Full screen and lauguage
disegnoarch
Operating system: mandriva
Сообщение disegnoarch »
Hi everyone, I have installed ROSA FRESH DESKTOP 2021.1 on my computer and I have 2 problems.
1) KWIN responds well to the CTRL+F8 command and correctly frames all 4 desktops (chosen by me) in a single screen. But when I press F11 ( full screen ) the screen goes black. This is for all programs.
2) I am Italian and I have chosen my language for the system and consequently the keyboard (Italian). On the bottom panel, however, I am offered only two possibilities: US > English language and RU > Russian language. You will have noticed from the accents that to me the keyboard is all busted.
If you can help me I would be very grateful.
Hello
Peter
1. There are too many bugs in the latest versions of kde...
You can try the unofficial version, maybe it will not have this problem. Download this file and put it in /etc/yum.repos.d/. Then run the command
$ sudo dnf update --refresh
2. Have you tried adding the desired layout in the keyboard settings?
disegnoarch
bash-5.0$ su
Password:
rosa2021 etc # chmod -R 777 yum.repos.d
rosa2021 etc # sudo dnf update --refresh
ROSA 2021.1 - x86_64 - Contrib 13 kB/s | 3.4 kB 00:00
ROSA 2021.1 - x86_64 - Contrib 842 kB/s | 2.1 MB 00:02
ROSA 2021.1 - x86_64 - Main 15 kB/s | 3.4 kB 00:00
ROSA 2021.1 - x86_64 - Main 790 kB/s | 1.7 MB 00:02
ROSA 2021.1 - x86_64 - Non-free 14 kB/s | 3.3 kB 00:00
ROSA 2021.1 - x86_64 - Non-free 15 kB/s | 10 kB 00:00
x11 321 kB/s | 338 kB 00:01
kde5 1.3 MB/s | 1.7 MB 00:01
qt5 229 kB/s | 210 kB 00:00
ROSA 2021.1 - i686 - Contrib 15 kB/s | 3.4 kB 00:00
ROSA 2021.1 - i686 - Contrib 914 kB/s | 2.1 MB 00:02
ROSA 2021.1 - i686 - Main 13 kB/s | 3.4 kB 00:00
ROSA 2021.1 - i686 - Main 772 kB/s | 1.6 MB 00:02
ROSA 2021.1 - i686 - Non-free 15 kB/s | 3.3 kB 00:00
ROSA 2021.1 - i686 - Non-free 14 kB/s | 3.3 kB 00:00
x11-32 292 kB/s | 287 kB 00:00
Errore:
Problema: mesa-22.3.2-1.i686 has inferior architecture
- cannot install both mesa-22.3.2-1.x86_64 and mesa-22.1.7-1.x86_64
- cannot install the best update candidate for package mesa-21.2.4-1.i686
- cannot install the best update candidate for package mesa-21.2.4-1.x86_64
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
rosa2021 etc #
disegnoarch
Thanks and happy new year! The first part of the command served me to put the file you indicated in the folder. Can I still go on? Hello
Try to fulfill
dnf clean all
And then again
disegnoarch писал(а): 09 дек 2022, 13:42 I am Italian and I have chosen my language for the system and consequently the keyboard (Italian)
You have selected a language for the system only, not for the keyboard. For the keyboard, the layout is set in the System Settings.
