking because of this kdm specific version
Here is what I have :
How can I install the last updates ?
[root@rosa2012lts ~]# urpmi --auto-update
le média « main (LTS2012.0-1) » est à jour
le média « main updates (LTS2012.0-2) » est à jour
le média « contrib (LTS2012.0-3) » est à jour
le média « contrib updates (LTS2012.0-4) » est à jour
le média « non-free (LTS2012.0-5) » est à jour
le média « non-free updates (LTS2012.0-6) » est à jour
le média « restricted (LTS2012.0-7) » est à jour
le média « restricted updates (LTS2012.0-8) » est à jour
le média « main_32 » est à jour
le média « main_32_update » est à jour
Pour satisfaire les dépendances, les paquetages suivants vont être installés :
Paquetage Version Révision Dist DEpoch Arch
(média « main updates (LTS2012.0-2) »)
kdebase4-workspace 4.8.3 3 rosa> 2012.0 x86_64
klipper 4.8.3 3 rosa> 2012.0 x86_64
lib64kwineffects1 4.8.3 3 rosa> 2012.0 x86_64
lib64kwinglutils1 4.8.3 3 rosa> 2012.0 x86_64
lib64oxygenstyleconfig4 4.8.3 3 rosa> 2012.0 x86_64
lib64plasma-geolocation-inter> 4.8.3 3 rosa> 2012.0 x86_64
lib64solidcontrol4 4.8.3 3 rosa> 2012.0 x86_64
lib64taskmanager4 4.8.3 3 rosa> 2012.0 x86_64
un espace additionnel de 30Ko sera utilisé.
61Mo de paquets seront récupérés.
Procéder à l'installation des 8 paquetages ? (O/n)
installation de lib64kwinglutils1-4.8.3-3-rosa.lts2012.0.x86_64.rpm klipper-4.8.3-3-rosa.lts2012.0.x86_64.rpm lib64oxygenstyleconfig4-4.8.3-3-rosa.lts2012.0.x86_64.rpm lib64solidcontrol4-4.8.3-3-rosa.lts2012.0.x86_64.rpm lib64taskmanager4-4.8.3-3-rosa.lts2012.0.x86_64.rpm kdebase4-workspace-4.8.3-3-rosa.lts2012.0.x86_64.rpm lib64plasma-geolocation-interface4-4.8.3-3-rosa.lts2012.0.x86_64.rpm lib64kwineffects1-4.8.3-3-rosa.lts2012.0.x86_64.rpm depuis /var/cache/urpmi/rpms
Préparation ... ##########################################################################################################################################################################
L'installation a échoué :
fichier /usr/share/apps/plasma/plasmoids/kdm/contents/ui/main.qml à partir de l'installation de kdebase4-workspace-4.8.3-3.x86_64 est en conflit avec le fichier du package kdm-4.8.3-3.x86_64
fichier /usr/share/apps/plasma/plasmoids/kdm/contents/ui/InputBox.qml à partir de l'installation de kdebase4-workspace-4.8.3-3.x86_64 est en conflit avec le fichier du package kdm-4.8.3-3.x86_64
L'installation a échoué : fichier /usr/share/apps/plasma/plasmoids/kdm/contents/ui/main.qml à partir de l'installation de kdebase4-workspace-4.8.3-3.x86_64 est en conflit avec le fichier du package kdm-4.8.3-3.x86_64
According to our devs, here one file was packaged twice. They said they would correct it, so you'll have to wait a little before trying again.
- sylvainsjc
Hello, updates still stuck with "kdebase4-workspace"
Can I expect soon a correction ?
Contacted the devs again, the moment it's corrected, I'll let you know.sylvainsjc писал(а):Hello, updates still stuck with "kdebase4-workspace"
For x86_64
Add:
and try to update again.
If it's ok, then disable this repo after updating and live happily again.
Update will be sent to main repos shortly.
Add:
urpmi.addmedia test http://abf.rosalinux.ru/downloads/rosa2012lts/container/kdebase4-workspace-295684/RPMS/If it's ok, then disable this repo after updating and live happily again.
- sylvainsjc
Great
and
and
again
Thank you, all works fine
- sylvainsjc
No problem for meДроноваЮ писал(а): sylvainsjc
Do you mind if we use this screenshot in our blog announce?
