mongoDB
papahander
Operating system: rosa fresh R6
mongoDB
Сообщение papahander »
Добрый день, не могу запустить mongodb
выхлоп systemctl status mongod.service
Loaded: loaded (/lib/systemd/system/mongod.service; disabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Sat 2023-02-25 10:18:05 MSK; 3min 56s ago
Docs: https://docs.mongodb.org/manual
Process: 7504 ExecStartPre=/bin/mkdir -p /var/run/mongodb (code=exited, status=0/SUCCE>
Process: 7505 ExecStartPre=/bin/chown mongod:mongod /var/run/mongodb (code=exited, sta>
Process: 7506 ExecStartPre=/bin/chmod 0755 /var/run/mongodb (code=exited, status=0/SUC>
Process: 7507 ExecStart=/usr/bin/mongod $OPTIONS (code=exited, status=2)
CPU: 32ms
фев 25 10:18:05 rosa2021.1 systemd[1]: Starting MongoDB Database Server...
фев 25 10:18:05 rosa2021.1 mongod[7507]: Error opening config file: Is a directory
фев 25 10:18:05 rosa2021.1 mongod[7507]: try '/usr/bin/mongod --help' for more information
фев 25 10:18:05 rosa2021.1 systemd[1]: mongod.service: Control process exited, code=exited>
фев 25 10:18:05 rosa2021.1 systemd[1]: mongod.service: Failed with result 'exit-code'.
фев 25 10:18:05 rosa2021.1 systemd[1]: Failed to start MongoDB Database Server.
Буду признателен за помощь.
papahander
mongoDB
Где исправить
papahander
mongoDB
путь к конф. файлу исправил, но легче не стало.
systemctl status mongod.service выдает
mongod.service - MongoDB Database Server
Active: failed (Result: exit-code) since Sat 2023-02-25 12:11:30 MSK; 41s ago
Process: 2797 ExecStartPre=/bin/mkdir -p /var/run/mongodb (code=exited, status=0/SUCCE>
Process: 2798 ExecStartPre=/bin/chown mongod:mongod /var/run/mongodb (code=exited, sta>
Process: 2799 ExecStartPre=/bin/chmod 0755 /var/run/mongodb (code=exited, status=0/SUC>
Process: 2800 ExecStart=/usr/bin/mongod $OPTIONS (code=exited, status=1/FAILURE)
CPU: 67ms
фев 25 12:11:29 rosa2021.1 systemd[1]: Starting MongoDB Database Server...
фев 25 12:11:30 rosa2021.1 mongod[2800]: about to fork child process, waiting until server>
фев 25 12:11:30 rosa2021.1 mongod[2807]: forked process: 2807
фев 25 12:11:30 rosa2021.1 mongod[2800]: ERROR: child process failed, exited with 1
фев 25 12:11:30 rosa2021.1 mongod[2800]: To see additional information in this output, sta>
фев 25 12:11:30 rosa2021.1 systemd[1]: mongod.service: Control process exited, code=exited>
фев 25 12:11:30 rosa2021.1 systemd[1]: mongod.service: Failed with result 'exit-code'.
фев 25 12:11:30 rosa2021.1 systemd[1]: Failed to start MongoDB Database Server.
mongoDB
Ну логи смотрите у сервера.
Скоро соберется и версия 6.2.0, путь к конфигу я в ней уже исправил.
papahander
mongoDB
Все, проблема решена.
При установке создается папка /var/log/mongo. Если mongo переименовать в mongodb, то все ОК.
mongoDB
papahander, спасибо исправил в репозитарии в пакетах пути. :good:
