Библиотека javascriptcoregtk-4.0
kopm
Operating system: ROSA Fresh Desktop 12.3 Plasma
Сообщение kopm »
При попытке собрать приложение написанное на rust не находится библиотека javascriptcoregtk-4.0
Compiling gtk3-macros v0.15.4
The following warnings were emitted during compilation:
warning: `"pkg-config" "--libs" "--cflags" "javascriptcoregtk-4.0" "javascriptcoregtk-4.0 >= 2.24"` did not exit successfully: exit status: 1
error: failed to run custom build command for `javascriptcore-rs-sys v0.4.0`
Caused by:
  process didn't exit successfully: `/home/max/Repo/test/src-tauri/target/debug/build/javascriptcore-rs-sys-091fab43d3dc0e89/build-script-build` (exit status: 1)
  --- stdout
  cargo:rerun-if-env-changed=JAVASCRIPTCOREGTK_4.0_NO_PKG_CONFIG
  cargo:rerun-if-env-changed=PKG_CONFIG_x86_64-unknown-linux-gnu
  cargo:rerun-if-env-changed=PKG_CONFIG_x86_64_unknown_linux_gnu
  cargo:rerun-if-env-changed=HOST_PKG_CONFIG
  cargo:rerun-if-env-changed=PKG_CONFIG_PATH_x86_64-unknown-linux-gnu
  cargo:rerun-if-env-changed=PKG_CONFIG_PATH_x86_64_unknown_linux_gnu
  cargo:rerun-if-env-changed=HOST_PKG_CONFIG_PATH
  cargo:rerun-if-env-changed=PKG_CONFIG_LIBDIR_x86_64-unknown-linux-gnu
  cargo:rerun-if-env-changed=PKG_CONFIG_LIBDIR_x86_64_unknown_linux_gnu
  cargo:rerun-if-env-changed=HOST_PKG_CONFIG_LIBDIR
  cargo:rerun-if-env-changed=PKG_CONFIG_SYSROOT_DIR_x86_64-unknown-linux-gnu
  cargo:rerun-if-env-changed=PKG_CONFIG_SYSROOT_DIR_x86_64_unknown_linux_gnu
  cargo:rerun-if-env-changed=HOST_PKG_CONFIG_SYSROOT_DIR
  cargo:warning=`"pkg-config" "--libs" "--cflags" "javascriptcoregtk-4.0" "javascriptcoregtk-4.0 >= 2.24"` did not exit successfully: exit status: 1
  error: could not find system library 'javascriptcoregtk-4.0' required by the 'javascriptcore-rs-sys' crate
  --- stderr
  Package javascriptcoregtk-4.0 was not found in the pkg-config search path.
  Perhaps you should add the directory containing `javascriptcoregtk-4.0.pc'
  to the PKG_CONFIG_PATH environment variable
  Package 'javascriptcoregtk-4.0', required by 'virtual:world', not found
warning: build failed, waiting for other jobs to finish...
max@rosa2021 ~ $ locate javascriptcoregtk-3.0
/usr/lib64/libjavascriptcoregtk-3.0.so
/usr/lib64/libjavascriptcoregtk-3.0.so.0
/usr/lib64/libjavascriptcoregtk-3.0.so.0.16.19
/usr/lib64/pkgconfig/javascriptcoregtk-3.0.pc
max@rosa2021 ~ $ locate javascriptcoregtk-4.0
/usr/lib64/libjavascriptcoregtk-4.0.so.18
/usr/lib64/libjavascriptcoregtk-4.0.so.18.20.10
max@rosa2021 ~ $ pkg-config --cflags javascriptcoregtk-3.0
-I/usr/include/webkitgtk-3.0 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include
max@rosa2021 ~ $ pkg-config --cflags javascriptcoregtk-4.0
Насколько я понимаю не хватает файлов /usr/lib64/pkgconfig/javascriptcoregtk-4.0.pc и /usr/lib64/libjavascriptcoregtk-4.0.so. Пакеты вроде все установлены:
max@rosa2021 ~ $ dnf list installed | grep lib64javascriptcoregtk
lib64javascriptcoregtk1.0_0.x86_64                  2:2.4.11-6                @Main
lib64javascriptcoregtk3.0_0.x86_64                  1:2.4.11-8                @mirror-rosa-x86_64-contrib
lib64javascriptcoregtk4.0_18.x86_64                 1:2.36.6-2                @Main
Кто-нибудь знает как решить проблему?
dnf install pkgconfig\(javascriptcoregtk-4.0\) попробуйте
kopm
Сообщение kopm »
irton, спасибо, собралась программа. Я не сильно давно в Linux, в связи с этим вопрос, что значит представленная Вами команда? dnf install - понятно, а дальше что? Что ставит в данном случае dnf?
Ставит провайд (Provides) который есть у пакета ( скобки только экранировать нужно.
Провайд pkgconfig(foo) автоматически задается пакету, если в нем есть foo.pc файл в каталоге pkgconfig. Ну и для других пакетов тоже автоматически создаются провайды, по которым эти пакеты можно устанавливать для сборки или в систему.
