Сбой Обновления
Сбой Обновления
Сегодня прилетели обновления, и выдало ошибки
roman@rosa2021 ~ $ sudo  dnf --refresh distrosync
[sudo] пароль для roman:
x11        13 kB/s | 3.3 kB     00:00
ROSA 2021.1 - x86_64 - Contrib - Test Updates        20 kB/s | 3.3 kB     00:00
ROSA 2021.1 - x86_64 - Contrib        30 kB/s | 3.4 kB     00:00
ROSA 2021.1 - x86_64 - Main - Test Updates        47 kB/s | 3.3 kB     00:00
ROSA 2021.1 - x86_64 - Main        38 kB/s | 3.4 kB     00:00
ROSA 2021.1 - x86_64 - Non-free - Test Updates        32 kB/s | 3.3 kB     00:00
ROSA 2021.1 - x86_64 - Non-free        18 kB/s | 3.3 kB     00:00
kde5        38 kB/s | 3.3 kB     00:00
qt5        32 kB/s | 3.3 kB     00:00
kf5        27 kB/s | 3.3 kB     00:00
plasma5        42 kB/s | 3.3 kB     00:00
ROSA 2021.1 - i686 - Contrib        14 kB/s | 3.4 kB     00:00
ROSA 2021.1 - i686 - Contrib - Test Updates        40 kB/s | 3.3 kB     00:00
ROSA 2021.1 - i686 - Main        39 kB/s | 3.4 kB     00:00
ROSA 2021.1 - i686 - Main - Test Updates        32 kB/s | 3.3 kB     00:00
ROSA 2021.1 - i686 - Non-free        27 kB/s | 3.3 kB     00:00
ROSA 2021.1 - i686 - Non-free - Test Updates        29 kB/s | 3.3 kB     00:00
x11-32        31 kB/s | 3.3 kB     00:00
yandex-browser        20 kB/s | 3.0 kB     00:00
Ошибка:
 Проблема 1: cannot install the best update candidate for package pipewire-0.3.63-1.x86_64
  - nothing provides libcamera-base.so.0.0.4()(64bit) needed by pipewire-0.3.67-1.x86_64
  - nothing provides libcamera.so.0.0.4()(64bit) needed by pipewire-0.3.67-1.x86_64
  - nothing provides libroc.so.0.2()(64bit) needed by pipewire-0.3.67-1.x86_64
  - nothing provides libroc.so.0.2(ROC)(64bit) needed by pipewire-0.3.67-1.x86_64
 Проблема 2: package pipewire-utils-0.3.67-1.x86_64 requires pipewire = 0.3.67-1, but none of the providers can be installed
  - cannot install the best update candidate for package pipewire-utils-0.3.63-1.x86_64
  - nothing provides libcamera-base.so.0.0.4 needed by pipewire-0.3.67-1.i686
  - nothing provides libcamera.so.0.0.4 needed by pipewire-0.3.67-1.i686
  - nothing provides libroc.so.0.2 needed by pipewire-0.3.67-1.i686
  - nothing provides libroc.so.0.2(ROC) needed by pipewire-0.3.67-1.i686
 Проблема 3: package pipewire-pulseaudio-0.3.67-1.x86_64 requires pipewire = 0.3.67-1, but none of the providers can be installed
  - cannot install the best update candidate for package pipewire-pulseaudio-0.3.63-1.x86_64
 Проблема 4: package pipewire-jack-0.3.67-1.x86_64 requires pipewire = 0.3.67-1, but none of the providers can be installed
  - cannot install the best update candidate for package pipewire-jack-0.3.63-1.x86_64
 Проблема 5: package pipewire-gstreamer-0.3.67-1.x86_64 requires pipewire = 0.3.67-1, but none of the providers can be installed
  - cannot install the best update candidate for package pipewire-gstreamer-0.3.63-1.x86_64
 Проблема 6: package pipewire-alsa-0.3.67-1.x86_64 requires pipewire = 0.3.67-1, but none of the providers can be installed
  - cannot install the best update candidate for package pipewire-alsa-0.3.63-1.x86_64
 Проблема 7: package lib64jack_pipewire0-0.3.67-1.x86_64 requires pipewire-jack(x86-64) = 0.3.67-1, but none of the providers can be installed
  - package pipewire-jack-0.3.67-1.x86_64 requires pipewire = 0.3.67-1, but none of the providers can be installed
  - cannot install the best update candidate for package lib64jack_pipewire0-0.3.63-1.x86_64
 Проблема 8: package lib64jacknet_pipewire0-0.3.67-1.x86_64 requires pipewire-jack(x86-64) = 0.3.67-1, but none of the providers can be installed
  - cannot install the best update candidate for package lib64jacknet_pipewire0-0.3.63-1.x86_64
 Проблема 9: package lib64jackserver_pipewire0-0.3.67-1.x86_64 requires pipewire-jack(x86-64) = 0.3.67-1, but none of the providers can be installed
  - cannot install the best update candidate for package lib64jackserver_pipewire0-0.3.63-1.x86_64
 Проблема 10: problem with installed package pipewire-0.3.63-1.x86_64
  - package pipewire-0.3.63-1.x86_64 requires lib64pipewire0.3_0 = 0.3.63-1, but none of the providers can be installed
  - cannot install both lib64pipewire0.3_0-0.3.67-1.x86_64 and lib64pipewire0.3_0-0.3.63-1.x86_64
  - cannot install both lib64pipewire0.3_0-0.3.63-1.x86_64 and lib64pipewire0.3_0-0.3.67-1.x86_64
  - cannot install the best update candidate for package lib64pipewire0.3_0-0.3.63-1.x86_64
Даже не знаю с каких репозиториев (тестовых или основных ошибки) - пока подожду, не буду обновляться
Сбой Обновления
Да, нужно ждать, пока пакет roc-toolkit и libcamera, дойдут до зеркал.
Они пока только на
А pipewire уже собран с ними в
http://abf-downloads.rosalinux.ru/qt5cu ... n/release/
Если бы были подключены источники с abf-downloads.rosalinux.ru, то не было бы проблем.
Похоже, что синхронизация зеркал пока отключена.
Сбой Обновления
Можно как то сделать чтобы после обрыва связи обновление докачивалось?
