Не запускается игра в steam
morbid_s
Operating system: ROSA 2021.1
Сообщение morbid_s »
Следующий вопрос.
Поставил драйверы Nvidia 460, через dnf, отконфигурил через XFDrake. Всё норм.
Поставил стим. Пытаюсь запустить WOT через Proton (пробовал всякий), загорается надпись в стиме о запуске игры и тухнет, игра не запускается.
Лог из консоли:
GameAction [AppID 1407200, ActionID 2] : LaunchApp changed task to ProcessingInstallScript with ""
esync: up and running.
wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
wine: could not open working directory L"C:\\windows\\system32\\", starting in the Windows directory.
wine: failed to open "c:\\windows\\system32\\steam.exe": c0000135
GameAction [AppID 1407200, ActionID 2] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 1407200, ActionID 2] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 1407200, ActionID 2] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 1407200, ActionID 2] : LaunchApp continues with user response "CreatingProcess"
/bin/sh\0-c\0/home/myfolder/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1407200 -- '/home/myfolder/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/myfolder/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/media/myfolder/System/Games/Steam/steamapps/common/World of Tanks/wgcs_api.exe'\0
Game process added : AppID 1407200 "/home/myfolder/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1407200 -- '/home/myfolder/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/myfolder/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/media/myfolder/System/Games/Steam/steamapps/common/World of Tanks/wgcs_api.exe'", ProcID 24213, IP 0.0.0.0:0
chdir /media/myfolder/System/Games/Steam/steamapps/common/World of Tanks
ERROR: ld.so: object '/home/myfolder/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
GameAction [AppID 1407200, ActionID 2] : LaunchApp changed task to WaitingGameWindow with ""
GameAction [AppID 1407200, ActionID 2] : LaunchApp changed task to Completed with ""
ERROR: ld.so: object '/home/myfolder/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
pid 24217 != 24214, skipping destruction (fork without exec?)
pid 24422 != 24421, skipping destruction (fork without exec?)
Game process removed: AppID 1407200 "/home/myfolder/.local/share/Steam/ubuntu12_32/reaper SteamLaunch AppId=1407200 -- '/home/myfolder/.local/share/Steam/steamapps/common/SteamLinuxRuntime_soldier'/_v2-entry-point --verb=waitforexitandrun -- '/home/myfolder/.local/share/Steam/steamapps/common/Proton 7.0'/proton waitforexitandrun '/media/myfolder/System/Games/Steam/steamapps/common/World of Tanks/wgcs_api.exe'", ProcID 24213
ThreadGetProcessExitCode: no such process 24426
ThreadGetProcessExitCode: no such process 24424
ThreadGetProcessExitCode: no such process 24421
ThreadGetProcessExitCode: no such process 24420
ThreadGetProcessExitCode: no such process 24419
ThreadGetProcessExitCode: no such process 24418
ThreadGetProcessExitCode: no such process 24215
ThreadGetProcessExitCode: no such process 24214
Uploaded AppInterfaceStats to Steam
Что может быть?
Вы запускаете игру для windows?
Если да, то нужно подбирать движёк Proton.
Некоторые игры не запускаются на новых версиях Proton, а на старых запускаются.
morbid_s
Спасибо за ответ!
Нашел решение тут: https://wiki.archlinux.org/title/Steam/ ... _partition
У меня библиотека стим(линукс) была создана на NTFS разделе. Сделал симлинки, как указано по ссылке выше, выбрал протон 6 версии - всё запустилось. Бегает гоооораздо бодрее чем через wine. Правда, вот из-за этого ВГ конечно, огромный минус: https://ru.wargaming.net/support/ru/pro ... p-articles
Получается, я не могу своим аккаунтом воспользоваться. Только новый создать.
Ещё раз спасибо за помощь, намёк с новыми темами понял ;-)
